lenovo Flex 5 bios need
  • pokyss1
    • Mar 2019
    • 57
    Originally posted by pokyss1
    BONJOUR
    no display issue
    model number in the bord:
    LC55-14A
    19793-3
    448.0K104.0031
      SMDFlea commented
      Editing a comment
      Post the laptop model number and Type and post the laptop serial number..........
  • shiyab
    • Sep 2023
    • 1286
    • india
    #82
    BONJOUR
    no display issue
    LC55-14A
    19793-3
    448.0K104.0031
    post snid
    • Osmarperez
      • Oct 2024
      • 4
      • Ecuador
      #83
      Hi everyone!!
      Could you please help me fixing this BIOS? Thanks in advance
      Lenovo Ideapad Flex 5-14ITL05 Laptop - Type 82HS
      S/N: R912W5LD
      BIOS VERSION: FXCN49WW
      Issue: after a bad upgrade laptop won`t recognize SSD NVMe, other than that everything is ok.
      Thank you very much
      • hoaca388
        Badcaps
        • Jan 2022
        • 11559
        • Viet Nam
        #84
        Originally posted by Osmarperez
        Hi everyone!!
        S/N: R912W5LD
        Thank you very much
        S/N: R912W5LD
        • Osmarperez
          • Oct 2024
          • 4
          • Ecuador
          #85
          Originally posted by hoaca388
          S/N: R912W5LD
          Thank you very much !!
          • Osmarperez
            • Oct 2024
            • 4
            • Ecuador
            #86
            Hi everyone, it`s me again this time with a question: is there a method to upgrade/flash the BIOS of the Lenovo Ideapad Flex 5-14ITL05 Laptop - Type 82HS using a bootable pendrive?
            I`ve search the Internet but I haven´t found a way to do it in Lenovo laptops. Thanks.
            • redoxy
              • Sep 2018
              • 100
              Hi everyone!!
              Could you please help me fix my BIOS?
              Lenovo IdeaPad Flex 5-14ITL05
              S/N: R912KL5Q
              Motherboard: LC65-14T 203013 448.0K121,0011
              Issue: Laptop powers on but no display. It appears the LCD backlight turns on but no image.
              Thanks, in advance.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11559
                • Viet Nam
                #88
                Originally posted by redoxy
                Hi everyone!!
                S/N: R912KL5Q
                Thanks, in advance.
                Flex 5-14ITL05 Laptop (ideapad) - Type 82HS
                • shiyab
                  • Sep 2023
                  • 1286
                  • india
                  #89
                  Hi everyone!!
                  S/N: R912KL5Q
                  Thanks, in advance.
                  hi try
                  • redoxy
                    • Sep 2018
                    • 100
                    Thanks, Hoaca388 and Shiyab for the files.
                    I tried Hoaca388's file and it worked. I have display.
                    However, I lost DMI info (S/N, Model #, UUID and Windows Key) as shown in the picture.
                    I tried using the Lenovo Uone tool to write the DMI info but I get an error "Locate protocol with LenovoEeprom, status [e]"
                    "Eeprom fail when reading or writing data."
                    Is there a way to fix the DMI tool error? I'd like to try that first if possible since I'd prefer not to desolder the BIOS chip again.
                    shiyab does your file retain the DMI information so I should go ahead and try that if I'm unable to write the DMI info with the tool?
                    Thanks, again for the help.
                    Cheers!
                    • qayyum786
                      • Aug 2018
                      • 1933
                      • INDIA
                      #91
                      try
                      • redoxy
                        • Sep 2018
                        • 100
                        Originally posted by qayyum786
                        try
                        Thanks, qayyum786. I made a rookie mistake in my haste to flash the BIOS. I forgot the battery was still when I was placing heat tapes on resistors and capacitors around the BIOS chip to prepare for desoldering the BIOS chip. I ended up shorting the BIOS chip (it burned). I replaced it with the same part number from a donor board and flashed your bin file but now there's no power. The laptop doesn't turn on anymore. I tried with battery only, power adapter only, and battery with power adapter with the same results, no power. I guess I might have damaged other components besides the BIOS chip
                        This is the end of this repair for me.
                        Thanks, everyone for all the help.
                        Cheers!
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          #93
                          Cheers!
                          flash old bios and check dose it turn on
                          • redoxy
                            • Sep 2018
                            • 100
                            I ordered new BIOS chips. I'll try and report back once I receive it.
                            Thanks.
                            • redoxy
                              • Sep 2018
                              • 100
                              I received the new BIOS chip and flashed the old BIOS. It still does not turn on.
                              • Lukosiukas
                                • Jul 2018
                                • 106
                                • Lithuania
                                #96
                                Hello, i need bios rebuild or dmi and widnows key trasfered. Turns on, black screen, no post. Tried dump with no dmi (from #3 post) computer turns on, works perfectly.
                                IDEAPAD FLEX 5 14ARE05
                                SN R9121R2B
                                MTM 81X2009JLT
                                BOARD LC55-14A 19793-3
                                • peste
                                  • Dec 2016
                                  • 12546
                                  • ROMANIA
                                  #97
                                  SN R9121R2B
                                  MTM 81X2009JLT
                                  now you have everything you need at post #3...transfer DMI AND KEYWIN yourself...
                                  the bios from post # is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                                  select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11559
                                    • Viet Nam
                                    #98
                                    SN R9121R2B
                                    MTM 81X2009JLT
                                    Flex 5-14ARE05 Laptop (ideapad) - Type 81X2
                                    • Shako
                                      • Jan 2025
                                      • 14
                                      Hello guys. Can you please help me with my BIOS. Laptop turns on and has a black screen.
                                      Lenovo IdeaPad Flex 5 14ARE05 Type:81X2
                                      SN: R9128CCK
                                      MTM:81X20099GE
                                      MO:R9N0B132700F
                                      I would really love to keep my Serial Number.
                                      Thanks in advance.
                                      • peste
                                        • Dec 2016
                                        • 12546
                                        • ROMANIA
                                        #100
                                        SN: R9128CCK
                                        MTM:81X20099GE
                                        MO:R9N0B132700F
                                        Thanks in advance.
                                        try post #4..
                                        https://www.badcaps.net/forum/troubl...os#post1758667
                                        • claws77
                                          lenovo flex 5 14ITL05 bios and motherboard fault
                                          by claws77
                                          my laptop is lenovo flex 5 14ITL05
                                          recently my power supply for this laptop developed a fault.
                                          which caused a short in my usb c port -- verified with a new charger.
                                          rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                                          I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                                          07-05-2024, 04:33 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                          Lenovo C340-15IML/FLEX-15IML/S340-15IML S340-14IML Bios Extract & DMI Edit Tutorial
                                          by SMDFlea
                                          These models use the same bios: Lenovo IdeaPad C340-15IML/FLEX-15IML/S340-15IML/S340-15IML Touch/S340-14IML Lenovo XiaoXin-15IML 2019/XiaoXin-14IML 2019
                                          Backup bios used for this tutorial https://www.badcaps.net/forum/showthread.php?t=97978 Post #13
                                          Extract & Edit.
                                          Download the lenovo update from - https://download.lenovo.com/consumer...s/crcn17ww.exe
                                          Extract the first exe using innoextract - https://constexpr.org/innoextract/#download
                                          Extract the second exe using 7-zip or winrar - https://www.7-zip.org/download.html
                                          08-11-2021, 12:22 PM
                                        • BootNewbie
                                          Lenovo v15 bios corruption! help needed!
                                          by BootNewbie
                                          3 days prior my Lenovo laptop notified of a bios update, at first I tried to decline it but when i put it on charging lenovo vantage started installing it automatically. After bios was updated i was asked for ftpm reset, first I chose no but same pop up showed up so i had to choose yes. After this concluded i successfully booted, but i had linux dual booted with windows, and it was nowhere to be seen after bios update, i tried secure boot off then successfully entered linux. after shutting down my laptop i encountered this issue:
                                          power is supplied
                                          screen remains blank (it gets...
                                          Today, 11:37 AM
