need bios + ec dell xps 9570
  • Slavol
    • May 2015
    • 64
    • Poland
    Dell XPS 9570 LA-F541p
    The laptop does not start, sometimes the POWER LED lights up and nothing - 3.3 and 5V present, 1.05V present. No reaction to the switch button. I suspect the bios but I couldn't find the correct one anywhere.
    Attached my dump.
    Please help me
    XPS 15 9570
    Service Tag: H25BQQ2
    I tried from this site but not correct
    https://www.badcaps.net/forum/showpo...10&postcount=7
    • hardware1
      • Sep 2021
      • 2930
      • N/A
      Re: Dell XPS 9570 LA-F541p
      Originally posted by Slavol
      Attached my dump.
      Please help me
      XPS 15 9570
      Here's your New BIOS, try it and give me the results.
      This Service Tag "H98JPV2" was in your Dump file not "H25BQQ2", but it's also belongs to "Dell XPS 15 9570".
      all donations are welcome,
      • Slavol
        • May 2015
        • 64
        • Poland
        Thank you very much, but the symptom is the same. Without the RTC battery, after 2-3 seconds, the switch indicator lights up and then nothing happens. No response to the switch.
        • Slavol
          • May 2015
          • 64
          • Poland
          hardware1 - probably Your bios is from mainboard LA-G341P, my is LA-F541 ... ?
          • hardware1
            • Sep 2021
            • 2930
            • N/A
            I repaired your BIOS file using the BIOS Region which is provided by Dell, I used this Service Tag to get it "H98JPV2" and it refers to "Dell XPS 15 9570".
            So there's only one BIOS for this Device, regardless the Motherboard Number.
            You can use another dump from anywhere and see if there are any differences.
            • Slavol
              • May 2015
              • 64
              • Poland
              #26
              OK, many thanks
              • magneh
                • Apr 2014
                • 588
                • Portugal
                #27
                Re: need bios + ec dell xps 9570
                Hello all!
                Ive replaced the PCH on a Dell XPS 9570 that was dead, and now its back to life.
                Can someone help me clean ME region on the original bios?
                Model P56F002
                service tag 1Y6LHR2
                board no. LA-G341P
                Thanks in advance
                • hardware1
                  • Sep 2021
                  • 2930
                  • N/A
                  #28
                  Originally posted by magneh
                  Hello all!
                  Model P56F002
                  service tag 1Y6LHR2
                  board no. LA-G341P
                  Thanks in advance
                  Here's your Clean BIOS, try it.
                  The Service Tag inside your dump file is "7BNNMV2", and it also refers to "Dell XPS 15 9570".
                  • magneh
                    • Apr 2014
                    • 588
                    • Portugal
                    #29
                    Thank you !
                    Ive flashed it, and I still encounter 2 issues which Im not sure if its due to the PCH replacement, or Bios.
                    First, each time I restart the machine I get this message
                    thunderbolt pcie device enumeration mode has switched to native
                    The switch option is disabled on the bios, and still this happens every time I reboot the machine
                    Secondly, I can install the GPU drivers (1050ti) with no problems, but when machine is rebooted, again, it appears in device manager with exclamation mark code 43 error.
                    If I reinstall drivers, it appears as normally installed and running with no errors.
                    The service tag on the cover is 1Y6LHR2, maybe someone worked on the bios before getting the machine...not sure.
                    Would the service tag mismatched create some of the issues im describing here?
                    Photos attached
                    Thanks for any inputs, appreciate it
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      #30
                      Thank you !
                      Try this New BIOS and see what will happen, I think if it works fine will let you insert the Service Tag in the BIOS menu.
                      Also it could help you with the other issues.
                      • magneh
                        • Apr 2014
                        • 588
                        • Portugal
                        #31
                        Hey Hardware1!
                        First of all thank you for your help on this one.
                        This dump worked fine, and I was able to enter the correct Service tag.
                        And it fixed the PCIe switch message.
                        At first reboot the GTX1050ti was still installed and working.
                        Installed a Thunderbolt firmware update, and it appeared after second reboot again with exclamation mark...
                        Very weird, gonna try to reinstall and check again if it goes bad after reboot or shutdown...
                        Would love to be able to fix this 100%, after all this work!
                        UPDATE: seems that if I SHUTDOWN the machine each time, the GTX1050ti is always correctly installed and working in device manager.
                        BUT whenever I RESTART the laptop, it appears again with exclamation mark, error code 43
                        What a strange and weird issue...
                        • hardware1
                          • Sep 2021
                          • 2930
                          • N/A
                          #32
                          Hey Hardware1!
                          You're welcome.
                          Have you tried to reinstall the OS? It could be an issue with some drivers.
                          • magneh
                            • Apr 2014
                            • 588
                            • Portugal
                            #33
                            You're welcome.
                            I will try it but very low chance.
                            Ive done some more stuff with the machine.
                            Even when the GTX is installed in device manager, ive run 3dmark and its only using the intel 630 graphics.
                            besides that, had a few bluescreens due to nvdd stuff so yeah...
                            Could be something dodgy with the replacement chipset, or the GPU taken a shot when PCH died, not sure.
                            Not looking good right?
                            • hardware1
                              • Sep 2021
                              • 2930
                              • N/A
                              #34
                              If the New OS doesn't fix the problems, I think you will need to ask for help in the Hardware section.
                              https://www.badcaps.net/forum/forumdisplay.php?f=23
                              • MAZMAZ23
                                • Jan 2023
                                • 31
                                • ALGER
                                #35
                                NEED HELP I FIND THE BIOS BUT I'M NOT SURE THIS IS THE ORIGINAL BIOS WITH THIS BIOS NOT DISPLAYING
                                MOTH DDB00 LA-G341P rev1.0
                                MODEL P56F002 SERVICE TAG 37PX4S2
                                • niggi
                                  • May 2016
                                  • 190
                                  • UAE
                                  #36
                                  yes working file 100% ok
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11653
                                    #37
                                    Originally posted by mazmaz23
                                    need help i find the bios but i'm not sure this is the original bios with this bios not displaying
                                    moth ddb00 la-g341p rev1.0
                                    model p56f002 service tag 37px4s2
                                    111111
                                    • lolmagexe
                                      • Jun 2023
                                      • 3
                                      • Украина
                                      #38
                                      Hi there,
                                      I have the same issue. I decided to reinstall my Windows and after auto installing drivers my bios was updated. From that moment my Nvidia GPU throws error 43 and doesn't work at all. I suppose to think if i flash my bios with right firmware everything will be ok. I'm new here and i hope to solve this issue.
                                      all the best,
                                      Alex
                                      • lolmagexe
                                        • Jun 2023
                                        • 3
                                        • Украина
                                        #39
                                        Originally posted by lolmagexe
                                        Hi there,
                                        all the best,
                                        Alex
                                        additional info:
                                        Product Serial Number: 6RW4QV2
                                        Mainboard Name: 0D0T05
                                        Mainboard Version: A00
                                        • fgpih
                                          • Sep 2023
                                          • 9
                                          • Italy
                                          #40
                                          Hi, I hope it's ok if I reuse this thread instead of opening another one since I need the BIOS for the same machine. I need the BIOS file for my 9570 with Service Tag 158BQQ2, if possible I'd like to have version 1.23.0. Also, would I need to modify it to include the Windows activation key before flashing it, is it correct? Are there any additional info related to my specific machine that I would need to edit into the "blank" BIOS? E.g. anything about hardware combination (my machine has i5-8300h and gtx 1050).
                                          Unfortunately I don't have a backup in hand right now, I hope you can still help me.
                                          Thanks in advance for the help.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • mrrubik
                                            Dell Optiplex 7010 micro bad BIOS flash?
                                            by mrrubik
                                            Hi folks,
                                            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                            Steps I took:
                                            1. Read BIOS with CH341a, verified hash twice
                                            2. Patched
                                            12-23-2024, 04:11 PM
