hp stream 11-ak0500sa (da0y0qmbc0 rev c) bios
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    please i need hp stream 11-ak0500sa (da0y0qmbc0 rev c) bios file. and attached the dump and picture please if it can repaired for me
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    Re: hp stream 11-ak0500sa (da0y0qmbc0 rev c) bios
    i need help
    • peste
      • Dec 2016
      • 13728
      • ROMANIA
      i need help
      bios extracted from the HP site update, the laptop has two variants of your bios is 085B5
      DMI 3C7000-3C70FF
      KEYWIN 3C5000-3C503F
      • jacospama
        • Aug 2019
        • 240
        • Ghana
        DMI 3C7000-3C70FF
        thank you Senior. am gonna try i will give you the feed back
        • psicobra
          • May 2022
          • 8
          DMI 3C7000-3C70FF
          thank you for this brough my dead HP back to life.
          PSI
          • psicobra
            • May 2022
            • 8
            problems copying data from old bios to new one da0y0qmbc0
            Hi guys i'm very new to this so i apologise in advance for the stupid questions that will follow.
            i have a HP stream that would power on but display a black screen back light would kick in but that's about it.
            I guessed the bios was corrupt so de-soldered it off the board put in the bios programmer i have found the bios on here for it flashed it and hey presto the laptop booted perfectly. how ever i had an error as expected about it being in a manufacturer program is in unlock mode.
            i tried to copy the region data from the old bios to the new one but it wont write the new bios file i get this error "function called with invalid parameter"
            i was wondering if it is anything to do with the error i get when opening the old bios file i saved from the chip it is as follows.
            "parseRawArea: one of volumes inside overlaps the end of data" and this
            "checkTeImageBase: TE image base is neither zero, nor original, nor adjusted, nor top-swapped"
            thanks for any and all help.
            PSI
            • hoaca388
              Badcaps
              • Jan 2022
              • 12406
              Re: problems copying data from old bios to new one
              Attach your bios here ?
              • psicobra
                • May 2022
                • 8
                that's a good idea lol... i have attached them thanks.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12406
                  HP Stream - 11-ak0502sa
                  • psicobra
                    • May 2022
                    • 8
                    hi is this the bios with all the information added? if so thanks really appreciated but can i ask what you did different to me it's something i feel i really should learn how to do thanks.
                    PSI
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12406
                      PSI
                      My file had DMI added, yours didn't.
                      • psicobra
                        • May 2022
                        • 8
                        thanks.... what's DMI??? lol i did mention this is my first time doing this.
                        PSI
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12406
                          PSI
                          A small example
                          That's why the original bios is always backed up and required to be attached.
                          • tyso
                            • Dec 2018
                            • 3
                            • kenya
                            please i need hp stream bios file
                            board n0 day0qmb16a0 rev a
                            • peste
                              • Dec 2016
                              • 13728
                              • ROMANIA
                              read..
                              • PacoGT
                                • Sep 2022
                                • 114
                                • Guatemala
                                hello can repair my bios file?
                                heres the serial 5CD052BQC1
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12406
                                  HP Stream - 11-ak0012dx
                                  • PacoGT
                                    • Sep 2022
                                    • 114
                                    • Guatemala
                                    blink 3-2 th capslock
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12406
                                      Find hardware problem
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • cr4zychriss
                                        by cr4zychriss
                                        • Rebrand: PC Specialist
                                        Today, 04:04 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
