Lenovo IdeaPad 3 15ADA05
https://www.badcaps.net/donate -
gs450&gs550&gs750 nm-c821 EC Bios bin
AMD % 100 okAttached Filesif you find these attachements useful please consider making a small donation to the site
model 81W1
SN PF236DLK
mtm 81W100KHSP
Hello, I've tried to find it by dumping different BIOSes that you provide, reading several posts without success. The laptop stayed with a black screen after updating the BIOS and it remains like that... I would appreciate it if you could help me please.Attached Filesif you find these attachements useful please consider making a small donation to the site
New biosLenovo IdeaPad 3 15ADA05
model 81W1
SN PF236DLK
mtm 81W100KHSP
https://www.badcaps.net/donateComment
Hello, these BIOSes are 100% compatible with AMD CPUs. This means you have a different issue.Lenovo IdeaPad 3 15ADA05
model 81W1
SN PF236DLK
mtm 81W100KHSP
You can try these steps.
1- Try using an external monitor.
2- Shine a bright light on the screen and see if there's any image on the screen. This could be a backlight issue.
3- If you have a graphics card, the problem could be related to that.
4- If you have an SVOD 4 programmer, program the IO EC. I have the EC BIOS in my post. You can download it from there.
5- Test the LVDS EDP cable connected to the display.
6- Remove the battery and adapter and hold down Ctrl+Alt+Esc for 15 seconds. Then hold down the Power button for 15 seconds. Then, swap the RAM. Then, reconnect the adapter and try turning it on. It should probably display.Comment
Hello! By the way, thanks for your help. Nothing, none of the options you told me about worked, always a black screen. I was sure it was a BIOS problem because it happened when I was updating, on the first reboot it started updating the BIOS and completed it, rebooted again and verified with 4 or 5 lines all ok, and when it rebooted again it was left with a black screen... but if you tell me that the BIOS that hoaca388 gives me has to work, I don't know what to do anymore... I'm dumping the BIOS with asprogramer-dregmod-v3.17 selecting the W25Q64JW-IQ_1.8V chip (WINBOND) through a CH341A programmer, connecting the 1.8V adapter to the programmer and the BIOS chip to the adapter. In case I'm doing something wrong... although it doesn't give me errors either when I dump the BIOS or when verifying. ThanksComment
try post #14...Hello! By the way, thanks for your help. Nothing, none of the options you told me about worked, always a black screen. I was sure it was a BIOS problem because it happened when I was updating, on the first reboot it started updating the BIOS and completed it, rebooted again and verified with 4 or 5 lines all ok, and when it rebooted again it was left with a black screen... but if you tell me that the BIOS that hoaca388 gives me has to work, I don't know what to do anymore... I'm dumping the BIOS with asprogramer-dregmod-v3.17 selecting the W25Q64JW-IQ_1.8V chip (WINBOND) through a CH341A programmer, connecting the 1.8V adapter to the programmer and the BIOS chip to the adapter. In case I'm doing something wrong... although it doesn't give me errors either when I dump the BIOS or when verifying. Thanks
https://www.badcaps.net/forum/troubl...ed#post3718145Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hello. The "NM-C821 DUMP" post on the site shows a corrupted picture and then remains black, but it won't open again. Attached is the E8CN18WW picture. I downloaded the bios from another site and changed it to E8CN28WW. The picture improved, but it booted once and then wouldn't boot again. Then I found this thread and did as instructed, but no picture appeared. Attached are the files. Did I make a mistake?
(There is no picture in my original bios backup) There is no label on the case. When I opened the BIOS from the website (by copying the DMI), I wrote down the serial numbers in the attached picture.
Lenovo IdeaPad 3-15ADA05 bios bricked
Lenovo IdeaPad 3-15ADA05 type ???
motherboard: GS450&GS550&GS750 NM-C821 Rev: 1.0
sn:PF1VKM0F
mo: PF9XB2507005
mtm: 81W1005VTX
No display. Please repair bios + DMI
I hope this topic is in the right place.Attached Filesif you find these attachements useful please consider making a small donation to the site
you have everything you need at post #29...Hello. The "NM-C821 DUMP" post on the site shows a corrupted picture and then remains black, but it won't open again. Attached is the E8CN18WW picture. I downloaded the bios from another site and changed it to E8CN28WW. The picture improved, but it booted once and then wouldn't boot again. Then I found this thread and did as instructed, but no picture appeared. Attached are the files. Did I make a mistake?
sn:PF1VKM0F
mo: PF9XB2507005
mtm: 81W1005VTX
I hope this topic is in the right place.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Message #29 is black screen and never opens. Can you check my previous message and attachments? How do I find the correct bios? (My bios header section is full)
Also, the bios in message number 29 is attached. I made a DMI transfer.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks for your reply. Yes, the processor is AMD, but the steps in post 287 didn't work for me. Post 283 has two ECs, but no main BIOS. Can you reload the main BIOS?Comment
Everything you need is here.
Please report your results here.Attached Filesif you find these attachements useful please consider making a small donation to the site
Unfortunately, the display came back once and never came back. The power button is constantly flashing.
I've tried about 15 BIOS updates, some won't boot at all, and some only boot once. I'll CPU reball and return it customer.Comment
This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by joven016Problem is blinking power led only
i don't know exactly if it's s145-15igm or s145-14igm
have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
Already tested some of posted bios here
S145-14igm - success but invalid serial and not booting on OS
S145-15igm - success with serial and some other info in bios but still not booting on OS
already tried installing new windows but always booting on bios setup
windows installer flash drive detected on...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
- Loading...
