Firmware password on A1286 820-2850-A need thanks
  • the new
    • Jul 2020
    • 14
    • France
    hi
    need help pliz on a macbook pro A1286 that have password on bios
    i trayed this : https://itcrush.wordpress.com/2012/0...-efi-password/
    but don't work for me so i readed bios and i don't find $SVS on the dump to remove password
    there is bios dump if some one can remove password on it and explane me how
    thanks
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Firmware password on A1286 820-2850-A need thanks
    Change RAM configuration and do 3x PRAM reset.
    • the new
      • Jul 2020
      • 14
      • France
      i trayed it already but when it come to chose disque and i chose usb disc macbook freez and reboot ,
      • the new
        • Jul 2020
        • 14
        • France
        so no solution other than this ? no dump hex change ?
        thanks
        • the new
          • Jul 2020
          • 14
          • France
          pliz this dump can be clear from bios password ? if no pliz tell me thanks
          • the new
            • Jul 2020
            • 14
            • France
            so no one can clear password from this 2010 macbook pro dump ?
            • piernov
              • Jan 2016
              • 4439
              • France
              Password should be vqlere164 .
              Method I explained above does work for 2010 and older machines so you're doing something wrong.
              • the new
                • Jul 2020
                • 14
                • France
                ok thanks will resold bios and retray ,
                • the new
                  • Jul 2020
                  • 14
                  • France
                  trayed vqlere164 ( with many combination like valere164 .... ) and no work , will retray memorie solution and tray make another bootable usb system to tray with it thanks
                  have you a good link for mac sytem and how to make them with usb wiith windows and with new mac thanks
                  • Nopslide
                    HP Omen 15-dh0052nf power-on & bios password
                    by Nopslide
                    Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                    My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                    Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                    04-01-2024, 04:27 PM
                  • outsider
                    Panasonic FZ-G1 MK5 - BIOS password returning
                    by outsider
                    Hello
                    I removed the BIOS password thanks to the help of one of the friends of this forum.
                    https://www.badcaps.net/forum/troubl...61#post3637661
                    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                    06-17-2025, 12:51 AM
                  • Julian Bailey
                    Latitude 7420 password ,corrupt ME firmware
                    by Julian Bailey
                    This is the backup of the original BIOS that is admin locked and possibly corrupt ME firmware
                    ST: C91L2F3
                    Cheers...
                    06-03-2025, 09:50 AM
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
