lenovo Flex 5 bios need
  • akbari_808
    • Jan 2019
    • 20
    • United Kingdom
    Re: lenovo Flex 5 bios need
    Thank you.
    • alex39t
      • Nov 2013
      • 50
      • greece
      i want also help my laptop is lenovo flex5-14a with motherboard lc55-14a 19793-1... my old bios is but when i put the old one again back to bios chip the ch341a write that it is buffer dissagrement .any help with this?
        • 20888
        Thats a common issue because the included software is poor. Alternative software is available https://www.badcaps.net/forum/showpo...40&postcount=2 1.1.1.6. CH341A
        EDIT: your backup file is 16,385KB it should be 16,384KB .Attached is your backup with the 1KB deleted.Use the alternative software
        • alex39t
          • Nov 2013
          • 50
          • greece
          also i want no corrupted bios can you help thanks very much
          • alex39t
            • Nov 2013
            • 50
            • greece
            i mean that bios is corrupted
            • donnick
              • Nov 2022
              • greece
              #26
              Hello guys. My flex 5 (14are05) screen just died. I do have a programmee and saved a copy of my bios. Then reprogrammed with a couple of bins posted here, but now there is also no power. Before had black screen but the power button and fan was working. any ideas?
              • donnick
                • Nov 2022
                • greece
                #27
                update; with the verify checked in AsProgrammer i get error codes and the write stops. Chi
                p is firmly soldered on the ch341, so no loose ends there...
                • Mumraiz Ahmad
                  • Aug 2022
                  • 13
                  • United Arab Emirates
                  #28
                  Originally posted by qayyum786
                  try newly build bios from lenovo support site
                  hi friends i need ec file lenovo flex 5
                  mother board lc55-a14
                  19793-3
                  npce388pb0dx
                  anybody help me thanks in advance
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11735
                    #29
                    19793-3
                    npce388pb0dx
                    serial number ?????????????????
                    • Mumraiz Ahmad
                      • Aug 2022
                      • 13
                      #30
                      idea pad flex 5 14are05
                      model name 81x2
                      serial r91020eb
                      thank you..
                      • hardware1
                        • Sep 2021
                        • 2930
                        • N/A
                        #31
                        model name 81x2
                        serial r91020eb
                        thank you..
                        Upload your original bios file.
                        all donations are welcome,
                        • Mumraiz Ahmad
                          • Aug 2022
                          • 13
                          #32
                          upload your original bios file.
                          here is it original fro laptop
                          npce 388 was burned out
                          • hardware1
                            • Sep 2021
                            • 2930
                            • N/A
                            #33
                            Here's your new file try it and let me know. The serial number in your backup file was: R911JEV9, it's also belongs to the same model.
                            • Mumraiz Ahmad
                              • Aug 2022
                              • 13
                              #34
                              DEAR THANKS ALOT FOR YOUR HELP BUT I NEED EC FILE NPCE 388
                              • hardware1
                                • Sep 2021
                                • 2930
                                • N/A
                                #35
                                Here are 2 EC files (192KB) and (256KB), you should know your chip size and choose the right one.
                                • Mumraiz Ahmad
                                  • Aug 2022
                                  • 13
                                  #36
                                  THANK YOU SO MUCH
                                  • Mumraiz Ahmad
                                    • Aug 2022
                                    • 13
                                    #37
                                    THANK YOU SO MUCH
                                    NO LUCK
                                    NO POWER ON
                                    NPCE388 CAPACITY IS 128 KB
                                    IF I USE NPCE385PA0DX WITHOUT ANY PROGRAMMING LAPTOP POWER ON AND CPU V CORE ALSO PRESENET BUT IT KEEP RESTRTING ABOUT EVERY 4 SECONDS CANNOT GET ANY IMAGE ON SCREEN.
                                    IS THERE ANY IDEA????
                                    • ajbernasko
                                      • Mar 2022
                                      • 229
                                      • ghana
                                      #38
                                      NO LUCK
                                      NO POWER ON
                                      how did you read and write files from the EC chip ? what was your configuration
                                      • Iampityu
                                        • Feb 2015
                                        • 19
                                        • Hungary
                                        #39
                                        Lenovo Flex 5 14ARE05 bios
                                        I have this notebook bricked, turned off at bios update.
                                        can someone check the dump, or give me working bios for it. AMD cpu.
                                        Thank you
                                        • hardware1
                                          • Sep 2021
                                          • 2930
                                          • N/A
                                          #40
                                          Re: Lenovo Flex 5 14ARE05 bios
                                          Thank you
                                          Here's your New BIOS, it's a Virgin BIOS from Lenovo with your DMI and Windows Key.
                                          Serial Number: R90Y5N4W.
                                          • claws77
                                            lenovo flex 5 14ITL05 bios and motherboard fault
                                            by claws77
                                            my laptop is lenovo flex 5 14ITL05
                                            recently my power supply for this laptop developed a fault.
                                            which caused a short in my usb c port -- verified with a new charger.
                                            rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                                            I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                                            07-05-2024, 04:33 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                            Lenovo C340-15IML/FLEX-15IML/S340-15IML S340-14IML Bios Extract & DMI Edit Tutorial
                                            by SMDFlea
                                            These models use the same bios: Lenovo IdeaPad C340-15IML/FLEX-15IML/S340-15IML/S340-15IML Touch/S340-14IML Lenovo XiaoXin-15IML 2019/XiaoXin-14IML 2019
                                            Backup bios used for this tutorial https://www.badcaps.net/forum/showthread.php?t=97978 Post #13
                                            Extract & Edit.
                                            Download the lenovo update from - https://download.lenovo.com/consumer...s/crcn17ww.exe
                                            Extract the first exe using innoextract - https://constexpr.org/innoextract/#download
                                            Extract the second exe using 7-zip or winrar - https://www.7-zip.org/download.html
                                            08-11-2021, 12:22 PM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
