Need Lenovo t550 bios
  • pirih77
    • Oct 2020
    • 62
    • Slovenia
    I have a lenovo t550 tha turns on, but nothing happens.
    I suspect it is bios fault.
    Does anybody have a working bios dump
    T550 type 20CJ
    MB FRU : 00UR090
    Any help appreceated
  • peste
    • Dec 2016
    • 12262
    • ROMANIA
    Re: Need Lenovo t550 bios
    T550 type 20CJ
    MB FRU : 00UR090
    post the backup bios copy
    • pirih77
      • Oct 2020
      • 62
      • Slovenia
      Here is the original bios dump
      • peste
        • Dec 2016
        • 12262
        • ROMANIA
        try..
        • pirih77
          • Oct 2020
          • 62
          • Slovenia
          Hello
          Now i get 2 beeps like the machine is starting, but still no picture on screen (external also)
          Regards
          • pirih77
            • Oct 2020
            • 62
            • Slovenia
            Interesting. After mora than 30 min on charger laptop started
            Now it is working normally
            Thank you for help!!
            • sag_lee
              • Apr 2017
              • 8
              • Türkiye
              please patch my bios please.
              black screen...
                • 20326
                black screen...
                Post the laptop serial number
                • sag_lee
                  • Apr 2017
                  • 8
                  • Türkiye
                  serial no sn:r90khkym
                  • sag_lee
                    • Apr 2017
                    • 8
                    • Türkiye
                    ples help me.!
                    sn:r90khkym
                    • mohammed mohan
                      • Nov 2017
                      • 196
                      • z
                      Thank you
                      Mohammed Mohan
                      • AHmad_Salal
                        Need BIOS Dump/ROM for Lenovo Thinkstation p500
                        by AHmad_Salal
                        Hello all,
                        I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                        11-28-2023, 05:28 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • Joluvillas
                        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                        by Joluvillas
                        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                        06-18-2024, 10:35 PM
                      • Captaincrap420
                        Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                        by Captaincrap420
                        Hi, I hope this is the right place to post this. This is my first post on this forum.
                        A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                        This bios dump is straight from the chip, nothing has been...
                        11-29-2024, 05:40 PM
                      • mrkmpn
                        Lenovo X1 Carbon 7th Gen Type 20R1 BIOS DUMP
                        by mrkmpn
                        SN: PF1Y5BBJ
                        Board: GX490 NM-C661 Rev: 1.0
                        I have made two dumps of this bios, with the bios chip removed from the board and the hashes match on both dumps, but I cannot find the DMI information in the dumps except for the Windows product key, so I think it is corrupted. I have downloaded two bios updates from the Lenovo support site, but they contain small .PAT file, and 4 subfolders containing .FL1 and .FL2 files, which I don't understand enough to figure out how to use to fix my dump.
                        The problem with the laptop is that...
                        05-21-2024, 09:14 AM
