K55vd fan fast spininnig please help
  • bilen
    • Aug 2014
    • 632
    • istanbul
    motherboard code : k55vd rev 3.1 nvidia 610m gpu
    fan spining fast . working dump :
    please help me
  • lapfix
    • Mar 2020
    • 2714
    • my workshop
    Re: K55vd fan fast spininnig please help
    Try
    • bilen
      • Aug 2014
      • 632
      • istanbul
      Originally posted by lapfix
      Try
      the problem continues
        • 20656
        Post a good clear readable picture of the white/green sticker on the motherboard. Usually its on or around the RAM socket .
        • bilen
          • Aug 2014
          • 632
          • istanbul
          here
            • 20656
            Try - https://www.badcaps.net/forum/showthread.php?t=83607
            • bilen
              • Aug 2014
              • 632
              • istanbul
              I've tried. the problem is the same
                • 20656
                try this one.If it doesn`t work this time the problem is somewhere else.
                • cook
                  HP Power Supply 6632A: Fast Mode vs Normal Mode?
                  by cook
                  FAST MODE vs NORMAL MODE
                  I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                  I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                  06-07-2020, 05:32 AM
                • SevenOFF
                  Denon AVR-X4000 – Fast red blinking after 2nd relay
                  by SevenOFF
                  I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
                  According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
                  Here’s what I’ve done so far:
                  • Fully opened and cleaned the unit (a lot of dust inside)
                  • Removed and visually inspected the AMP board → nothing visibly damaged or burned
                  • Testing is done with
                  06-18-2025, 09:54 PM
                  TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                  FF Series (Very Fast Acting), 0603 Size
                  Features
                  ● Very fast acting at 200% overload current levels
                  ● Low DCR
                  ● High inrush current withstanding capability
                  ● Fiberglass enforced epoxy fuse body
                  ● Copper termination with nickel and tin plating
                  ● Halogen free, RoHS compliance and lead-free
                  Applications
                  ● Notebook computers and tablets
                  ● Digital cameras
                  ● Memory cards
                  ● Toys
                  ● Bluetooth earphones
                  ● Portable electronic devices​...
                  10-07-2024, 05:50 AM
                • paparazzo79
                  fast charging vs normal charging cellphone,damaging battery?
                  by paparazzo79
                  Hi friends.
                  I see there are many clever people here.
                  I purchased used Note 10 plus phone,and it doesn't have good battery cuz it's been used probably more then a year.
                  Since I'm not an expert into phones but my own thought is that fast charging with high current wears out battery more quickly and damages cells compared to regular charging.
                  I don't need fast charging at all so I disabled that option in phone,since I don't care if my phone will charge 1h or 2.5 h (with regular charging).
                  But want to ask does fast charging damage the battery cells as time passes...
                  05-16-2021, 03:27 AM
                • Caimano
                  hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                  by Caimano
                  MB G7AD-2G DAG7ADMB8D0 REV D
                  Processor i5 8265U
                  AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                  Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                  Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                  02-06-2024, 10:14 AM
