dell latitude 7300 bios
  • jaglion19
    • Oct 2017
    • 110
    • TURKEY
    dell latitude 7300 bios tested ok.
    LA-G861P REV 1.0 BİOS TESTED OK.
    LA-G861P V1.0 BİOS TESTED OK
  • peste
    • Dec 2016
    • 13874
    • ROMANIA
    Re: dell latitude 7300 bios
    the bios from post # 1, with the ME region clean..I hope it will be helpful ..
    • jaglion19
      • Oct 2017
      • 110
      • TURKEY
      [QUOTE=peste;1050836]the bios from post # 1, with the ME region clean..I hope it will be helpful ..
      very thank you
      • jaglion19
        • Oct 2017
        • 110
        • TURKEY
        it works flawlessly. thanks.
        • bejaoui
          • Feb 2017
          • 64
          • ariana
          the bios is unlock
          • peste
            • Dec 2016
            • 13874
            • ROMANIA
            Originally posted by bejaoui
            the bios is unlock
            you have no way of knowing until you try it .. make a copy of the original bios of the laptop and then try the bios from post # 2 ..
            • ace.code
              • Apr 2016
              • 133
              • Estonia
              i posted my org dump in another post and cant get it unlocked
              but when i try your dump the laptop is unlocked but the ssd is not detected can you help here my dump
              • farouk_1994
                • Mar 2021
                • 399
                • algeria
                try it
                • ismy4real
                  • Dec 2011
                  • 87
                  pls i want to unlock my dell 7300
                  the file posted here is not detecting ssd
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    Here's your Unlocked Bios, hope it works fine.
                    all donations are welcome,
                    • ismy4real
                      • Dec 2011
                      • 87
                      thaks working perfect
                      • karemkf
                        • May 2020
                        • 22
                        • egypt
                        hi ineed cler bios late display
                        • hardware1
                          • Sep 2021
                          • 2949
                          • N/A
                          Here's your Clean BIOS, try it.
                          Next time you can follow the steps in that Guide and do it by yourself.
                          https://www.badcaps.net/forum/showthread.php?t=88533
                          • kesmeseker
                            • Jan 2015
                            • 121
                            • turkey
                            hi .no display dell. add old bios. thanks
                            service tag FVNKQ13
                            • Kiajalali
                              • Jun 2017
                              • 7
                              Hello after flashing new bios it freezes before booting into any operative system/installer, does any one knows about it?
                              • gotowiec27
                                • Aug 2022
                                • 14
                                • Poland
                                Hi, could someone help me with removing the password from the attached file?
                                Thanks in advance.
                                  • 22216
                                  Thanks in advance.
                                  You must post the service tag - https://www.badcaps.net/forum/showthread.php?t=103570
                                  • gotowiec27
                                    • Aug 2022
                                    • 14
                                    • Poland
                                    Oh, yes, sorry. The service tag is HV9DQ13
                                    • aldopc
                                      • Jul 2017
                                      • 480
                                      • Chilito
                                      Test and comments
                                      • gotowiec27
                                        • Aug 2022
                                        • 14
                                        • Poland
                                        It worked flawlessly. Huge thanks for your help!
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
                                          DELL Latitude 7300 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 7300 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7300 boardview and 7300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7300...
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 12:36 PM
