Need Help A1286 2012 EMC 2556 bios password
  • myjunaid
    • Nov 2019
    • 32
    • Spain
    820-3330-B
    Hi Can anyone help me out to remove the password from this bios dump file
    Thanks in advance
    Macbook pro
    A1286
    2012
  • peste
    • Dec 2016
    • 12835
    • ROMANIA
    Re: Need Help A1286 2012 EMC 2556 bios password
    Originally posted by myjunaid
    820-3330-B
    Thanks in advance
    Macbook pro
    A1286
    2012
    the bios is incomplete ... it must have 8MB ... read the bios chip several times, use the HxD program and compare the copies..and if you have two similar copies, post here ..
    • myjunaid
      • Nov 2019
      • 32
      • Spain
      i tried 3 times and everytime i read it gives me only 128kb
      i am using CH341A
      you can also see the picture of the bios in the zip file
      can you please guide me what i am doing wrong
      • myjunaid
        • Nov 2019
        • 32
        • Spain
        Everytime i read it gives me same size i have read 3 times also you can see the picture of the bios chip and the programmer in the zip file
        • piernov
          • Jan 2016
          • 4435
          • France
          If you don't select the correct chip in the programmer software it won't work.
          • myjunaid
            • Nov 2019
            • 32
            • Spain
            i have tried reading the chip by changing the manu to Winboard and 1 time i read with w25q64bv it gave me 8mb file and 2nd time i read w25q128bv and it gave me 16mb file
            let me know if i m doing something wrong
            • myjunaid
              • Nov 2019
              • 32
              • Spain
              i have my bios picture on my zip file can you guide me the proper setting to read that chip
              thank you for help
                • 20961
                Try NeoProgrammer and ASProgrammer software.You can make a backup with each one and then compare the files with a hex editor to make sure both are the same.Or make 2 backups using the same software and compare both.If they are the same post your backup.
                https://www.badcaps.net/forum/showpo...04&postcount=7
                https://www.badcaps.net/forum/showpo...6&postcount=10
                • peste
                  • Dec 2016
                  • 12835
                  • ROMANIA
                  thank you for help
                  the 8MB bios seems ok ... look in the programmer's software, what is written on the bios chip and select ... if you can't find it, try to enter it manually ... use this program..https://www.badcaps.net/forum/showpo...unt=10...other users have succeeded with it ...
                  • myjunaid
                    • Nov 2019
                    • 32
                    • Spain
                    Thank you for the softwares yes my Programmer was detecting wrong chip
                    i have read the file with neo programmer and the as programmer
                    both files attached now with their pictures and now i can also find $SVS
                    you can check and if possible clear the efi lock for me will appreciate
                    • myjunaid
                      • Nov 2019
                      • 32
                      • Spain
                      please check my last message i have read the file from 2 different programmer have a look i think now its fine
                      i remember you helped me out long time ago in my Hp bios for that Thank you very much
                      • peste
                        • Dec 2016
                        • 12835
                        • ROMANIA
                        you have the bios at post # 9
                        • myjunaid
                          • Nov 2019
                          • 32
                          • Spain
                          Thank you very much it worked
                          • pankajis2005
                            • Nov 2010
                            • 3
                            Can you help he to clear (unlock) the firmware password
                            • ranzoo
                              • Jun 2015
                              • 17
                              • algeria
                              Mackbook pro A1286 EMC 2556
                              Macbook pro a1286 Motherboard number: 820-3330
                              eeprom : 25L6406E
                              EFI UNLOCK /FILE TEST
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • traxformania
                                TONGFANG "GM7TG7P" Bios Password Problem?
                                by traxformania
                                I tried :
                                -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                11-15-2023, 07:32 AM
                              • tlindi
                                Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                by tlindi
                                Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                Ack
                                Ack
                                01-30-2025, 04:26 AM
                              • Nopslide
                                by Nopslide
                                04-01-2024, 04:27 PM
                              • BlackVisor
                                How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                by BlackVisor
                                RedmiBook Pro 1542022 6800H
                                SKU: TM2113-39463
                                Model Number: RMA2204-AB
                                CMIIT ID: 2022AP1835
                                SN: 39463/22WD01355
                                BIOS version: RMARB5B0P1010 20230628
                                1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                01-14-2024, 06:35 AM
