Dell INspiron 3580 EDI54 LA-G712p rev 1.0(a00)
    Re: Dell INspiron 3580 EDI54 LA-G712p rev 1.0(a00)
    Originally posted by SMDFlea View Post
    The one at post #2 has clean ME FW. Theres more on the forum with clean ME FW , the same bios is used in these models: Inspiron 3480 3580 3583 3780 Vostro 3480 3580 3583.
    Try the attached bios, if it doesn`t work the problem is somewhere else.
    It doesn`t matter if the ME FW is a bit older,newer or exactly the same as long as its configured - clean.
    working fine. thanks
      Re: Dell Inspiron 3583
      its working thanx
        Re: Dell Inspiron 3580/3588 bios
        Originally posted by mcplslg123 View Post
        Your bios merged with dell webupdate. Try this file and post result.
        Hello, this BIOS is for the same board with pentium 5405u processor??
          Originally posted by shabi View Post
          no schematic or boardview LA-G721P available
          working 100%
          thankyou
            Hi all, Ive tried every bios in this thread with pretty much the same result. Laptop powers on no display, after maybe 10 secs the power light will go off but the laptop is still on. Pressing the power button again the fan spins up and after 5 secs the laptop shuts down. Pressing the D key will go through the LCD test cycle as it should. I've attached a copy of the original bios dump if any of you kind folk could take a quick look. TIA
              Try
              Become a Badcaps supporter
              Thanks to all supporters.
                Sorry for the late reply. Thank you for that but still nothing with that file it acts pretty much dead. But thank you again
                  Good afternoon, this is my bios, there is no start with it, please help
                    Vostro 3580
                    Service Tag: 7QPG5Z2
                      Originally posted by hoaca388 View Post
                      Vostro 3580
                      no, my service tag is 45G9JZ2
                        No service tag yet. You have to add it yourself.
                          thanks it's working
                            its a new file
                            ok 100%
                            thnks
                              Hi I have a Inspiron 3583 that has a password on the HD, rewriting the bios removes this password? the code is #XS1E687ZFLK-E7A8
                                FzGmNMrkk9Qs2Zyy
                                or
                                WGqQxZPyZz2ZyZ22
                                  FzGmNMrkk9Qs2Zyy
                                  or
                                  WGqQxZPyZz2ZyZ22
                                  Don't worked
                                    @Juniopms
                                    Can you describe the procedure that you performed? For the HDD I do it this way, I type the master password, then press and hold down CTRL key while I press ENTER key just once (CTRL-ENTER), I then read screen messages and if there isn't any confirmation prompt to Secure Erase the hard drive, then I press CTRL-ENTER a second time.
                                    If you do CTRL-ENTER-ENTER quick you may miss that Secure Erase prompt asking for confirmation.
                                      Originally posted by AAAC View Post
                                      @Juniopms
                                      I tried but show "Invalid Password, try again" on 2 passwords
                                        its taking tooooo long to display
                                        attached is backup
                                        any help i will appreciate
                                          attached is backup
                                          Have you attempted to clean the ME firmware,it should the slow boot
                                          https://www.badcaps.net/forum/showpo...41&postcount=3
