Asus TP412FA
  • meroo2041
    • Nov 2020
    • 29
    • saudi arabia
    Asus TP412FA
    please help me need ASUS tp412fa bios
    don't have original file my programmer cant see flash
    need file please board number tp412fa mini board rev 2.1
    thanks
    • 20888
    Re: asus tp412fa bios
    thanks
    What model is your programmer ?
    • meroo2041
      • Nov 2020
      • 29
      • saudi arabia
      mini pro tl866cs
      i need file then will replace bios ic
      • Bonzas
        • 471
        • Indonesia
        Asus TP412FA
        Need Help remove this bios password, i've try remove 1 password that i think it admin, but only user password.
        Thanks before
          • 20888
          Re: Asus TP412FA
          Its an AMI bios, the AMITSE method will work on this. https://gist.github.com/en4rab/55088...f3039e3c8ab6fd
          Its been mentioned on the forum many times how to decrypt.Open the bios with a hex editor,search for AMITSE ,keep searching again until you find an AMITSE area with some code.Copy the hex and make it the same length as the decyption hex ,XOR both codes to ASCII
          Copy the first line of hex into notepad/wordpad ,remove the spaces.
          This is the second code to decrypt the first
          5B93B62611BA6C4DC7E022747D07D89A332E8EC1E95444E89F7BFA0E55A2B0350BC9665CC1EF1C83
          Enter both hex codes at http://xor.pw ,output to ASCII
          • Bonzas
            • 471
            • Indonesia
            Re: Asus TP412FA
            Ah thanks for your info, i already find something usefull info before i make this post. Maybe i don't see about that. Really thanks for help sir
            • matusiq
              • Dec 2020
              • 58
              • Slovakia
              Re: Asus TP412FA
              OMG ... I have tried to understand that in the past ... I was looking at it like a goat THX SMDFLEA such a easy explanation !
              • tikanot
                • Mar 2020
                • 67
                • france
                Asus TP412FA
                hello i have an Asus TP412FA with no power on , maybe bios corrupted any have bios in order to try this in first try. Maybe it's the ec?
                thanks
                • cacla
                  • Apr 2015
                  • 442
                  Re: Asus TP412FA
                  thanks
                  Give me the sn from the unit
                  • tikanot
                    • Mar 2020
                    • 67
                    • france
                    Re: Asus TP412FA
                    hi pn is tp412fa-ec143r and sn is kcn0lp00e24750a
                    • tikanot
                      • Mar 2020
                      • 67
                      • france
                      Re: Asus TP412FA
                      see the original bios
                      • cacla
                        • Apr 2015
                        • 442
                        Re: Asus TP412FA
                        Sorry for the late respond but here it is
                        • tikanot
                          • Mar 2020
                          • 67
                          • france
                          Re: Asus TP412FA
                          i read my bios with hexeditor i see stranger thing
                          • tikanot
                            • Mar 2020
                            • 67
                            • france
                            Re: Asus TP412FA
                            hi i flash the bios , and same thing no power on
                            • cacla
                              • Apr 2015
                              • 442
                              Re: Asus TP412FA
                              This is F1 bios. You have other problem its not the bios.
                              • tikanot
                                • Mar 2020
                                • 67
                                • france
                                Re: Asus TP412FA
                                yes other mistake , i must open a new post
                                • syaiful
                                  • Mar 2023
                                  • indonesia
                                  Re: Asus TP412FA
                                  its works
                                  • pangtyorb1
                                    • Mar 2023
                                    • 3
                                    • canada
                                    Asus Vivobook Flip 14 TP412FA clean BIOS need
                                    Hi, I lost the BIOS password of my ASUS laptop, I can read and write BIOS files with a programmer, how to unlock it? Thanks a lot for the help!
                                    TP412FAC Rev. 2.0
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      Re: Asus Vivobook Flip 14 TP412FA clean BIOS need
                                      TP412FAC Rev. 2.0
                                      Admin Password : 8328
                                      Boot Password : 7fjp89bm
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                      • pangtyorb1
                                        • Mar 2023
                                        • 3
                                        • canada
                                        Thank you, problem solved
                                          ASUS VivoBook TP412FA-EC494T Hybrid (2-in-1) Flip 14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412FA-EC494T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412FA-EC494T boardview and TP412FA-EC494T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 02:00 AM
                                          ASUS VivoBook TP412FA-EC470T Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412FA-EC470T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412FA-EC470T boardview and TP412FA-EC470T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 08:40 PM
                                          ASUS VivoBook TP412FA-Q3MS1-CB Hybrid (2-in-1) Flip 14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412FA-Q3MS1-CB Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412FA-Q3MS1-CB boardview and TP412FA-Q3MS1-CB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 08:10 PM
                                          ASUS VivoBook TP412FA-C3MS1-CA Hybrid (2-in-1) Flip 14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412FA-C3MS1-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412FA-C3MS1-CA boardview and TP412FA-C3MS1-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS VivoBook TP412FA-EC142T Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412FA-EC142T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412FA-EC142T boardview and TP412FA-EC142T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:00 PM
