need working bin of Asus FX95G_fx505gt rev 2.0
  • balobi
    • Jan 2015
    • 88
    • phillippines
    badly need working files of Asus FX95G_FX505GT rev 2.0 I7 9th gen or can help me clean ME region or repaire the file. thanks!
    orig files attached is No Display.
  • Mazorca
    • Jan 2017
    • 463
    Re: need working bin of Asus FX95G_fx505gt rev 2.0
    Me Analyzer gives error:
    Error: Detected incomplete firmware size 0x800000, expected 0x1000000!
    Warning: Firmware size exceeds Engine/Graphics region, possible data loss!
    Note: Adjusted buffer to Flash Descriptor 0x0 - 0x1000000!
    Did you get at least two readings and compare them?
    • balobi
      • Jan 2015
      • 88
      • phillippines
      kindly try this another back up file.
      • Mazorca
        • Jan 2017
        • 463
        Try this one, with ME from repositories and BIOS region from ASUS update.
        • balobi
          • Jan 2015
          • 88
          • phillippines
          many thanks! Mazorca, your file clean me works.
          but there's another problem. display suddenly goes off and the machine is still have power. i try turn off and on again it has 0.17amps on my DC bench and intel chips heat up. what could be posible problem?
          • Mazorca
            • Jan 2017
            • 463
            Sorry, that is ouside my experience, disconnect all peripherials and check voltages again. Yesterday I had a laptop with a 4gb pc3L ram stick, it would start once, give video but then went off and in a start/stop loop, never give video again unless disconnected/connected again, same loop. RAM stick exchanged, problem solved. Good luck.
