help unlock passbios unowhy Y13G010S4EI
  • MOHDZGSM
    • Feb 2023
    • 11
    • zoui ouled rechache
    #121
    Re: help unlock passbios unowhy
    im trayng to unlock this bios lock but im not sur about this ?
    Y13G011S4EI EM_IG116_200B_ENE_F_V2.0
    Y13G010S4EI EM_IG116_200B_ENE_F_V2.0
    • volinakis
      • Jan 2021
      • 2749
      • N/A
      #122
      Re: help unlock passbios unowhy Y13G010S4EI
      there's no risk since you save the content of bios chipset. you can write it back and laptop should work as before.
      • MOHDZGSM
        • Feb 2023
        • 11
        #123
        but there is a deference between this?
        and this my laptop here : Y13G011S4EI EM_IG116_200B_ENE_F_V2.0
        Last edited by SMDFlea; 10-15-2023, 09:40 AM. Reason: posted external images directly to badcaps
        • Phil94
          • Jan 2023
          • 7
          • France
          #124
          [QUOTE=volinakis;1270528]
          Originally posted by Phil94
          Your bios dump is corrupted. Read it again and compare new dump against old saved dump.
          Dear Volikanis ,
          Here is the file.bin ,
          Could you help about this
          Unock password and communicate the new one ?
          • volinakis
            • Jan 2021
            • 2749
            • N/A
            #125
            [QUOTE=Phil94;1283198]
            Dear Volikanis ,
            try. you owe me a lamb
            • Phil94
              • Jan 2023
              • 7
              • France
              #126
              [QUOTE=volinakis;1283219]
              Dear Volinaskis the lamb will wait,
              I don't know what to put for the bios password and finally access the machine
              Could you check , it seems the same original situation
              • volinakis
                • Jan 2021
                • 2749
                • N/A
                #127
                [QUOTE=Phil94;1288531]
                2 lambs, maybe 3rd time is a charm try Volinakis ...
                it should work, I erased all areas where passwords were. did you remove cmos battery before soldering bios?
                • Phil94
                  • Jan 2023
                  • 7
                  • France
                  #128
                  [QUOTE=volinakis;1288534]
                  The issue is we don't have battery cmos on this motherboard , see the pictures below ,
                  Which advice do you have for me in this case ?
                  • farouk_1994
                    • Mar 2021
                    • 393
                    • algeria
                    #129
                    [QUOTE=Phil94;1289049]
                    Try this file and feedback
                    • tamilnilan
                      • Dec 2018
                      • 16
                      • France
                      #130
                      please unlock pass bios!
                      • farouk_1994
                        • Mar 2021
                        • 393
                        • algeria
                        #131
                        Post your dump and serial number and MB number here
                        • tamilnilan
                          • Dec 2018
                          • 16
                          • France
                          #132
                          Em-ig116-200b-ene-v1.0
                          • tamilnilan
                            • Dec 2018
                            • 16
                            • France
                            #133
                            Em-ig116-366b-v2.0
                            • farouk_1994
                              • Mar 2021
                              • 393
                              • algeria
                              #134
                              try this file than tell the result
                              • tamilnilan
                                • Dec 2018
                                • 16
                                • France
                                #135
                                no vga?
                                • Phil94
                                  • Jan 2023
                                  • 7
                                  • France
                                  #136
                                  [QUOTE=farouk_1994;1289054]
                                  No working ....
                                  Is normal we have a difference on Address of the eeprom (left colum) on your program compare me ?
                                  AMISETup (ASCII) is >> 22DB8C
                                  AMISETup (ASCII) is >> 22DB90
                                  I just searched on the flash that I did ans as you can see above it is quite empty on the friendsetup .... ?
                                  But when I start the unowhy and validate empty field , it's still ''invalid password ''
                                  Are there a 2nd password on the main menu of BIOS on this laptop ?
                                  Here is a copy of the BIOS , I think is the real model on my interface Xgpro with device T48
                                  What to do now ?
                                  • casti3l
                                    • Mar 2014
                                    • 95
                                    • romania
                                    #137
                                    Hello, can someone help me with a working bios for UNOWHY Y13G012S4EI - MODEL JUNE 2022 (Classe 2MRC1) SN: IFP223091322 EM-IG116-200B-ENE-TI-v1.0. I will attach the bios but it's corrupted . I tried multiples versions but with no luck. Thank you
                                    • portier11
                                      • Dec 2023
                                      • FRANCE
                                      #138
                                      Hello
                                      help pleas unclock pass bios unowhy Y13G012S4EI
                                      impossible restaur windows because not admin
                                      I can no longer work with my pc
                                      thanks you very mutch
                                      • fayal
                                        • Jan 2015
                                        • 14
                                        • uk
                                        #139
                                        hi please need unlock bios thanks
                                      • fayal
                                        • Jan 2015
                                        • 14
                                        • uk
                                        #140
                                        N :IFP047056938
                                        MODEL:Y13G010S4EI
                                        motherboard EM IG116_366B_ENE_V2;0
