HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
  • nik nik
    • Dec 2017
    • 20
    • nigeria
    HELP ME TREAT THIS BIOS FILE HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
  • peste
    • Dec 2016
    • 12973
    • ROMANIA
    Re: HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
    try..
    • nik nik
      • Dec 2017
      • 20
      • nigeria
      is still the same thing no changes
      • peste
        • Dec 2016
        • 12973
        • ROMANIA
        check keyboard, I/O chip
        • Kruglec
          • Sep 2019
          • 30
          • Rossia
          There is a laptop with the same problem, before entering the BIOS and in the BIOS itself, the keyboard and touchpad work, immediately after exiting the BIOS they stop working, the laptop came with an embedded BIOS, there is a strong suspicion that the problem is in the BIOS, possibly in DMI or some kind of protective chip , tried different dumps - it doesn't help
          • peste
            • Dec 2016
            • 12973
            • ROMANIA
            post the backup of the bios as it is, the name and the complete model of the laptop, the model of the motherboard.
            • Kruglec
              • Sep 2019
              • 30
              • Rossia
              Все как у автора темы, HP 640 G1 6050a2566302
              • Kruglec
                • Sep 2019
                • 30
                • Rossia
                And yet, tell me where to get a photo of the board in good quality, there are traces of soldering on one resistor, I want to make sure that it is in its place
                • peste
                  • Dec 2016
                  • 12973
                  • ROMANIA
                  try..
                  • Kruglec
                    • Sep 2019
                    • 30
                    • Rossia
                    No changes, laptop works as well + asks for DMI data. I have doubts that the dump is native, although the serial number from the dump matches the number on the case, but there are traces of soldering on the BIOS chip.
                    • peste
                      • Dec 2016
                      • 12973
                      • ROMANIA
                      try this too..it has a functional bios at its origin ..
                      what is the termination of the motherboard "mb-a04" or 'mb-a03 "???
                      • Kruglec
                        • Sep 2019
                        • 30
                        • Rossia
                        Everything also does not work, for me mb-a02. Can you help with the photo of the board? near the hub and RTC battery
                        • peste
                          • Dec 2016
                          • 12973
                          • ROMANIA
                          try..
                          • Kruglec
                            • Sep 2019
                            • 30
                            • Rossia
                            Nothing has changed, most likely the problem is still in the hardware, thanks for helping
                            • Kruglec
                              • Sep 2019
                              • 30
                              • Rossia
                              Replacing the hub and removing the TPM chip helped, removing the TPM separately did not help
                              • abdelilahocs
                                • Nov 2018
                                • 119
                                • morroco
                                bios extracted from dead motherboard
                                • chandrank
                                  • Sep 2021
                                  • 3
                                  • india
                                  goooddddd okkkkk thanks
                                  • Doniciputat
                                    • Aug 2022
                                    • 110
                                    • Indonesia
                                    thanks master
                                    • blacky.mhretab@gmail.com
                                      • Sep 2023
                                      • ethiopia
                                      tnx
                                      • prasath_max
                                        Technician
                                        • Feb 2020
                                        • 33
                                        • Sri Lanka
                                        This is HP ProBook 640 G1
                                        Part No : 6050A2566302-MB-A04
                                        PCID : A3009DD10303
                                        SERIAL NO : 5CG6164WMB
                                        problam No Display and High Speed fan Spining.
                                        attached Dump file
                                        plz share good working file plz
                                        • ladharimohamed2
                                          Laptop Keyboard problem and it is not the keyboad!!!
                                          by ladharimohamed2
                                          Good night everyone,
                                          My problem seems to be strange and i didn't found anything on the internet so here it is if someone have faced it and could help.
                                          It is a Lenovo Legion Y520-15IKBN that have some keys on the keyboard not functioning ( E , G , H , 8 , 9 , FN , ....) so i thought that it is a keyboard problem, i ordered a new one and replaced it , at first night it worked perfectly the second night those keys were not functioning but when i press one of them 5 or 6 times they function again i restarted the laptop sometimes works sometimes not sometimes i press several times so...
                                          04-20-2023, 05:09 PM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
