Dell Latitude E6430 bios dumps v.A24 (bios upgrade problem)
  • pingaroon
    • Nov 2019
    • 121
    • uk
    I have noticed with Dell Laptops, that once the bios is corrupted, then reflashing the chips with other versions from other machines (ec/main) will work fine in the sense, the machine can then boot again normally, but there is always one issue remaining: The bios can no longer be updated. There are posts all over the internet complaining about Dell bios updates failing. They go through the update procedure and everything looks fine, but as soon as the machine restarts, it just boots normally without actually performing the upgrade.
    I have an E6430 (LA-7781P) which I have recovered with files off this forum, but it is stuck at A14. Does anybody have the ec/main dumps for version A24 as that is my only hope of upgrading it (unless anybody knows a trick how to make this work).
    I have tried windows/dos forceit options, everything imaginable to get it to upgrade, but absolutely nothing works.
    Your help appreciated!
    • 21307
    Re: Dell Latitude E6430 bios dumps v.A24 (bios upgrade problem)
    Bios version A24 https://www.badcaps.net/forum/showth...ighlight=E6430 .Use an SPI bios programmer .
    • pingaroon
      • Nov 2019
      • 121
      • uk
      Big THANK YOU! That worked a treat
      • gizaha
        by gizaha
        02-13-2024, 07:18 AM
      • jhanra
        by jhanra
        11-02-2024, 04:19 AM
      • TripTop
        Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
        by TripTop
        Hi
        i have dell latitude E7270 with following symptoms:
        - takes long time to restart.
        - sometimes powers on and then off
        - sometimes while working it just dies,
        From googling online bios clean could possible resolve this?
        i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
        As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
        I reinstall...
        09-09-2024, 02:05 PM
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
      • Loli Popu
        DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 08:29 AM
