hp probook 440 g7 bios password
Every donation made will go towards server fees and maintenance costs. -
I have a HP Probook 440 G7 that is BIOS locked and I need some help getting it removed!
Serial #: SCD0232698
Product ID: 1G7G5EC#UUW
Motherboard: DA0X8JTB8D0
Tried opening up the bin files in Hex workshop and looking for UserCred, BiosUser00 etc. but to no avail.
There's a Windesk and a GigaDevice chip on the motherboard, I attached both files.
EDIT: I tried the RCUnlocker, did not work on either files.Attached Filesif you find these attachements useful please consider making a small donation to the site
the image may be corruptedI have a HP Probook 440 G7 that is BIOS locked and I need some help getting it removed!
EDIT: I tried the RCUnlocker, did not work on either files.Comment
Hello, sorry, I have a problem. I would like to change the serial number of these two copies of the bios, but I tried and they keep showing me the same one. Could someone help me leave these serial numbers?
5CD032CLF8, 5CD033BPWG
Greetings, can you help me with my bios to unlock it, it has a password and an endpoint security error, my computer is HP 440 g7 motherboard DA0X8MMB6D0 serial number 5CD022FNXVAttached Filesif you find these attachements useful please consider making a small donation to the site
Password unlocked and endpoint security fix.Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Hi!. I would like to ask for some help with this bios File. I've tried to use RCUnlocker and manually editing but I've not been lucky. This is a ProBook 440 g7. Mother board X8M-6L, Serial Number SCD026MWLX. Attached are the bios dumps of both the winbond and the giga device. Thank you!Attached Filesif you find these attachements useful please consider making a small donation to the site
HP ProBook 440 G7Hi!. I would like to ask for some help with this bios File. I've tried to use RCUnlocker and manually editing but I've not been lucky. This is a ProBook 440 g7. Mother board X8M-6L, Serial Number SCD026MWLX. Attached are the bios dumps of both the winbond and the giga device. Thank you!
CTNumber_6JPMK52CFDTFXT
Serial_5CD026MWLX
Product_6XJ55AV
BuildId_19WWR4BT601#SABA#DABA
Fearture byte_3X476J6S6b7B7J7M7Q7W7m7saBaQapaqauawbUbhcAdUdpdqeTfPk8.Qe
Hi everyone, I've been trying to remove the password on this laptop without success. Could anyone help me remove it? I'm not sure which chip has the password, so I'm leaving a copy of the two on the motherboard.
Any help is appreciated.
Model: HP ProBook 440 G7
Motherboard: DA0X8MMB6D0 Rev D
Serial number: 5CD050FQ17Attached Filesif you find these attachements useful please consider making a small donation to the site
Use RCUnlocker for GD25B127.Hi everyone, I've been trying to remove the password on this laptop without success. Could anyone help me remove it? I'm not sure which chip has the password, so I'm leaving a copy of the two on the motherboard.
Serial number: 5CD050FQ17----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Greetings, can you help me with my bios to unlock it, it has a password and an endpoint security error, my computer is HP 440 g7 motherboard DA0X8MMB6D0 serial number 5CD043C3VJAttached Filesif you find these attachements useful please consider making a small donation to the site
Read the post above, unlock the 16MB EC_Bios using RCUnlocker, read the bios guides sticky thread for a link to it. To fix endpoint try the patcher script on the main bios https://www.badcaps.net/forum/troubl...security-errorComment
I don't know how to fix this, someone please fix this bios file for me
DA0X8MMB6D0
here flash bothAttached Filesif you find these attachements useful please consider making a small donation to the site
plz fix this issue
firstly i thankyerorrou for fix my end point
Can you fix the issue of Manufacture Programming Mode error?Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Hello,😇😇😇
I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
🔧 Model: HP ProBook 11 G2
📦 Serial Number: 8CG72478MY
🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
🔒 BIOS Status: Locked with password
The laptop is no longer under warranty and HP refused to help me.
I’m looking for a custom SMC.bin file.
I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
Thanks a lot for your help!🙏🙏🙏...-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
- Loading...
