hello there...i invalitate the password for getac v110 in hex but seems i have some problems with functionality...not work well...is there any chance to get a clean free passowd for this model? maybe someone know how to make it bin from their website...with this bios , even i try to make update i get error...maybe someone can give a fresh clean bios for this model..thank you !!!
Getac V110 Bios Needed.
i put in attach 4 bios with password from same model..v110 g2 hey are with bios pwd..and after i invalidate them all 4 pcs are not working well...and i can`t update bios...i apreciate a free no bios pwd clean bios...i must say i have over 20 pcs same model with bios pwd and first 4 after invalidate pwd in hex only problems , and can`t make update to bios i get error,thank you! any help i can get i will apreciate!Attached FilesComment
i put in attach 4 bios with password from same model..v110 g2 hey are with bios pwd..and after i invalidate them all 4 pcs are not working well...and i can`t update bios...i apreciate a free no bios pwd clean bios...i must say i have over 20 pcs same model with bios pwd and first 4 after invalidate pwd in hex only problems , and can`t make update to bios i get error,thank you! any help i can get i will apreciate!Comment
Thank You AAAC for quick answer.You Have right.Then i was unable to test the password because i invalidate the password in hex and write it to getac...and then seems that worked...not test de laptop so much then...but what can i do,i will write back the bin with password was original and i will try with password , i didn`t know that all have same password,i will try it,thank you i will come back with answer after i do,thank you so much again AAAC! thank you!Comment
biospw.bin (s/n: RGA39V0996)
v1par.bin (s/n: RGA39V0945)
v1pw.bin (s/n: RGA39V0983)
v110g2v1.bin (s/n: RGA39V0989)Comment
Hello
I own three GETAC V110 V6, all three with a locked BIOS (BIOS password set and lost).
There is no OS on the HDD and no boot is allowed on external devices.
I'd wish to get those 3 machine alive, again, and at the very best understand how the whole damn thing works.
What I did on one system :
opened it and located the Winbond 25Q80DVSIG eeprom and was able to read the BIOS with a CH341/IMSprog (proper modification applied to the CH341 to have the right voltage on the entire chip)
so I decided to save it and write a fresh BIOS downloaded from the GETAC site (V110G6_R108.bin) and flash it straight to the EEPROM
powered the laptop back, tried to enter the BIOS and got prompted for a password again
I tried to read the original BIOS with binwalk and an Hex editor but didn't succeed in finding anything and in the various tests I made, I lost the backup of the original BIOS (yeah, I know, this sucks)
nonetheless I decided to erase the Windond chip and see what this would do, it changed nothin : BIOS passwd prompt, again
so there is something somewhere such like the system setup utility whish is stored somewhere else and this is where I'm stuck for I had a close look of the motherboard and couldn't find a plausible candidate
any hint or help will be grealty appreciated
regards
*** EDITED ***
I was able to dd a bootable Windows 10 on the machine, so the passwd is still here but I can run some stuff from here - unfortunately the secure boot was activated so no Linux, Windows onlyLast edited by viklander; 12-11-2024, 04:24 AM.Comment
Hello
It is true however that IMSprog identifies the chip as a 1 MB
And I examined with great care the motherbord but I couldn't find any Windond / EEPROM chip
Would you suggest me to entirely remove the motherboard to see if it's on the other face ?
TIA, with regards
Hi, thanks a lot for your answer, but according to https://www.winbond.com/hq/product/c...artNo=W25Q80DV is an 8MB chip. Or am I wrong ?
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
right, uppercase mistake, my wrong
however I extended the serach and I removed a sticky soft plastic shield under which I found a larger Winbond chip covered with varnish, and it's labelled BIOS on the motherboard print
marks are non readable, it is however a larger chip then the one I identified erroneously
I'm gonna have to find the proper clip for this one
ThanksComment
Thanks----------------------------------------------------------------------------------------------------------------------------------------------------------------------
this is my first try working on a bios chip.
i have a Getac V110 G5 with a bios problem (i guess). i was updating the firmware through Windows Update on Win11 and then nothing. Only keyboard lights and display backlight.
so i hope i can revive that computer.
Serial number is RL103V0146
thanks in advance
Sorry, my English is not the best, i am from GermanyAttached FilesLast edited by MettyWurst995; 12-22-2024, 08:59 AM.Comment
thanks in advance
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thanks1 PhotoComment
Send to youAttached FilesComment
In a previous post dated 10-27-2024 I have extracted the password on one of your Getac V110G4 computers (password was hashed), password is "dbihg", which also happens to be the same exact password on the 4 bios dumps that you uploaded. Maybe the problem is with your programmer, and you could have also used the "dbihg" password I've posted almost 6 weeks ago.thank you again for help!
by GrafZahlHi!
I am in desperate need for a Bios dump from an Getac V110 G5.
It needs to be from a stock V110 G5, not a Bosch DCU220 (that also is labeld V110 on the bottom).
If it is password locked, that is no problem.
Thank you in advance!...-
Channel: BIOS Requests ONLY!
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Yesterday, 02:17 PM -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
- Loading...
