need bios la-e331p
  • chandrakant
    • Nov 2017
    • 39
    • india
    need bios la-e331p
    need bios la-e331p
  • peste
    • Dec 2016
    • 13809
    • ROMANIA
    Re: need bios la-e331p
    post the original bios, laptop, model, motherboard, etc
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Dell XPS 15-9560 CAM00/01 LA-E331P
      Hi to all
      May I have a request for this Bios bin File this Unit
      Unit Brand Model and Mobo Part no.
      Dell XPS 15-9560 CAM00/01 LA-E331P BIOS
      Also i Confused for the Following ROM Or Bios Chip
      UT2_W25Q80
      UT5_W25Q32
      UH8 W25Q256
      Which one is a Main. I guess Only UH8. also I dont have a Socket Slot Kits
      for Frashing this Type of ic. but i know howto identify the Pin out. also may i know if the RT809F Can support This type of Bios CHip?
      other info about this Laptop. Problem is Auto off, i press the Power Switch . Light indicating then the Device Turn on no display . fan spinning Normal then about 9 to 10 sec. turn in off.
      TIA
        • 22170
        Re: Dell XPS 15-9560 CAM00/01 LA-E331P
        Bios - https://www.alisaler.com/dell-xps-95...e331p-bios-ec/
        Schematic - https://www.badcaps.net/forum/showthread.php?p=946795
        EDIT: the schematic is for the LA-C361P ,not LA-E331p
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          Thanks Boss
          • eng.umair.a
            • Jun 2016
            • 82
            • Pakistan
            Dell m5520 bios needed
            Plz i need working bios of this MB thanks in advance.
            Part no. CAM00/01 LA-E331p rev 2.0
            Dell precision M5520
            • piszpunta
              • Jan 2019
              • 260
              • poland
              Re: Dell m5520 bios needed
              post the oryginal bios
              • eng.umair.a
                • Jun 2016
                • 82
                • Pakistan
                Dont have original bios some other technician erased orginial bios
                • eng.umair.a
                  • Jun 2016
                  • 82
                  • Pakistan
                  No one can help?
                  • eng.umair.a
                    • Jun 2016
                    • 82
                    • Pakistan
                    • lapfix
                      • Mar 2020
                      • 2765
                      • my workshop
                      Your serial !
                      • eng.umair.a
                        • Jun 2016
                        • 82
                        • Pakistan
                        Serial?
                        • lapfix
                          • Mar 2020
                          • 2765
                          • my workshop
                          yes , you find it at the backup
                          • bilen
                            • Aug 2014
                            • 637
                            • istanbul
                            Need la-e331p rev 1.0 bios
                            Model : Dell xps 15 9560
                            motherboard code : LA-E331P REV 10 (A00)
                            Please clean me bios dump.
                            orginal bios no screen :
                            • Mazorca
                              • Jan 2017
                              • 463
                              Re: Need la-e331p rev 1.0 bios
                              Try and reply please
                              • bilen
                                • Aug 2014
                                • 637
                                • istanbul
                                not working
                                • peste
                                  • Dec 2016
                                  • 13809
                                  • ROMANIA
                                  try..
                                  • eng.umair.a
                                    • Jun 2016
                                    • 82
                                    • Pakistan
                                    how can i find it in bios? what should i search in HxD?
                                    • eng.umair.a
                                      • Jun 2016
                                      • 82
                                      • Pakistan
                                      i found 1 bios which worked but laptop was turning off in 15 to 20 seconds, i tried reprogramming ec but then same issue came up NO Display
                                      • lapfix
                                        • Mar 2020
                                        • 2765
                                        • my workshop
                                        Try to clean me this bios
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
