Dell Latitude 5410 Bios Password 8FC8
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #421
    Re: Dell Latitude 5410 Bios Password 8FC8
    Originally posted by Audux
    Hello. Can you unlock password on Dell Inspiron 5501 (8FC8)?
    BIOS:
    ME:
    Look at the thread title.
    Read the rules before posting:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • jagg
      • Feb 2012
      • 30
      • Mexico
      #422
      Hello, can someone remove the password from this bios?
      Dell 5410
      LA-J371P
      Service Tag: 8PXV793
      Express Service Code: 18982796151
      here are the 2 bios, I don't know which one contains the password.
      thank you so much !!
      • volinakis
        • Jan 2021
        • 2744
        • N/A
        #423
        Dell 5410
        LA-J371P
        1st boot, press F2, write service tag, disable Absolute, save (Apply Changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
        • jagg
          • Feb 2012
          • 30
          • Mexico
          #424
          Thanks for the answer volinakis, I just programmed the bios and when I turn on the laptop it only turns on the fan at maximum speed, it does not give video and it always restarts, what can I do? Thank you !!
          • volinakis
            • Jan 2021
            • 2744
            • N/A
            #425
            let it run for 2 minutes.
            • jagg
              • Feb 2012
              • 30
              • Mexico
              #426
              Hello volinakis, I did it, I left the laptop on for more than 5 minutes and it does not exit the loop, it does not show video and the fan is at maximum power.
              • volinakis
                • Jan 2021
                • 2744
                • N/A
                #427
                check if you did solder both bios chipsets properly. Modification of bios is ok, I double-checked. It should work. Modify only XM25QH64C and put back the other one as is.
                • Erick D
                  • Jul 2023
                  • Argentina
                  #428
                  Hello can someone remove they password from this BIOS pls
                  Dell Latitude 5420
                  J3t06j3-8fc8
                  Thank you so much
                  • volinakis
                    • Jan 2021
                    • 2744
                    • N/A
                    #429
                    Dell Latitude 5420
                    J3t06j3-8fc8
                    Thank you so much
                    you have to upload your bios dump if you want to get help, read the rules and all posts in this thread starting with #1.
                    • jagg
                      • Feb 2012
                      • 30
                      • Mexico
                      #430
                      Hi volinakis, it's working now! You were right, the problem was a bad soldering on the chip , the laptop is now without a password, thank you very much, God bless you!!
                      • volinakis
                        • Jan 2021
                        • 2744
                        • N/A
                        #431
                        thank you, enjoy!
                        • trlmaster
                          • Feb 2017
                          • Hungary
                          #432
                          Hello everyone! Please I need to unlock DELL Latitude 5410 BIOS, here is the dump! Thanks a lot!
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #433
                            1st boot, press F2, write service tag, disable Absolute, save (Apply Changes), restart. 2nd boot press Alt+F to exit manufacturing mode. Let it run for 2minutes, it will restart several times with no display.
                            • trlmaster
                              • Feb 2017
                              • Hungary
                              #434
                              Dear Vesko! It works, you are fantastic! Thank you very very much!
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #435
                                You're welcome. Happy to help, enjoy your unlocked laptop.
                                • lukasis
                                  • Jan 2021
                                  • Polska
                                  #436
                                  Originally posted by aldopc
                                  Ok, test and comment.
                                  Start is ok but laptop has pass on bios
                                  • fhnsrdhesgeb
                                    • May 2021
                                    #437
                                    Could someone please help with this?
                                    Thank you!!!!!
                                    • kumarchennupati
                                      • May 2020
                                      • india
                                      #438
                                      i need dell 5410 Bios Password help below is the service tag
                                      7YPXW33-8FC8
                                      can you please help
                                      • volinakis
                                        • Jan 2021
                                        • 2744
                                        • N/A
                                        #439
                                        Originally posted by kumarchennupati
                                        i need dell 5410 bios password help below is the service tag
                                        7ypxw33-8fc8
                                        can you please help
                                        follow steps described in post #433
                                        • kumarchennupati
                                          • May 2020
                                          • india
                                          #440
                                          Thank You
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 5410 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5410 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5410 boardview and 5410 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5410...
                                            09-06-2024, 08:10 PM
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                            09-07-2024, 03:10 AM
