Need Lenovo E590 NM-B911 bios dump
  • bander-1979
    • Oct 2021
    • 5
    • saudi
    Re: Need Lenovo E590 NM-B911 bios dump
    thanks soo mathch boos
    • Blackam8899
      • Sep 2020
      • 44
      • Rosario
      We are with the same problem, the machine turns on but there is no voltage in the vcore coil and it does not give any image that solved it?
      • Blackam8899
        • Sep 2020
        • 44
        • Rosario
        Re: Need Lenovo E590 NM-B911 REV 2.0 bios dump
        Originally posted by gjlpereira
        Hi Jtzabala.
        I have a motherboard with the exact same issue; did you ever managed to fix yours?
        same problem did you have a solution?
        • dvt1989
          • Jan 2020
          • 33
          • Viet Nam
          Please help! no display after finish setup window.
          • dvt1989
            • Jan 2020
            • 33
            • Viet Nam
            Same with me, i write a lot of source bios but turn on no volt transfer In U7201
            • SCREAM76
              • Jan 2014
              • 51
              • istanbul
              #26
              nm-b911 rev 1.0 clean me please. no screen.
              • brontobyte
                • Jul 2021
                • 85
                • Romania
                #27
                Hello friends, i need your help please.
                I need clear dump for Lenovo Thinkpad E590.
                I tried to clear this dump but i have no result. It's something that i miss. There's my original dump and my outimage.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria šŸ‡§šŸ‡¬
                  #28
                  What's the issue with the laptop? Serial number?
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                  • brontobyte
                    • Jul 2021
                    • 85
                    • Romania
                    #29
                    SN PF-1RTGCS
                    Laptop turn on, 3 restarts, no fan, only 0.07Ah on 20v. Power light on
                    i have 3.3 on bios chip, 1.05 on pch coil 3,3v on SIO chip.
                    no voltage on vcore
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria šŸ‡§šŸ‡¬
                      #30
                      SN PF-1RTGCS
                      no voltage on vcore
                      Why do you think it's a ME Firmware problem, did it happen while updating the bios, or you just receive the machine in this non working state?
                      • brontobyte
                        • Jul 2021
                        • 85
                        • Romania
                        #31
                        i recived like that.
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          #32
                          SN PF-1RTGCS
                          no voltage on vcore
                          try a new build
                          • bmb2015
                            • Jul 2023
                            • 10
                            Hi. I have a Thinkpad E590 and tried to make a Hackintosh and after clearing NVRAM, the laptop does not boot. Three lights come on, first NumPad and CapsLock and then after 30 seconds or so, the ESC light.
                            Type is: 20NB-005RUS
                            Serial is: PF-1REJLR
                            Motherboard: NM-B911 Rev 1.0
                            I tried to flash about 5 roms on the posts here but I believe the roms are not specific to my Laptop Type.
                            Please help in fixing my attached Rom or suggesting a rom i can flash using CH341a programmer.
                            • Markus1741
                              • Sep 2020
                              • 842
                              • N/A
                              #34
                              Try ...
                              • bmb2015
                                • Jul 2023
                                • 10
                                Originally posted by Markus1741
                                Try ...
                                I just tried to flash this, same symptoms. The power light, caps lock and num lock lights are on. Then after 30 seconds, the esc light comes on.
                                If it helps, I believe the process for hackintosh had me use Gensmbios to modify config.plist. I have the link to the youtube video i was following. At 6:20 is where Gensmbios was used.
                                Again, the issues started when I cleared the NVRAM at 12:06, after that the laptop restarted with black screen and stayed that way with the symptoms described above.
                                https://www.youtube.com/watch?v=c5HVJug0H-4&t=28s
                                • Markus1741
                                  • Sep 2020
                                  • 842
                                  • N/A
                                  #36
                                  Hello, try this file from Post #32 me be it helps ...
                                  • bmb2015
                                    • Jul 2023
                                    • 10
                                    Didn't work. Just the power light on. I am trying to find out how to extract the bios file from lenovo update utility. It sucks that these companies don't just post the bios file, or even factory bios file. They want you to purchase their support so their employees can do the same thing I am doing, and difference is they have the correct files.
                                    Let me know if you have any other ideas. Its either trying to get a working bios or replacing the bios chip, which i'm not looking forward to because of soldering.
                                    • volinakis
                                      • Jan 2021
                                      • 2653
                                      • N/A
                                      #38
                                      try this. happened to me with a L390 and replacing EfiSystem volume did the trick.
                                      To extract bios from update use innoExtractor.
                                      • bmb2015
                                        • Jul 2023
                                        • 10
                                        volinakis, THANK YOU! This worked like a charm. WOW you are genius. I was so happy that I donated as well.
                                        As a result of my E590, I had purchased another laptop L590 with a Winbond 25Q80DV bios chip. The serial is PF-1YGGLK. Machine: 20Q700ALUK. Bios installed was ROZET53W (1.31)
                                        Some additional info on this bios is that NeoProgrammer shows as 8 Mbits and all bios files i am finding are 32mb. I get the message that bios size is greater than IC.
                                        Hope this info helps.
                                        • volinakis
                                          • Jan 2021
                                          • 2653
                                          • N/A
                                          #40
                                          that is not bios chipset, see picture attached
                                          • AHmad_Salal
                                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                            by AHmad_Salal
                                            Hello all,
                                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                            11-28-2023, 05:28 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            Yesterday, 02:28 PM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Joluvillas
                                            Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                            by Joluvillas
                                            Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                            06-18-2024, 10:35 PM
                                          • Captaincrap420
                                            Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                                            by Captaincrap420
                                            Hi, I hope this is the right place to post this. This is my first post on this forum.
                                            A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                                            This bios dump is straight from the chip, nothing has been...
                                            11-29-2024, 05:40 PM
