Please bios Toshiba Tecra C50-c
  • ruletero
    • Nov 2018
    • 182
    • Mexico
    Hi everyone
    Please, I need the bios for Toshiba Tecra C50-C celeron version
    I attach the .exe file downloaded from the official page but I don't know how to extract from it or if someone could explain me how to do it.
    I decompressed it with winrar and 7zip but it doesn't have a fd / bin file, only too many files.
    Please help.
    Thank you
  • peste
    • 13183
    • ROMANIA
    Re: Please bios Toshiba Tecra C50-c
    Originally posted by ruletero
    Hi everyone
    Please help.
    Thank you
    see post # 4
    https://www.badcaps.net/forum/showthread.php?t=91357
    • ruletero
      • Nov 2018
      • 182
      • Mexico
      Ok, let me try. thank you!
      • ruletero
        • Nov 2018
        • 182
        • Mexico
        No luck
        I did all the steps and I get the bin file but the size is very lower, almost 6 MB. The original bios has 16 MB
        I attached the process. Did I do something wrong?
        thank you
        • qayyum786
          • Aug 2018
          • 1942
          • INDIA
          no luck
          i did all the steps and i get the bin file but the size is very lower, almost 6 mb. The original bios has 16 mb
          i attached the process. Did i do something wrong?
          Thank you
          you have to use fitc tool and decom your original dump and modify your bios region and rebuild it again by the help of fitc tool
          • ruletero
            • Nov 2018
            • 182
            • Mexico
            Hi
            Do you know or do you have a tutorial about that ? Is the first time that I hear that tool.
            Please
              • 21441
              No luck
              thank you
              No,its just that the extracted file is only a bios update,not the full one.
              Hi
              Please
              There`s a sticky thread at the top of the bios requests with an ME firmware cleaning tutorial . Post your bios backup and someone will fix it .
              • ruletero
                • Nov 2018
                • 182
                • Mexico
                Ok, this is my backup. Please someone could help me
                • peste
                  • 13183
                  • ROMANIA
                  try..
                  • ruletero
                    • Nov 2018
                    • 182
                    • Mexico
                    Originally posted by peste
                    try..
                    No luck, with these bios the machine not turn on, with the original bios turn on but without video.
                    • peste
                      • 13183
                      • ROMANIA
                      try..
                      • ruletero
                        • Nov 2018
                        • 182
                        • Mexico
                        Thanks peste but it isn´t working, same behavior, not turn on.
                        The laptop turns on (without video of course) without bios chip, also turns on with original bios.
                        In first case it has voltage in vgfx_core, in the second case it haven't.
                        The problem started when I changed a value in bios setup ( I don't remember what), after that, I saved and restarted the laptop and turn on without video.
                        This is the complete information for the laptop:
                        TECRA C50-C
                        Part: PS571U-05L02EST
                        Serial: 9G065875H
                        I have not found the correct bios in the web.
                        Thank you for your help.
                          • 21441
                          Try this one.Your bios + DMI .
                          • SHIBIL MA
                            • Sep 2021
                            • 29
                            Re: pls Help me extracting Toshiba BIOS !!!!
                            Toshiba tecra c50-c a4097a need bios please
                            • peste
                              • 13183
                              • ROMANIA
                              post as much data about the laptop as possible (see post # 12), and the original bios backup of the laptop.
                              • hamdykl
                                • Oct 2021
                                • egypt
                                i try this its working
                                • ejaz.jan
                                  • 15
                                  • pakistan
                                  please unlock or dump this file for me
                                  • ejaz.jan
                                    • 15
                                    • pakistan
                                    Does anyone please extract the bin from this file or create dump?
                                      • 21441
                                      The password is stored in the SMSC MEC chip,it can`t be programmed as JTAG access is blocked. The only way to remove it is by challenge-response code or by using another chip from a donor board that has no pass.
                                      For information ... all these models are unlocked only through the response code:
                                      Portege (A30, A600, M100, M200, M300, M400, M700, M750, M780, R30-A, R100, R200, R400, R500, R600, R700, R830, R930, S100, Z830, Z930, Z10T-A, Z20T-B, Z30T-A/B/C, X20W-D, X30-D)
                                      Qosmio (F20, F30, F60, F750, G10, G20, G30, G40, G50)
                                      Satellite (M30, R10, R20, R630, R830, R840, R850, R930, Z930, U200, U920, Z30-A)
                                      Satellite Pro (A30-D, A40-D, A50, A120, M10, M30, R40-D, R50-B/C/D, R840, R850, R950, S200, S300, S300L, S500, U200)
                                      Tecra (A3X, A9, A10, A11, A40-D, A50, A50-D, C50-C, M1, M2, M3, M4, M5, M7, M9, M10, M11, R840, R850, R940, R950, S3, S4, S5, S10, S11, X40-D, W50- A, Z40T-A/B/C, Z50-A/B/C/D), WT310, Kira, Libretto (U100, W100)
                                      X30-E,Z50-E E...F series only service Toshiba can unlock.
                                      If you post your challenge code someone might give you the response code if you`re lucky.Otherwise you can find paid services if you google search for them.
                                      • ejaz.jan
                                        • 15
                                        • pakistan
                                        Thanks a lot dear
                                          Toshiba Tecra Tecra X40-E-114 Netbook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra Tecra X40-E-114 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tecra X40-E-114 boardview and Tecra X40-E-114 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 06:42 AM
                                        • aze2eza
                                          [Request] BIOS Unlock for Toshiba Tecra X40-E-19
                                          by aze2eza
                                          I need help unlocking the BIOS of a Toshiba Tecra X40-E-19, Serial Number: 2K199216H.
                                          The BIOS is locked (possibly password protected), and I have already dumped both the original BIOS and EC chips using an RT809H programmer.
                                          Board model: FURRSY1 A4481A
                                          I'm requesting assistance in removing the password or unlocking the BIOS while keeping system data intact.
                                          Any help or patched file would be greatly appreciated.
                                          Thank you!...
                                          04-30-2025, 03:35 AM
                                          Toshiba Tecra C50-EC Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra C50-EC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-EC boardview and C50-EC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                                          09-06-2024, 09:01 AM
                                          Toshiba Tecra X40-E Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra X40-E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X40-E boardview and X40-E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                                          09-06-2024, 06:27 AM
