hp pavillon 13-s109nl
  • alfredodinolfo
    • 128
    • N/A
    Hi, I need bios dump or FIX my dump (display issue) for 13-s109nl.
    MB FAUCHON-SKY 14265-2 448.05H03.0021
    SPS CODE 827823-601
    CPU SR2EY I5-6200U
    KBC/SIO ITEKB9028Q
    WINBOND 25Q64FVIQ
  • peste
    • 12734
    • ROMANIA
    Re: hp pavillon 13-s109nl
    SPS CODE 827823-601
    CPU SR2EY I5-6200U
    KBC/SIO ITEKB9028Q
    WINBOND 25Q64FVIQ
    bios extracted from the Hp site update, the laptop has two variants of your bios is 080D1
    DMI + KEYWIN 220000-22103F
    • alfredodinolfo
      • 128
      • N/A
      i try but not lucky
      • jevix60
        Needed Bios dump Hp pavillon x2 10-n10***
        by jevix60
        Hp pavillon 10-N106NL product code T9N87EA
        After updating BIOS , the tablet is dead
        may be corrupted the bios.
        Attach backup u4502 ic MX25U6435F
        Thanks...
        01-02-2024, 01:04 PM
      • eryo
        HP Pavillon Laptop 14-ce3031nf Bios Help
        by eryo
        Hello Everyone,
        Hoping someone can help me.
        Product: 1F7H0EA#ABF
        Serial: 5CD022HQJD
        Model : G7AL-2G DAG7ALMB8C0 rev: C
        Before flashing the bios. Laptop has power and turns on but no display , No CAPS lock but fans spin for 1-2 seconds. with a consumption of 0.8A. All the tension was present.
        Since the flash the laptop only consumes 0.05A and I no longer have SUSON and MAINON has 3.3v output from the ITE chip.
        Original dump.
        Thank you in advance for your help.​...
        12-06-2023, 08:06 AM
      • ajgae
        HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
        by ajgae
        Hi everyone!
        First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
        03-06-2025, 09:53 AM
      • Med-Tech
        HP Pavillon Laptop I5 G34A Mobo no startup or led power light.
        by Med-Tech
        i have a problem with a my HP laptop. No startup or led power light, when I plug in the mains supply. After testing the 19V rail, up until the first MOSFET all seems good. The first MOSFET measures 19V in, but output voltage fluctuates. Output measures 14V (or there abouts) and begins to drop to around 2V and then increases again. I have replaced this MOSFET to no avail. I have tested for a short, but I am unable to locate one. Has anyone experienced this type of behaviour? Or perhaps someone has an idea what could be this cause of this?
        Pic with measurments attached....
        01-17-2024, 10:53 AM
      • mgjini
        hp pavillon convertible 14-dy0502sa can somebody clean me please
        by mgjini
        hi all
        this laptop it shows the ssd on bios but it will not recognise when laptop is on, i have tried latest bios updates from hp but still the same issue, i also tried other ssds, i was looking on internet to see if anybody has this bios so i can use them but difficult to find, serial is 8cg137fxs7
        many thanks...
        02-02-2022, 12:53 PM
