HP 840 G7 password
    Hi i need help bios password HP 840 G7. Winbond 25q256gjven
    Serial number:
    5CG1016LSF
    Product number:
    2X0E8EC#ABU
    Thank you
      Serial number:
      5CG1016LSF
      Product number:
      2X0E8EC#ABU
      Thank you
      first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
      use BCU. you can permanently disable Absolute lock in BCU.
      here's your dmi:
      Serial Number: 5CG1016LSF
      Product #/SKU: 2X0E8EC#ABU
      CT Number: PJSCQ00WBEOE8J
      Description: HP EliteBook 840 G7 Notebook
      BuildID: 20WWCMBT601#SABU#DABU
      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfPfXguhKhkjhk8mEmV.yd
      MAC Address : 3C:18:A0:7F:6D:E6
        here's your dmi:
        Thank you everything works !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 😄
          Can you help me with the second HP 840 G7 with the password.
          Serial number
          5CG0533KT1
          SKU Number 8PZ96AV
            Serial number
            5CG0533KT1
            SKU Number 8PZ96AV
            here's your dmi:
            Serial Number: 5CG0533KT1
            Product #/SKU: 8PZ96AV
            CT Number: PJRZQ00WBENSYW
            BuildID: 20WWCMBT601#SABY#DABY
            Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPfXgSguhKjhk8mE.nR
            MAC Address : 6C:02:E0:B9:5E:62
              clean me region from website copied your serials
                here's your dmi:
                Thanks 😊 !!!!!!!!!!!!!!!!!!!1
                  Can you help me with next HP 840 G7 with the password.
                  Serial number
                  5CG131878C
                  SKU Number 8PZ98AV
                    Serial number
                    5CG131878C
                    SKU Number 8PZ98AV
                    HP EliteBook 840 G7 Notebook PC
                    Serial_5CG131878C
                    Product_8PZ98AV
                    Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfPguhKhkjhk8mEmVnV.GY
                    Build Id_20WWCMDT601#SABY#DABY
                    Become a Badcaps supporter
                    Thanks to all supporters.
                      Serial_5CG131878C
                      Product_8PZ98AV
                      Thanks !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Perfect😊
                        I have still three pieces withn password. you help me with next HP 840 G7 with the password.
                        Serial number
                        5CG1037QJL
                        SKU Number 113X5ET#ABU
                          Serial number
                          5CG1037QJL
                          Only 3 more... .Try comparing a locked/unlocked bios with a hex editor and see if you can work out how to do it yourself
                            hi guys i have this hp elitebook with the endpoint security error ,i need help to remove that error
                            SN:5CG1362NWR
                            ELITEBOOK 840 G7
                            Many thanks in advance
                              SN:5CG1362NWR
                              ELITEBOOK 840 G7
                              https://www.badcaps.net/forum/troubl...security-error
                                Thank you,i follow the process and both devices are working fine!
                                  Hello. Please Remove Password
                                  HP 840 G7
                                  6050A3136201-MB-A01
                                  s/n:5CG1054FM0
                                    HP 840 G7
                                    6050A3136201-MB-A01
                                    s/n:5CG1054FM0
                                    here's your dmi:
                                    Serial Number: 5CG1054FM0
                                    Product #/SKU: 1C8P4UT#ABA
                                    CT Number: PJRVV00WBES14X
                                    Description: HP EliteBook 840 G7 Notebook PC
                                    BuildID: 20WWCMBT601#SABA#DABA
                                    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqfPguhKhWhkj4jhk8mE.Ed
                                    MAC Address : 3C:18:A0:C1:F5:2A
                                      Hi!
                                      pleace help to disable computrace
                                      serial 5CG04522BD
                                        found solution how do it on hp, thanks
                                          Bonjour la communauté. s'il vous plait j'ai un hp elitebook 840 g7 qui a le mot de passe pouvez-vous m'aider à le debloquer ????
                                          SN: 2TK12402NP
                                          je vous met le fichier joinds.
