Razer Blade 15” Base 2020 (RZ09-0328x) Bricked due to BIOS upgrade
    • 22197
    Re: Razer Blade 15” Base 2020 (RZ09-0328x) Bricked due to BIOS upgrade
    Originally posted by beatngu
    Could you please send me divided (8MB file)?
    I already asked Razer "support" million times but they keep saying they don't send individual parts and I should send it back to them for repair (which means a full mobo replace most probably...
    New EC to try .
    • hitchikers
      • Sep 2021
      • Philippines
      #42
      Thanks for this post OP. CH341A Programmer and BIOS 1.6 works like a charm. My Razer Blade 15 RZ090-0328 is alive again after getting bricked. When flashing make sure the clip-on ribbon clip is securely attached to the bios chip and no copper pins are sticking out or are slightly visible.
      • xperia.1.ns
        • Jul 2021
        I need help. I have the same problem and I try all files same result. fun work no picture try external monitor no picture also.
        • hunglaptop1102
          • Dec 2018
          • 84
          • viet nam
          #44
          please help me bios Razer Blade 15 RZ09-03287E72
          I can't click the source and I think it's a bios error
          please help me clean it
          and here are the main and bios pictures I copied
          Thank for all
            • 22197
            Re: please help me bios Razer Blade 15 RZ09-03287E72
            Thank for all
            Post #40 is a virgin bios extracted from razer bios update 1.06 https://mysupport.razer.com/app/answ...%7C-rz09-0328x
            • hunglaptop1102
              • Dec 2018
              • 84
              • viet nam
              #46
              thank you
              • Niyozov
                • Jun 2022
                • 4
                Hello Guys,
                I have a Razer Blade 15” Base 2020 (RZ09-0328x) and performed a BIOS update last week (used the factory 1.06). During installation Windows 10 BSODd and my computer didn't start anymore. I could manage to manually flash the BIOS with a CH341A Programmer (only to version 1.03 as 1.06 is still killing my machine) but after that my touchpad is not working anymore. When I check BIOS I could see proper main version but for EC FW and MCU FW versions I see version 1.0.x. (which seems to be incorrect for me). I extracted the BIOS image from official updater (it contained 2 BINs, Dana5_0106.bin and Dana5_0106_FWUpdate.bin.
                After few more attmepts my laptop totally died (no charging, no LEDs, etc.). I guess it has something to do with EC chip.
                So my request would be if anyone has the same model would you please provide me extracted BIOS and EC FW?
                Thanks much in advance!
                Hi do you have dump of the bios firmware 1.03?
                • bobo00
                  • Jul 2022
                  Hi, The Embedded Controller IT 8390E does not have an external bios chip it is a programmable controller, it is sold pre-programmed
                  • BalkanBoy
                    • Feb 2017
                    • 69
                    • Croatia
                    #49
                    can you please help me identify resistor from the photo, I accidentally lost it somewhere when changing PCH.
                    Thanks!
                    • Yehuda170
                      • Jan 2015
                      • 34
                      • Israel
                      #50
                      BalkanBoy
                      30.60 Ohm
                      the 8MB chip is EC FW
                      the 16MB chip is BIOS&ME FW
                      • kiensgpro
                        Badcaps VIETNAM
                        • Nov 2021
                        • 17
                        #51
                        Can I ask you a question. 0328x is including 03289 right. and EC can copy together, right? because the original bios is dead 2. so it has to be replaced with another bios. thanks admin
                        • cr4zychriss
                          by cr4zychriss
                          • Rebrand: PC Specialist
                          11-14-2025, 04:04 PM
                        • vinaypundith
                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                          by vinaypundith
                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                          08-03-2024, 12:32 PM
                        • studdy05
                          Bricked HP Probook 450 G7 Bios questions
                          by studdy05
                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                          Ive got...
                          07-08-2025, 09:24 PM
                        • Awdev
                          Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
                          by Awdev
                          S/N is BY2011A72401766
                          Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
                          MB Model is: DA530-MB
                          Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
                          10-18-2025, 02:13 AM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
