For Asus X555LJ-XX013D bios dump please !
  • digix
    • Nov 2013
    • 19
    • România
  • peste
    • 13176
    • ROMANIA
    Re: For Asus X555LJ-XX013D bios dump please !
    post the original laptop bios
    • digix
      • Nov 2013
      • 19
      • România
      This is the original laptop bios
      • qayyum786
        • Aug 2018
        • 1939
        • INDIA
        this is the original laptop bios
        try
        • digix
          • Nov 2013
          • 19
          • România
          Now charges the battery but does not start.
          • qayyum786
            • Aug 2018
            • 1939
            • INDIA
            check hardware requirements
            • peste
              • 13176
              • ROMANIA
              try this too
              • ambet22
                • May 2018
                • 22
                • Philippines
                Originally posted by qayyum786
                try
                thanks a lot bro
                • 114MAREKR
                  • Sep 2022
                  • 6
                  • polska
                  Originally posted by peste
                  try this too
                  Works ASUS X555lj
                  • JoWed
                    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                    by JoWed
                    Hello Community,
                    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                    07-01-2025, 09:32 AM
                  • alphabetty
                    novice user attempting first BIOS write on ASUS laptop
                    by alphabetty
                    Hello first post!
                    Ok so after an (ASUSTek) optional Windows update, my old ASUS E403NA laptop rebooted and froze in the BIOS menu screen and was unresponsive so after about 30 mins I powered off and back on again. Now i just get a power LED and a black screen, I have tried all the basic suggestions and all the suggestions on the ASUS site, spoke to ASUS support who said I will need to pay for an RMA.
                    The laptop is worth €50 so I won't be doing the RMA at god knows what price.
                    So I have seen some videos where people have reprogrammed the BIOS...
                    03-07-2024, 08:31 AM
                  • vixeko_
                    Problems with the asus x456ua laptop bios chip
                    by vixeko_
                    They asked me to change the HDD to an SSD on this Asus laptop, in case the laptop already had problems such as it not turning on every time and the battery charge lasting very little.
                    and perform the task successfully and clone the data from the hdd to the new ssd
                    I managed to start windows on the ssd and everything was normal so I decided to restart it to measure the startup speed and when I did that instead of starting windows the laptop sent me to the bios
                    I exited the bios to continue to windows but when the laptop turned off it did not turn on again, it was strange but...
                    10-19-2023, 06:36 PM
                  • Technodoc
                    ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                    by Technodoc
                    Asus laptop G614JZ-N3012W Rog Strix with i7
                    Mainboard G634J-PMV-VGT
                    6050A3441302-MB-A01
                    2023-02-10
                    Power button works okay....power light goes on
                    Red "bottom" leds go on
                    Charging led works
                    Fans do not spin, capslock key does nothing, screen stays black
                    I would like to program the bios again, to rule out a corrupted bios.
                    However I run into a size error
                    The bios chip is a Winbond 25R256JVEN
                    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                    02-24-2025, 04:46 AM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
