A1534 820-00045-a efi bios dump need
Every donation made will go towards server fees and maintenance costs. -
Re: A1534 820-00045-a efi bios dump need
peste pls guide me how to program this bios. ?
The machine was working fine , suddenly it turned into no display. cpu heats ok. I feel somewhat more than normal. EDP_BKLT_EN signal is absent ie;0v. I feel maybe bios file is corrupt. Pls guide meComment
Will be a CPU problem as usual.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
if anybody have a video of how to program the bios of 820-00045 pls post.ThanksComment
post the original bios of the laptop... you need an SPI programmer..
https://www.youtube.com/watch?v=DWWigscuQDYDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Help me unlock efi a1534Attached Filesif you find these attachements useful please consider making a small donation to the site
Good evening. Macbook a1534 emc2991. Failed update, stuck after shutdown, internal memory is not detected. The volume is 512GB. It works fine with an external drive, when you try to update, you see license errors. I'm thinking of flashing EFI Bios. if you can help. Serial Number CO2SC1CAGTHVComment
post the original bios of the laptop, the corrupted one...
Good evening. Macbook a1534 emc2991. Failed update, stuck after shutdown, internal memory is not detected. The volume is 512GB. It works fine with an external drive, when you try to update, you see license errors. I'm thinking of flashing EFI Bios. if you can help. Serial Number CO2SC1CAGTHVDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Native BackupAttached Filesif you find these attachements useful please consider making a small donation to the site
try .. but be careful when writing because the bios posted is longer... remove the bios chip from the motherboard, before writing or reading, or stick wires between the programmer and the chip..Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you very much. I managed to upload the BIOS without errors. Startup there is only WiFi stopped working. But the internal disk is still not visible in the system. The personal macbook was practically not used. has 35 charge cycles only. Is it possible to drip only the CPU further..... All resistances are normal. SSD power supply presentComment
A1534 EMC 2746
MB:820-00045
S/N:C02QQOCNFWW3
TNXAttached Filesif you find these attachements useful please consider making a small donation to the site
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by bondminer009Good Evening,
Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
Thank You
Salam,
Three-
by picouserPower off when the laptop is doing a BIOS update. The file seems corrupted, or the DMI data was written in the wrong place. Could someone help me with it? I uploaded the backup file from the BIOS chip and the generic file extracted from the HP website. Thanks!...
by adelageHi,
I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?-
by joshAUHi all.
I'm looking for a BIOS file for an Asus N550JK.
I have a Asus R552J, which I believe is identical to the Asus N550JK.
I downloaded the latest BIOS (210) for the R552.
It is named N550JKAS.210.
The BIOS file is however only 6mb in size.
I've read the chip with a CH341A programmer and verified the file.
That file is actually 8mb in size.
I'm wanting to remove the BIOS password from this unit.
It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...-
- Loading...
