ThinkPad T14 Supervisor password
  • picasso_86
    • Oct 2021
    • 10
    • Poland
    #41
    Re: ThinkPad T14 Supervisor password
    Hello, it's my first post... So, I Welcome... My English not so strong, and i'm Sorry about that...
    I also have secured Lenovo T14 1st gen, I have programmer EZP2010. When I Try to unlock by autopatcher I have this messege:
    "Using UEFIReplace to inject 2 DXE drivers...
    [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
    LENOVOORG.bin is corrupted or does not contain a valid dump.
    There was an error... Aborting."
    I have few questions... How big should be dump file of this chip? My, is only 1024KB
    There is Winbond 25Q80DVSIG
    It is necessary to solder out this chip? Right now I use clips, to read this chip.
    Can someone tell me, is my dump is correct?
    Thanks in advance
    • 69d0b913
      • Mar 2018
      • 146
      • BR
      #42
      Thanks in advance
      T14 has no solution, only recording the I/O as far as I know, you can't patch like the other models, your DUMP is wrong, the DUMP of this machine has 32MB.
      • picasso_86
        • Oct 2021
        • 10
        • Poland
        #43
        WOW Thanks for this fast reply... OK I will try to do better dump. Can You Tell Me something more about I/O recording?
        • 69d0b913
          • Mar 2018
          • 146
          • BR
          #44
          I don't have an IO recorder but I know "vertyanov" does this job. This chip you read the DUMP on is not the correct one, it's another chip.
          • picasso_86
            • Oct 2021
            • 10
            • Poland
            #45
            If I good understand... when I buy vertyanov for example from here Vertyanov ebay I'll be able to programm KBC via keyboard slot, and then, i will clear SVP? but from where I can download KBC dump without SVP??
            • 69d0b913
              • Mar 2018
              • 146
              • BR
              #46
              that's just what I heard, that the solution is to record IO, where to find the file I don't know. But I think it is not difficult, otherwise the tool did not exist.
              • picasso_86
                • Oct 2021
                • 10
                • Poland
                #47
                Probably it is not dificult, but programmer is prety expensive, there will a lot of searching of correct dumb, and I'm not sure of good reasult of those operations. I have to search some smarter than me, guy ho can do this in my country, and pay for it. Thx a lot for informations.
                • 69d0b913
                  • Mar 2018
                  • 146
                  • BR
                  #48
                  this tool was cheap, until they found out that only this way it would be possible to remove passwords from some notebook models, then it became expensive! There are other tools that are much more expensive than vertyanov like svod or rf809h. I just didn't buy it because there's very little need to have it, I don't have demands for a service like this, and the price I would charge to do this service wouldn't even be a third of what the tool costs.
                  • picasso_86
                    • Oct 2021
                    • 10
                    • Poland
                    #49
                    I was reading somewhere that You don't need pragrammer like this... Yo just can solder wires to correct pins and You can do with normal programator... All You need is schematics, and technical skils
                    • 69d0b913
                      • Mar 2018
                      • 146
                      • BR
                      #50
                      yes, it can also be done, but where would the pins be? I've never seen anyone post the pin to make this kind of flash in IO on notebooks.
                      • picasso_86
                        • Oct 2021
                        • 10
                        • Poland
                        #51
                        I saw... on this forum, also
                        for example on this subject mec 16xx dump with info block
                        • LenBios
                          • 122
                          • Ker
                          #52
                          Hi, post clear Fotos from MEC Chip + JTAG. Which programmer do you have?
                          • 69d0b913
                            • Mar 2018
                            • 146
                            • BR
                            #53
                            ch341 and tl866.. as soon as I'll post pictures of the machine's MEC chip. But I think the friend below can help before me at this point.
                            • LenBios
                              • 122
                              • Ker
                              #54
                              you can not use this programmer to read / write MEC
                              • 69d0b913
                                • Mar 2018
                                • 146
                                • BR
                                #55
                                these are what i have, but tell me which one you recommend.
                                • LenBios
                                  • 122
                                  • Ker
                                  #56
                                  vertyanov or RT809H works always for new Lenovos
                                  Vertyanov is easier no need to solder wires only remove 1 resistor, you can use Keyboard connector to read only eeprom area
                                  • 69d0b913
                                    • Mar 2018
                                    • 146
                                    • BR
                                    #57
                                    I don't have easy access, there is a "Vertyanov" that costs too much, and sending it to my country is not feasible. I could buy the rt809h but still also a very expensive machine by the way. We had already talked about Vertyanov but it is difficult to find one to buy.
                                    • picasso_86
                                      • Oct 2021
                                      • 10
                                      • Poland
                                      #58
                                      I write still active ebay link few posts before... Vertyanov costs 100$ + sending costs, so if You have some service, it will pay for itself quicly... I was searching somebady who can remove SVP for me in my coutry, and I found...but he want almost 130$ for this. Simpli mathematics... If I buy Vertyanov, it pay itself with first laptop which I will do...
                                      • picasso_86
                                        • Oct 2021
                                        • 10
                                        • Poland
                                        #59
                                        If I wil buy Vertyanov Can You help me with T14 removing SVP? Which resistor should I remove, and where is the pasword in dumb of KBC?
                                        • picasso_86
                                          • Oct 2021
                                          • 10
                                          • Poland
                                          #60
                                          b.t.w. I'm searching on this motherboard other chips simillar to bios and there is no other... There is only Winbond 25Q80DVSIG. When I check datasheet of this chip there is writed that it have only 1MB capacity... so how dump can have 32MB?? I try to read again and still have 1MB dump.
                                          • badzymandiaz
                                            Thinkpad P14s Gen 4, BIOS Supervisor Password
                                            by badzymandiaz
                                            I have a laptop that was purchased second-hand, and I am able to boot Windows on and extract the BIOS dump (ONLY the BIOS region, I was unable to dump anything else due to an FCERR I received trying to dump the other regions) and use normally. However, because the BIOS is locked with a supervisor password, I am unable to use anything else except for Windows, and it has also disabled some hardware features of the laptop itself, such as the fingerprinting module, etc. that I really do wish to use.
                                            I have been digging around for nearly 2 weeks trying to find any mention of the same model...
                                            09-28-2025, 10:49 AM
                                          • Andreasandreou
                                            Lenovo Thinkpad T14s GEN 4 Supervisor Password Bypass
                                            by Andreasandreou
                                            Hello, I have Lenovo Thinkpad T14s GEN 4 serial number GM-0FK2ER laptop. It was brought to me by a customer to reinstall windows. The problem is it is locked with a superviser password. Can anyone please give instructions on how to reset the bios or bypass the supervisor password? Thank you.
                                            09-02-2025, 09:45 AM
                                          • vijayppatel017
                                            Lenovo Thinkpad X13 Gen 6 BIOS Supervisor Password Remove
                                            by vijayppatel017
                                            i have Lenovo Thinkpad X13 gen 6. with supervisor password enable. anyone know how to remove it. as i am starting this thing first time so dont know. but i am good in solder.
                                            10-12-2025, 09:04 AM
                                          • Badpatch02
                                            Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                                            by Badpatch02
                                            Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                                            So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                                            I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                                            11-30-2024, 05:22 AM
                                          • AppleLover123
                                            Lenovo Yoga X380 22LH Supervisor Password removal
                                            by AppleLover123
                                            Hey guys,
                                            have a laptop here that has a supervisor Password (dump in Attachements).
                                            Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                            the laptop works but everytime it wants me to type a supervisor password i never set.
                                            I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                            Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                            04-17-2025, 03:42 PM
