Hp 450 g6
  • motanya
    • Nov 2021
    • 158
    • Kenya
    #41
    Re: Hp 450 g6
    Somebody help me with the bios file for 450 G6 with Nvidia graphics, for some reason the current chip has no data at all, seems like someone tried to program it. I have tried the ones available here powers on but no display the gpu remains cold
    • hardware1
      • Sep 2021
      • 2912
      • N/A
      #42
      Re: Hp 450 g6
      Write your device Serial Number and Upload your Backup here, we will see and tell you if it's the Original BIOS or not.
      all donations are welcome,
      • motanya
        • Nov 2021
        • 158
        • Kenya
        #43
        Re: Hp 450 g6
        Thanks @hardware1, however, as mentioned above, I tried to read from the chip that came with the laptop, there was no data in it if you read it saves nothing so I guess the chip was erased or something of the sort.
        If you are able to help without the original backup, kindly do. Here is the S/N: 5CD052QLVX on the cover.
        • hardware1
          • Sep 2021
          • 2912
          • N/A
          #44
          Re: Hp 450 g6
          As you can see from the Image, this Serial Number belongs to (HP ProBook 455 G7) not (HP ProBook 450 G6).
          HP ProBook 455 G7 should have (AMD Ryzen 5 4500U CPU), HP ProBook 450 G6 should have (Intel 8th Gen CPU). Which one of those CPUs you have?
          • motanya
            • Nov 2021
            • 158
            • Kenya
            #45
            Re: Hp 450 g6
            I am sorry brother for that I had two of them opened, I mixed up, here is the correct serial number 5CD109J72L. But, this is interesting and I had not noticed that, the code written on the motherboard returns it is an hp 450 g6, but the serial number above and back cover model is written as 450 g7.
            I have attached everything if this will help give a clue. Thank you.
            • hardware1
              • Sep 2021
              • 2912
              • N/A
              #46
              Re: Hp 450 g6
              Motherboard can be used for more than one Model, but I don't think this Motherboard is for 450 G7. (Maybe someone changed the Cover)
              Anyway, I will give you 2 BIOSs for (450 G6 & 450 G7 to try them).
              • motanya
                • Nov 2021
                • 158
                • Kenya
                #47
                Re: Hp 450 g6
                Thank you, will let you know
                • motanya
                  • Nov 2021
                  • 158
                  • Kenya
                  #48
                  Re: Hp 450 g6
                  Unfortunately, none works.
                  • andy999
                    • Jan 2021
                    • 23
                    • Ukraine
                    #49
                    Re: Hp 450 g6 need clean plzzz
                    Here's your New bios file, try it and let me know the results.
                    thank you very much
                    • hardware1
                      • Sep 2021
                      • 2912
                      • N/A
                      #50
                      Originally posted by andy999
                      thank you very much
                      Good to know, You're Welcome.
                      • andy999
                        • Jan 2021
                        • 23
                        • Ukraine
                        #51
                        Re: Hp 450 g6
                        hello
                        please help to modify hp450g6 bios file
                        I have got hp 450 g6 without bios chip on board
                        the new bios I found worked fine but I have few caps lock blinking before start
                        bios updates ok
                        many thanks
                        • hardware1
                          • Sep 2021
                          • 2912
                          • N/A
                          #52
                          Re: Hp 450 g6
                          hello
                          bios updates ok
                          many thanks
                          Why you didn't try the file in Post #29? I think it was for your another device and you replied to me in Post #49.
                          • andy999
                            • Jan 2021
                            • 23
                            • Ukraine
                            #53
                            Re: Hp 450 g6
                            hello
                            it`s 2nd laptop / that bios file isnt working here
                            thanks
                            • mhmed2090
                              • May 2017
                              • 33
                              • alex
                              #54
                              Re: Hp 450 g6
                              this one HP ProBook 450 G6 (R71) (V_1.22).rar
                              working for x8j-8l thanks
                              • an_kiwi
                                • Oct 2023
                                • 15
                                • New Zealand
                                #55
                                Re: Hp 450 g6
                                Guys, forgive my illiteracy, I see so many replies with the BIN files for HP Probook450 g6 DAX8JMB16E0
                                I currently need that unlocked working original BIOS for my laptop. Could you kindly reply with the file? Thanks heaps!
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11398
                                  • Viet Nam
                                  #56
                                  Re: Hp 450 g6
                                  Post backup bios and serial number.
                                  • an_kiwi
                                    • Oct 2023
                                    • 15
                                    • New Zealand
                                    #57
                                    Re: Hp 450 g6
                                    I haven't got the BIOS dump unfortunately.
                                    S/N: 5CD85O52QG
                                    I am trying to revive a dead laptop. Currently all signs point at corrupted BIOS
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11398
                                      • Viet Nam
                                      #58
                                      Re: Hp 450 g6
                                      S/N: 5CD85O52QG
                                      Try #2
                                      • an_kiwi
                                        • Oct 2023
                                        • 15
                                        • New Zealand
                                        #59
                                        Re: Hp 450 g6
                                        even though it is for da0x8jmb8e0 rev:E not for DAX8JMB16E0 rev:E ?
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11398
                                          • Viet Nam
                                          #60
                                          Re: Hp 450 g6
                                          There is only one bios version for Probook 450 G6 which is R71.
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
                                            HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-06-2024, 10:51 AM
