HP Omen 17-w010ca BIOS
  • suiramix
    • Mar 2011
    • 131
    Hi there,
    I got this HP Omen 17-w010ca laptop completely dead (no light on DC-in led).The BIOS chip has some scratches on the pins (my guess is somebody tried to re-program using a SOIC-8 clip)...however, I backed-up the existing file. Downloaded the newest BIOS file from HP web (sp106009), and noticed 6 different files (0820D.bin ...08294.bin). Now do I have to try all of them ? The motherboard is DAG37AMB8D0 rev: D . Thanks again!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Omen 17-w010ca BIOS
    No, you need to check $bid number in your backed bios and flash the same. However, since you are saying, it came from a prior service attempt, may be wrong bid is flashed. So check accordingly.
      • 20731
      The 17-w010ca spec page lists your CPU as a i7-6700HQ ,its Skylake H ,so that cuts your options down to 3 .
      https://www.badcaps.net/forum/showthread.php?t=72828
      BID0820D SKYLAKE H
      BID0825F SKYLAKE H
      BID08294 SKYLAKE H
      https://support.hp.com/gb-en/document/c05333486
      • suiramix
        • Mar 2011
        • 131
        Thanks guys, ..I opened the backed-up dump file with HxD and $BID found 0820D. Erased and wrote the BIOS chip with the latest file ... but same result !!!. Same thing with 0825F and 08294.bin !
        Question: should I re-flash back to the old bin file? Probably I will start a new post related to troubleshooting this motherboard ( doing some voltage measurements at PU1001 IC charger)
          • 20731
          As youve flashed a new bios with clean ME its now married to the PCH. If you flash the old bios back thats already initialised (dirty) it would either not boot,boot to black screen,run slow and shut down after 30 minutes. We can assume for now that 0820D is the original so flash the virgin 0820D bios back and do further troubleshooting.If you fix the problem then you`d need to re-enter the DMI info ,or just clean the original bios ME and flash it back. That would save you having to re-enter the DMI
          • suiramix
            • Mar 2011
            • 131
            OK got it! Just re-flashed to virgin (latest 0820D.bin from HP) ... before doing any repairs, personally I want to have some history ...that will help to find the defect faster ! Thanks again SMDFlea !
            • jopekgsm
              • Oct 2017
              • 3
              • Poland
              Hi, could you share your bios?
              • peste
                • Dec 2016
                • 12674
                • ROMANIA
                post the backup of the bios
                • Mcfalsi
                  • Apr 2015
                  • 191
                  • Türkey
                  hi DAG37AMB8D0REV D UMA BİOS NEED
                    • 20731
                    If your asking for a different one to the model in the thread topic "17-w010ca" start your own thread.You should know what to do by now, you come here often enough.If you have a bios backup check the bid number with a hex editor,its very easy to do.Find the bios at the HP support site by entering the serial number,or laptop model number.Run the exe and choose "save to location" ,all the bios (there could be more than one in the exe) will be extracted to the location/folder you chose.Checkthe extracted bios file names for example 0820D ,then use the hex editors text search function and look for 0820D ,or all the other file names to find your BID
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
                    • Dani Rahal
                      hp omen 17-cb0247ng bios
                      by Dani Rahal
                      Hi can some one help me plz
                      i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
                      i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
                      the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
                      i have the orginal bios if some one can see what the problem or...
                      05-30-2025, 09:11 AM
                    • zerbatin
                      HP Omen 16-c0825no BIOS.
                      by zerbatin
                      I have problem with my laptop. When I turn it on it do not POST. Black screen with FAN not working, When pressing CTRL+V/B I can go into BIOS update, but after auto restart there is no update screen. Nothing happen.
                      I have tried using this DUMP but with no go,
                      https://www.badcaps.net/forum/troubl...os#post3210916
                      My winbond BIOS chip got fried as well after 4th attempt, now it is unsoldered and I am waiting for...
                      07-17-2025, 02:14 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
