Xiaomi Mi Notebook Pro 15.6 [BIOS password / BIOS dump]
Re: Xiaomi Mi Notebook Pro 15.6 [BIOS password / BIOS dump]
Nice.Can you post the XMAKB5R0P0906 in a zip or rar and the platform.ini as a text file,it might help someone else.Comment
more info can be found in this github repo: https://github.com/Cr0wTom/Mi-Notebook-Pro-Mods
this is the with an modified platform.ini which downgrades/sidegrades/upgrades to XMAKB5R0P0906 and resets the password on flash to 1234Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello. I tried this method and managed to dump bios into bin file but while inside hex editor I cannot find the value where the password should be (it says (value cannot be found). I am attaching the bios.bin file for the reference.I bought a 2nd Hand Xiaomi Notebook Pro laptop but the first owner used a password in the Bios and I cant contact the first owner because I bought the laptop from a local supplier which buys it outside the country.
After searching the web with no clear answer or tutorial. I want to share how I did it.
1st Step. Download Intel FPTW64 FPTW64 files I used from here and place all the files in your :\C folder. You will make a backup of your BIOS. To do this. Open CMD as Administrator then type cd C:\ then press Enter, then after that type
.\fptw64.exe -bios -d bios_backup.bin . This will create a bios_backup.bin file which contains your bios password.
2nd Step. To decode the BIOS .bin file. You need HxD hex editor. Open your .bin file on the HxD program . This will show text you cannot undestand but you only need to use ctrl+f to find this specific location on the texts Use CTRL+F then go to the Hex-values tab and type this 00 65 00 72 00 76 00 69 00 73 00 6F 00 72 00 50. After that you will see on the left side under Decoded Text there is something like {S.y.s.t.e.m.S.u.p.e.r.v.i.s.o.r.P.w.....(this area will contain your password)aU?..........
Take a photo of that so you can type it when you log in to your BIOS .Comment
packed with zipAttached Filesif you find these attachements useful please consider making a small donation to the site
Guys, could you please help me with decoding BIOS password?
I've created dump with FTWP64 but can't decode the password
I have no idea about correct symbols, hope you can help
HEX Code: D2 76 FB 56 FA BD 95 45 5C 71 93 65 43 80 15 60 4E FC E0 51 0E 12 25 B2 75 B3 5C E6 5E 83
"Decoded" text: ТvыVъЅ•E\q“eCЂ`NьаQ%Іuі\ж^ѓ
BIOS backup attached
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
I disabled BIOS "SECURE BOOT" required by Ventoy to install OS, then I just F10 exit BIOS. I dID NOT enable any BIOS password nor tamper other settings, just straight exit BIOS. Now the BIOS ask me BIOS password which I didn't setup in the first place. (I still can normally boot into Windows, just CANNOT enter BIOS anymore).
To make matter worse now I also couldn't boot from USB flash drive (which usually present when press F12). Now when press F12 the ONLY boot option available is boot from INTERNAL SSD.
I've tried following methods to extract BIOS file to no avail:
- FPTW64.exe
- Universal BIOS Backup ToolKit 2.0
by chance I saw on CPU-Z got "Save BIOS" feature (see attached image), thus I attached it here hopefully it is the BIOS file needed.
Anyone can help me clear the BIOS password?
Model: Redmi Book Pro 15 2022
CPU: AMD Ryzen 7 6800H with Radeon Graphics
Current BIOS: TIMI RMARB5B0P0B0BAttached Filesif you find these attachements useful please consider making a small donation to the site
Your text file runs down to 10000h, which corresponds to 64KB, it is way too small to be a complete BIOS bin, should be something like 8,192KB or 16,384KB.
First time I have seen a bios as a text.
You should see something like 7FFFF0 or FFFFF0 at the last line.
Please try again.Comment
Can anyone tell me how to dump bios file?
I've tried using:
- Intel FPTW64.exe -> Error 2: Failure. Unexpected error occurred
(run from windows under command prompt run as admin, and boot to windows to command prompt).
is it bcos this tool ONLY meant for Intel processor? MINE is AMD.
- Universal BIOS Backup ToolKit 2 -> NOT recognized mine.
I have NO access to USB boot.
Previously I use CPU-Z to save my BIOS file (see attached image) but it turned out to be the incorrect one.
been searching how to dump bios on this thread and others to no fruition. hope some guru kindly guide me what's the correct tool.
Laptop: Xiaomi RedmiBook Pro 15 2022
RAM: 16 G
Mobo: TIMI
Model: TM2113
BIOS: TIMI
version: RMARB5B0P0B0B
Date: 07/10/2022Attached Filesif you find these attachements useful please consider making a small donation to the site
I have a Redmi book pro 15 2022 ryazan 7 6800H. I made a BIOS backup and tried to decrypt it. Strange characters are displayed together where the supervisor password should be.Attached Filesif you find these attachements useful please consider making a small donation to the site
I have the save problem, the same laptop, managed to dump with Universal BIOS Backup ToolKit 2.0 buy password is encrypted.Comment
18836-2 bios dump ok i5-10gen srgky
pls me clean before writeAttached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Does anyone have a bios dump for 32gb model, with AMD 6800H? It had a custom bios. I flashed latest RMARB5B1P0E0E, but now it recognizes 16gb ram only (Last edited by philipdick; 08-14-2023, 02:56 PM.Comment
Question regarding Xiaomi Mi Notebook Pro 15.6 GTX BIOS
I'm looking for information on successfully updating BIOS on a Xiaomi Mi Notebook Pro 15.6 GTX 1050 version (TM1707).
I downloaded BIOS XMAKB5RRP0C05 that should work with my version of the laptop from Xiaomis website, but there have been multiple instances of people brickinking their Xiaomi Notebooks by installing a BIOS that is not compatible, so I though I would ask around to see if anyone had any success with it.
Model: Xiaomi notebook Pro 15.6 TM1707 (GTX version)
CPU: I5 8250U
GPU: GeForce GTX 1050
RAM: 8 GB
Current BIOS: XMAKB5RRP0804Comment
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by dell_biosHi everyone,
I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
The board has three SPI flash chips:
- W25Q64FV (main BIOS)
- W25Q32FV (EC/TPM)
- W25X10CL (configuration)
I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
The dump contains protection that needs to be removed.
If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
I’m also happy to share my dump for comparison if needed.
Laptop model: [please specify, e.g....-
Channel: BIOS Requests ONLY!
by AhariHi all,
I...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by ArkzGHey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
What I currently have available:
- Model: FA506NF (2021)
- BIOS chip: GD25LQ16 (16Mbit/2MB)
- Tools: CH341A programmer ready to use
Does anyone have either a clean 2MB .bin dump of this model,...-
- Loading...
