Lenovo L340-15API BIOS Dump needed
  • hoaca388
    Badcaps
    • Jan 2022
    • 11512
    • Viet Nam
    #41
    Originally posted by beast4ever
    Unfortunately, it only flashes in the power button.
    Check hardware.
    • mohamedelmasry
      • Feb 2021
      • 21
      • egypt
      #42
      EC please >>>
      • peste
        • 12438
        • ROMANIA
        #43
        Originally posted by mohamedelmasry
        EC please >>>
        post the S/N, post the original content of the bios chip, the motherboard model, the full name and model of the laptop,etc.
        • mohamedelmasry
          • Feb 2021
          • 21
          • egypt
          #44
          WHY ALL THESE INFO
          • peste
            • 12438
            • ROMANIA
            #45
            WHY ALL THESE INFO
            because those are the forum rules..
            • mohamedelmasry
              • Feb 2021
              • 21
              • egypt
              #46
              here is backup
              mother board NM_C101
              i want the EC
              • shiyab
                • Sep 2023
                • 1258
                • india
                #47
                here is backup
                i want the EC
                post snid
                • 789852
                  • Nov 2015
                  • 51
                  • Kazahstan
                  #48
                  good afternoon, Lenovo L340-15API. NM-C101 Rev:1.0
                  please tell me in which direction to look. The laptop turns on, all devices are working, but it constantly emits 2 beeps. The multicontroller was replaced and the firmware was taken from this forum branch. I also noticed that when you turn off the device, you can turn it on again only by holding the power button for a long time, the PWM replaced all the devices and checked. I replaced the RAM with a chip, the RAM was soldered. Maybe someone has come across tell me
                  • 789852
                    • Nov 2015
                    • 51
                    • Kazahstan
                    #49
                    2 beeps
                    the problem was in the network
                    • Joluvillas
                      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                      by Joluvillas
                      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                      06-18-2024, 10:35 PM
                    • AHmad_Salal
                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                      by AHmad_Salal
                      Hello all,
                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                      11-28-2023, 05:28 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • TacticalFahrrad
                      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                      by TacticalFahrrad
                      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                      06-30-2025, 04:09 AM
                    • hirens
                      Lenovo ideapad 3 14IGL05 bios dump needed
                      by hirens
                      model: 81wh
                      sn: pf36ta6h
                      board no: nm-c961 gs453/gs553
                      hey guys above is my laptop info
                      it only blinks the power button kindly help me with a working dump
                      old dump attached...
                      07-21-2023, 04:48 AM
