Lenovo IdeaPad 3 15ADA05
Originally posted by hoaca388 View Post
IdeaPad 3-14ADA05 Laptop - Type 81W0
tnx in advance i already change nvme the one that good working same
Originally posted by nickojean22 View Posthello can anyone help me blinking power led this is my backup bios
this is the info of the laptop
PF2BFQTV
tnks in advance
PF2BFQTV
tnks in advanceAttached Files
Originally posted by Nicolas Tizzano View Post
Just for refresh my problem...
The computer starts with Blue Screen Error... Client sends me a pic showing the Recovery instance with error code 0xc0000001
When I get it...........
Namaste!
I reach the goal and fix the computer... The SSD m.2 was corrupt... and for that i couldn't enter BIOS normaly. But with other m.2 it works fine!
So... if you have same problem, just change m.2
Please, see all my post to understand whats happened to me.
Thanks again for all of you who bring help without wanted nothing.
Originally posted by EpicFix View PostHi, I need a BIOS file for Lenovo 15ADA05. The machine turns on without video, there is fan spin all voltages are present (3.3v, 5v, 19v) and the power button LED keeps flashing. It powered on once and gave TPM error message. I've tried the Novo button and disconnected CMOS to reset but to no avail. I suspect the issue is the on board RAM so if anyone can also provide me with a BIOS that has the on-board RAM disabled for troubleshooting as well I will also be gladly appreciative. Attached is a dump I was able to pull off the BIOS as required. Thanks in advance.
IdeaPad 3 15ADA05.
PN: 5B20S44266 (Not sure if this is the board serial number but this is what I got from the sticker on the RAM slot)
Model: GS550
https://www.badcaps.net/forum/troubl...11#post3237947
IdeaPad 3 15ADA05.
Model: GS550Attached Files
Originally posted by volinakis View Post
there is a hole on the side of laptop, pressing on the switch inside that hole you'll be able to enter in bios setup, take from there serial no
I already try that, even i explain all in post 194
All serial numbers that i have is from the webpage wich sends me the QR code from laptop label. Pictures attached in post 193
The NOVO button that you means does not work, when I select BIOS option, it does not get in BIOS, just go ahead loading OS, and stuck there.
I will try with another M.2 SSD just to see what's happening...
So... i could never go to BIOS... thats why i think there is a problem and wanted to test with another BIOS.... I don't know if there is any keyboard combination to Activate something which let me in BIOS.
I don't think that another thing is wrong... even i can't take out RAM couse they are SMD and soldered.
Thanks anyone for your help!! I hope this case could help others!
Namaste!
Woow QR works and tell me wich computer ir... because there is no label just the ones in attached photo.
This computer is a IdeaPad 3 14ADA05 81W0 PN: PF2PRW41 MTM: 81W000MUAR
With AMD Ryzen 3 3250U and DDR4 4GB
Just for understand, why is important this numbers?? I really like to understand that... thanks for any kind of support!!
PD: my client was so awful taking care this computer... like you see in inside back plate.
When I get it, i looked inside and saw that i was full of dirt. So i cleaned it.
Then I try turning on, and it allway get stuck "Loading Windows" in LENOVO Logo stage.
So i wanted to see BIOS, and pressing F2 or FN+F2, nothing happends, just LENOVO Logo without any loading, gettin stucked.
Looking for internet it says that this notebook comes with NOVO Button... i pushed it, MenĂº appear, but i have the same problem... BIOS is not working, just the LENOVO Logo. When I try another option, is the same... just goes to LENOVO Logo and get stucked there.
When I take off SSD m.2 the computer says:
"Verifiying shim SBAT data failed: Security Policy Violation
Somthing has gone seriusly wrong: SBAT self-check failed: Security Policy Violation"
So I realise that there is SecureBoot ON.
Namaste!
Originally posted by peste View Post
Look for a label on the laptop case.
Originally posted by borgesbe View Post
I'm sorry but i didn't follow... Soyo SY-7VBA133U points to another user asking for correct bios, do you reffer to DMI copy ? from what i have been reading DMI doesn't male power led blinking but windows uefi key and other issues right ?
Edit: i think i got the problem, when i write BIOS and next when i read it results are the same. I am using clip and i think i will need 1.8v adapteur am i right ?
I attach datasheet.
You have to see first which voltaje is working... may be chip could works with other voltages but better use the intended for. Even you can test 8 pin for seeing voltage from the board.
Hope could be helpful!Attached Files
