Lenovo E590 no boot
  • regi
    • Jan 2020
    • 26
    • germany
    Lenovo E590 no boot
    Hi all.
    i need some help.
    My Boss gave me a brand new never used Lenovo E590 that was lying around for a year or 2.
    I unboxed it and it won´t boot, the power led flashes a few times and then it switches off.
    I opened the laptop, disconnected the battery and the bios battery, shorted the pins of bios battery and put all together again.....still no boot.
    The notebook is out of warranty and so i flashed the bios with the dump from another E590. Laptop now boots but shows error message:
    0271: Check Date and Time settings.
    0183: Bad CRC of Security Settings in EFI variable.
    Press F1 to enter Setup.
    When I press "Enter" the bios wants a password that has never been set.
    Before flashing i made a dump of the Original defective bios, just in case.
    How can I get this running again?
    thanks for any help
    regards
    regi
  • regi
    • Jan 2020
    • 26
    • germany
    Re: Lenovo E590 no boot
    nobody here who has an idea how to fix the bios?
    • Mazorca
      • Jan 2017
      • 463
      Post the bios that has the password, I'll see if I can patch it for you. Or you can patch it yourself, look here: https://www.badcaps.net/forum/showthread.php?t=87588
      • regi
        • Jan 2020
        • 26
        • germany
        thank you so much
        here ist the file
        • Mazorca
          • Jan 2017
          • 463
          Try this and report back, follow instructions, don't dispair if you get beeps, try resoldering or making a good connection.
          • Mazorca
            • Jan 2017
            • 463
            I forgot to add in the instructions, look for any switches, they must be pressed when doing the unlock. Usually they are pressed when the backplate or bottom cover is on, so if you just put the cover back, you are good to go.
            • regi
              • Jan 2020
              • 26
              • germany
              ok, i´ll give it a try this afternoon.
              thank you very much
              • regi
                • Jan 2020
                • 26
                • germany
                ok, that doesn´t work.
                when i power on i get no picture, only a sound with changing frequencies and thats it.
                forgotten: with back cover on and off
                • AAAC
                  • Jan 2020
                  • 459
                  • Mexico
                  @regi
                  first things first... Which programmer model do you use?
                  I've checked this ThinkPad E590 bios and although it's a 9th Generation model, seems it can be patched as in the 4th to 8th Generation ThinkPad models.
                  • regi
                    • Jan 2020
                    • 26
                    • germany
                    i have a ch341a black edition, with this programmer i wrote the bios as mentioned in my first post but at boot it wanted a password which was never set. the programmer seems to work.......i think
                    • Antonynl
                      • Apr 2021
                      • 74
                      • Nederland
                      is there such a swicth inthe E590 mobo?
                      I looked but can't see any of them: mind you they can be very tiny
                      • logobg
                        • Jan 2022
                        • 5
                        • Austria
                        Hi, do you have a solution with this one? I have done (bad) flash on my e590 and it stopped(Waited 1 hour but never finished the flash). I turned the laptop off and now I have the 0285 (TCG error) sound. With CH341 black and NeoProgrammer V2.2.0.8 I dumped my bios, tried to flash another bios from internet (no success) and returned to my original bad bios dump.. Please can you help?...
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12441
                          What is your machine type ? ThinkPad E590 (Machine types: 20NB, 20NC) ?
                          • logobg
                            • Jan 2022
                            • 5
                            • Austria
                            Thank you for the quick reply! It is 20NB-005HGE
                            MB:
                            FE490/FE590/FE480 NM-B911
                            Rev:2.0
                            2019-01-17
                            Vendor:HSB
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12441
                              thank you for the quick reply! It is 20nb-005hge
                              mb:
                              Fe490/fe590/fe480 nm-b911
                              rev:2.0
                              2019-01-17
                              vendor:hsb
                              • logobg
                                • Jan 2022
                                • 5
                                • Austria
                                This is it!!!! It worked!!! THANK YOU VERY VERY VERY MUTCH!!!!!!!!!!!!
                                I tried so many thins for days and didn't worked. If it is not to much to ask, can you teach me a little if this happen in the future, what can i do to do it myself? Tank you once again!!!
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12441
                                  I have consulted how to do it from many video sources on youtube in both Vietnamese and foreign languages, so I don't know where the instructions are. The keyword I set is: “How to extract bios .bin file from .exe file". Also learn about decimal, binary and hexadecimal strings.
                                  • logobg
                                    • Jan 2022
                                    • 5
                                    • Austria
                                    Ok I'll check this! Thank you again!
                                    • zmezm1995`
                                      • Nov 2020
                                      • 99
                                      • iraq
                                      i need bios for laptop lenovo thinkbad e590
                                      i need bios for laptop lenovo thinkbad e590 to solve this problem and this my dump plz help
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12441
                                        Re: i need bios for laptop lenovo thinkbad e590
                                        Your serial number ?
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • Max029
                                          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                                          by Max029
                                          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                                          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                                          TY,
                                          08-18-2024, 08:28 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • gestalt.exe
                                          Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
                                          by gestalt.exe
                                          My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
                                          Laptop stopped booting entirely.
                                          I used a CH341A programmer to dump the corrupted 16MB BIOS.
                                          i then attempted the following:
                                          1. Downloaded stock BIOS BHCN39WW from Lenovo
                                          2. Trimmed it to 16MB
                                          3. Extracted the BIOS region from the corrupted dump
                                          4. Extracted the BIOS region from the stock 39WW
                                          5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
                                          6. Injected back my LDGB / DMI
                                          11-30-2025, 10:38 AM
