asus x415ja bios
  • fadi4001
    • Mar 2016
    • 4
    • Damascus
    #141
    Originally posted by SMDFlea
    Try the ram patcher script - https://www.badcaps.net/forum/troubl...20#post3232220 .If it doesn`t work look for the schematic/boardview and try to disable by resistor straps.
    Sir only is edited bios to disable RAM
    • badal
      • Sep 2016
      • 56
      • india
      #142
      can any help rebuild my no display bios
      asus X515JA-EJ562WS(X515JA)
      S/N-MBN0CX17M39146E
      MB-X415JA REV 3.1
      OLD BIOS ATTACHED
      • s_specialist
        • Jul 2013
        • 31
        • Turkey
        #143
        Good luck, my experts. The Asus X515JF appears to have a problem with the onboard RAM after it was exposed to liquid. The motherboard code is X415JA Rev 2.1. I found the BIOS for X415JA Rev 3.1 online. I got an image with it, but it didn't detect the graphics card. The keys on the keyboard clicked differently. I also tried sliding the resistor, but I couldn't get an image. I'm sending the BIOS of the device. Could you disable the onboard RAM? Thanks.
        Serial number : M6N0CX250483267
          • 22274
          Thread merged..next time please look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • s_specialist
            • Jul 2013
            • 31
            • Turkey
            #145
            Thanks, I did it the way you said and it worked.
            Asus X415ja Rev 2.1 onboard ram disable working bios:
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
