HELP ME TREAT THIS BIOS FILE HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
Re: HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs. -
Every donation made will go towards server fees and maintenance costs.Comment
There is a laptop with the same problem, before entering the BIOS and in the BIOS itself, the keyboard and touchpad work, immediately after exiting the BIOS they stop working, the laptop came with an embedded BIOS, there is a strong suspicion that the problem is in the BIOS, possibly in DMI or some kind of protective chip , tried different dumps - it doesn't helpComment
There is a laptop with the same problem, before entering the BIOS and in the BIOS itself, the keyboard and touchpad work, immediately after exiting the BIOS they stop working, the laptop came with an embedded BIOS, there is a strong suspicion that the problem is in the BIOS, possibly in DMI or some kind of protective chip , tried different dumps - it doesn't helpDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Все как у автора темы, HP 640 G1 6050a2566302Attached FilesComment
No changes, laptop works as well + asks for DMI data. I have doubts that the dump is native, although the serial number from the dump matches the number on the case, but there are traces of soldering on the BIOS chip.Comment
what is the termination of the motherboard "mb-a04" or 'mb-a03 "???Attached FilesLast edited by peste; 08-04-2021, 11:45 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
bios extracted from dead motherboardAttached FilesComment
This is HP ProBook 640 G1
Part No : 6050A2566302-MB-A04
PCID : A3009DD10303
SERIAL NO : 5CG6164WMB
problam No Display and High Speed fan Spining.
attached Dump file
plz share good working file plzComment
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
Good night everyone,
My problem seems to be strange and i didn't found anything on the internet so here it is if someone have faced it and could help.
It is a Lenovo Legion Y520-15IKBN that have some keys on the keyboard not functioning ( E , G , H , 8 , 9 , FN , ....) so i thought that it is a keyboard problem, i ordered a new one and replaced it , at first night it worked perfectly the second night those keys were not functioning but when i press one of them 5 or 6 times they function again i restarted the laptop sometimes works sometimes not sometimes i press several times so... -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... - Loading...
