IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12333
    #261
    Originally posted by eu7abz@tut.by
    SN: PF35JM4B
    Don't forget to include the serial number when making a request, this is a forum rule.
    • eu7abz@tut.by
      • Sep 2018
      • 11
      • Беларусь
      #262
      Thank you very much!
      After the firmware it turned on and froze, after rebooting there is no initialization. I have another malfunction.​
      • than_22
        • Sep 2017
        • 53
        • philippines
        #263
        Please help me to Disable onboard RAm
        Lenovo V15-ADA
        Board Code - GV451 & GV551 Nm-D151
        S/N - PF2862KS
        MTM - 82C7005RPH
        • shiyab
          • Sep 2023
          • 1618
          • india
          #264
          Lenovo V15-ADA
          S/N - PF2862KS
          MTM - 82C7005RPH
          hi try
          • than_22
            • Sep 2017
            • 53
            • philippines
            #265
            Originally posted by shiyab
            hi try
            not working,, laptop no display with this bios
              • 21951
              Disable RAM by resistor straps - https://www.badcaps.net/forum/troubl...vo-ip3-nm-d151
              • than_22
                • Sep 2017
                • 53
                • philippines
                #267
                Originally posted by SMDFlea
                This one Solved the issue,, Thank You,, GODbless Badcaps Forum
                • its service
                  • Feb 2021
                  • 147
                  • india
                  #268
                  Model : V15-Ada
                  SN : pf26b1fc
                  Part no : Nm-d151 rev 1.0
                  Problem no display need to onboard ram disable, I'll attached the originial dump
                  • peste
                    • 13641
                    • ROMANIA
                    #269
                    Originally posted by its service
                    Model : V15-Ada
                    SN : pf26b1fc
                    try..
                    • Crazy Dad
                      • Dec 2024
                      • Uzbekistan
                      #270
                      Hello, please help me with the BIOS,
                      LENOVO 15-ADA MODEL 82C7
                      SN: PF2NS1TZ
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12333
                        #271
                        SN: PF2NS1TZ
                        V15-ADA Laptop (Lenovo) - Type 82C7
                        • Crazy Dad
                          • Dec 2024
                          • Uzbekistan
                          #272
                          Hello, thank you for helping, but the BIOS you posted didn't help, still a black screen with a blinking backlight
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12333
                            #273
                            Then you should check the hardware.
                            • MrMike25
                              • Mar 2022
                              • 6
                              I have an Lenovo ideapad 3 15ADA05 with a bios password​. I pulled the bin file off the bios chip but I can't seem to find where the password is located to translate it from a hex editor. I can reflash the bios but it removes everything even the product key. I really like to find the password so I can enter it and remove it. I have done this in the past but it's been years since. I can see where it says supervisor password and password in the hex editor but the coding isn't letting me convert it into a password. Any help would be greatly appreciated. Thanks!
                                • 21951
                                Thread merged. Please read the rules, the laptop serial number must be posted with every bios request. Read post 1 you can add the DMI from your backup to the new bios using the script.
                                • Seb RS
                                  • Sep 2024
                                  • 9
                                  • france
                                  #276
                                  Same as everyone else, black screen at boot on a Lenovo 17ADA05.
                                  I followed the tutorials.
                                  I extracted the bios to recover the original DMI block but the ROM is completely empty !
                                  Can you help me ?
                                  Lenovo 17ADA05
                                  Model: 81W2
                                  SN: PF3FRKGZ
                                  MTM: 81W20059EN​
                                  • peste
                                    • 13641
                                    • ROMANIA
                                    #277
                                    Can you help me ?
                                    Lenovo 17ADA05
                                    Model: 81W2
                                    SN: PF3FRKGZ
                                    MTM: 81W20059EN
                                    you have everything you need at post #217...
                                    The bios chip must be unsoldered from the board before writing or reading..
                                    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                    solder wires between the programmer and the bios chip..​
                                    • reparacipo
                                      • Jun 2018
                                      • 31
                                      • argentina
                                      #278
                                      Hi guys,
                                      Please I need to repair this bios.
                                      I commented: The cover does not have the model data, serial number, etc., I do have the backup of the original bios, but it does not give me an image, I have tried creating a bios from the website and it works but the notebook model does not appear , nor the MTM, nor the serial number.
                                      Can the bios be repaired?​
                                        SMDFlea commented
                                        Editing a comment
                                        Thread merged. Read post 1 ,everything you need is right here in this thread.
                                    • rindorika
                                      • Jan 2025
                                      • Turkey
                                      #279
                                      I have attached my original dump. Could you please check and correct it? Thanks.
                                      SN: PF2KVQ11
                                      MTM: 82C7007KTX​
                                      • peste
                                        • 13641
                                        • ROMANIA
                                        #280
                                        SN: PF2KVQ11
                                        MTM: 82C7007KTX​
                                          Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 05:00 AM
                                        • Patriarxis
                                          Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                          by Patriarxis
                                          Hello.
                                          I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                          It takes 0.027A and the power button flashing.
                                          All the voltages on the board are ok. 3.3, 5 etc.
                                          Also is charging the buttery .
                                          What else i can check?​
                                          05-26-2025, 01:03 AM
                                        • hotcrossedbuns999
                                          IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                          by hotcrossedbuns999
                                          First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                          Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                          05-21-2025, 05:59 PM
                                        • pcwhiz24
                                          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                          by pcwhiz24
                                          Model: Lenovo IdeaPad 3 14ADA05 81W0
                                          S/N: PF2BZS7D
                                          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                          I already have a CH341A programmer...
                                          04-07-2025, 07:10 PM
                                        • Visual_vt
                                          Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                          by Visual_vt
                                          Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                          SSD and BIOS seems to be OK.
                                          Thank you....
                                          12-30-2024, 09:14 AM
