T2 Chip Programmer Tool
This topic is closed.
+ More Options
Posts
  • Bb68
    • Jul 2017
    • 15
    • South Africa
    Re: T2 Chip Programmer Tool
    Originally posted by stevie
    attached are the bin files from the T2 activation
    you can run the mina activation tool by putting the MacBook Pro in DFU Mode
    but unless you pay the unreasonable $90 to $120 that mina resellers
    want for letting you submit the serial you want to use
    it will come up with the message "serial no authorised"
    you can use the tool with the bin files with the tool but although
    successful it will give wrong summary details in about this mac
    ie: displays that it is a 13" when it should state its a 16" etc
    Hi is there new t2 unlock files available?
    • andriyd1
      • Dec 2013
      • 7
      Originally posted by MughalG
      i have good working Activation_Lock bin files for all models with same configuration as per model
      of course method is not for free
      New serial number / WiFi/ Bluetooth address already built into it?
      • curiositymaster
        • Apr 2021
        • 45
        • Nigeria
        I'm very sure you've got a lot of free help on this forum, I mean from people who didn't get the knowledge/tools free of charge.
        • curiositymaster
          • Apr 2021
          • 45
          • Nigeria
          Originally posted by anhbanxoi
          I cannot open minaT2Activator on Macbook M1. Anybody tested that file?
          Use it on an intel-based system.
          • paulyboy
            • Mar 2020
            • 130
            • New Zealand
            What programmer interface for reading the chip please? Is the a socket for tl866 thanks
            • Bb68
              • Jul 2017
              • 15
              • South Africa
              #26
              Hi
              Ch340 programmer , like by-t200
              • Trackstar23
                • Mar 2010
                • 8
                Any programmer that can read/write to a 25 Series SPI FLASH should be able to interface with the T2 ROM. The CH341A chipset is utilized by most popular products that were developed specifically for the T2 ROM, but a TL866 should also be able to read/write to it so long as you use a 1.8v adaptor when reading it (or use an adaptor that has the 1.8v conversion logic built in).
                • MughalG
                  • Aug 2012
                  • 9
                  • Pakistan
                  #28
                  Yes sure already modified
                  BR
                  • MughalG
                    • Aug 2012
                    • 9
                    • Pakistan
                    #29
                    BY-200 is best for now, anyway you can read it with any programmer but need to solder points
                    BR
                    • MughalG
                      • Aug 2012
                      • 9
                      • Pakistan
                      #30
                      M1 Not supported
                      • Blackmambo50
                        • 3
                        Hi there, after using this kind of bypass (flashing the spi flash)
                        I have two issue: first is that mina/checkm8 give an error, something like "was not able to read from your t2 mac"
                        And if i try to online restore it, i let me put the password for wifi, but after that it does nothing...
                        Any advise?
                        • Blackmambo50
                          • 3
                          Ok after flashing spi back to stock, machine seems to pass this step witch make be belive that either its the issue with mina/check8 or maybe those sn are now blocked by apple...
                          • paulyboy
                            • Mar 2020
                            • 130
                            • New Zealand
                            #33
                            anyone know the socket for the rom
                            • anhbanxoi
                              • Sep 2021
                              • 170
                              • VN
                              #34
                              USON8 4x3mm
                              • Bb68
                                • Jul 2017
                                • 15
                                • South Africa
                                #35
                                I think the T2 unlock data for A1932 is blocked, that Serial number in the T2 unlock bin may be blocked now by Apple because cannot restore in Apple Configurator 2. Can anyone confirm if they have used it recently ?
                                • curiositymaster
                                  • Apr 2021
                                  • 45
                                  • Nigeria
                                  #36
                                  Maybe something is wrong with the file you're using. Try using your stock bin file with a Mina-fied (if you get what I mean) serial number, it should work.
                                  • david zhao
                                    • May 2017
                                    • 9
                                    • australia
                                    #37
                                    I used T203 for A1932 2018 model on 20/10, it worked well. Then I tried to use it for my A2179 2020 model, it gave error "not found SSH device, check it and try again". I got this error at the last step while the "minaT2activator" started running? anybody else has the same issue? Please share your solutions.
                                    One more question here: Can we modify the serial number in those unlock data bin file, before we auto program the rom chip? Will the changing of the serial number affect the jailbreaking?
                                    All helps and discussions are welcome.
                                    David
                                    • david zhao
                                      • May 2017
                                      • 9
                                      • australia
                                      #38
                                      Originally posted by Stephen
                                      I was curious if the T2 chip serial being changed would allow cracking the Firmware lock and icloud lock of a device? We came across the T2 Rom Tool and this allows the use of changing the serial which in our experience would allow removal of MDM on older models (2017-and older). Would that isolate the icloud bypass since it is married to the serial of the T2 chip? Curious since we are close to pulling the trigger on a wholesale lot and we anticipate iCloud devices in MacBooks etc. Piernov or anyone have thoughts on this?
                                      Update: People are saying yes and no. If you change the serial you would have to change the UUID? Apple looks at the serial and the UUID in the rom. I know we could figure this out some how some way.
                                      Any answer to this original question? If I modify the serial number in the unlock data bin file, will the iCloud bypass still work?
                                      • mon2
                                        • Dec 2019
                                        • 13944
                                        Hi. Also interested to learn if the T203 tool is suitable to remove password off A1932. Looking to purchase a broken A1932 from Ebay but only if we can get the password off the unit. Real focus is to learn on how to remove and replace the very thin LCD retina as compared to replacing the display assembly.
                                        • gmorb
                                          • Sep 2017
                                          • 33
                                          David
                                          Same happened to me for my A2179. SSH error
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                            by SMDFlea
                                            Bad...
                                            09-02-2021, 04:40 PM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
