Lenovo G50-70 gigadevice 25b64bsig
  • speggio91
    • Apr 2020
    • 83
    • Italy
    i'm trying to fix this laptop with this bios chip. The problem is that it turn on with just one led on. It's not displaying anything and I believe it's the bios corrupted.
    I have a Ch341a chip programmer and I downloaded a valid bios image from this forum. I can't flash the new bios with any programmer software, i've tried with neoprogrammer and asprogrammer, none of them let me write the bios image. The stock programmer when it's verifyng the new image, an error pop up saying: "Chip Main Memory with the content are in disagreement".
    Is there anyone that had experience with this bios chip? Any program that could work?
  • speggio91
    • Apr 2020
    • 83
    • Italy
    Re: Lenovo G50-70 gigadevice 25b64bsig
    I attach the original bios I dumped from the motherboard. The model is: ACLU/ACLU2 NM A271 Rev 1.0
    • peste
      • 12244
      • ROMANIA
      try..
      • speggio91
        • Apr 2020
        • 83
        • Italy
        Originally posted by peste
        try..
        Thank you for helping but the programmer software still give me the error when trying to verify the chip.
        The message is the same: "Buffer data does not match SPI chip".
        Every programmer I used to flash the bios gave me that error and in the chip database there's not my chip.
        Is there a software with that chip in the database? I did read that Skygz can give you a paid version of the standard software by contacting him. I didn't receive any answer so far.
        Thank you anyways, i'll update this thread in case there are any news.
        • peste
          • 12244
          • ROMANIA
          remove the bios chip from the motherboard before reading or writing and stick it on the programmer if you do not have an adapter ... set the name of the bios chip correctly in the program..maybe the programmer is defective ..
          • speggio91
            • Apr 2020
            • 83
            • Italy
            I did desoldered the chip and soldered it on the board I receive with the programmer, checking also the correct pin orientation.
            The problem is that my programmer software doesn't have in its database that chip. It has something similar like GD25Q64 but it doesn't work, it give me the error i already mentioned.
            Yesterday i tried to manually add the chip on neoprogrammer import.xml file.
            Under SPI_Eprom category I added this line:
            Code:
            <GIGADEVICE>
             <GD25B64BSIG vcc="3.6" id="C84017" page="256" size="8388608"/>
                  </GIGADEVICE>
            Those data i inserted was found on another forum, but it's not working either, the verification phase terminate with an error and roughly 10%.
            Maybe there are some more details to add about that chip..
            • speggio91
              • Apr 2020
              • 83
              • Italy
              Hi again,
              after some weeks i managed to retrieve a good programmer, it's the Tl866II plus, the original one, not a clone, directly purchased from an authorised dealer.
              I managed to successfully flash the bios sent by peste some posts ago.
              After trying to power on the board the power consumption goes up to 0.55A, the cpu start to get warm rather hot, and after 3 seconds it shut down after hearing a very flimsy "click" sound.
              During the 3 seconds, the display does turn on for a while meaning the backlight is working but there's no image at the display.
              What could be the issue? Is still the bios fault or is there the super IO that is shutting everything down due to an anomaly?
              Should i open a new thread on the repair forum?
              Thank you very much
              • rubenvidalflores
                • Jan 2023
                • 5
                • PerĂº
                Hi again,
                Thank you very much
                Hello, were you able to solve it? The same thing happens to me, only the camera lights up and the device turns off after 3 seconds
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • grimacelord
                  by grimacelord
                  Hello there.
                  History:
                  03-15-2023, 03:29 PM
                • jendkkd jeje
                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                  by jendkkd jeje
                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                  10-11-2024, 03:12 PM
                • mximiliandz
                  help bios lenovo ideapad s145-14iil type 81w6
                  by mximiliandz
                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                  Yesterday, 06:50 AM
                • 1g0r
                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                  by 1g0r
                  First, the data in brief:
                  Manufacturer: Lenovo
                  Model: ThinkPad L15 G3 21C3-0016GE
                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                  IC Bios 1: MX77L25650F
                  IC Bios 2​: MX25L25673G
                  EC Chip: NPCX997KAABX
                  So far I've been a silent reader, but now I need your help
                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                  01-18-2025, 02:39 AM
