Hedwig-6050a2992901-MB-A02(A2)
    Hi! Got this bios.
    ME analyzer says it has no Intel Image.
    UEFI Analizer first tells me UEFI volumes not found.
    Then shows me Description, ME and BIOS Region.
    But there's no Filesystem Inside BIOS Region.
    I found on internet Another dump, but it will clear my SKU and other things won't it?
    Here are the Dumped File (Original.bin) and the Internet File.
    Can you help me figuring out how to repair this Bios File? Or what should I do?
    Re: hedwig-6050a2992901-mb-a02(A2)
    Originally posted by lazaro.089 View Post
    Hi! Got this bios.
    try it and please report
      Original dump is mostly empty. It's probably not being read properly. Get a proper dump before flashing anything.
        Try it but didn't work
        Tried to dump it continuously but it's the same result.
        I flashed qonma dump on another chip, maybe original chip is faulty?
          i think the chips no problem...only not matching from bios and mainboard
            I've tried several now.
            But it's the same result. The laptop tries to turn on, fan spins, LCD powers up (change from off state to on) then laptop powers down.
            No liquid damage. The laptop is practically new. But customer can't return it to warranty.
            What should I check then?
              Hp 14-cf008ca Hedwig-6050a2992901-MB-A02(A2)
              Today I am working on the Hp 14-cf008ca motherboard Hedwig-6050a2992901-MB-A02(A2) .. Does anyone have the working BIOS for this model.. I am uploaded the Original dump, hopefully someone can fix for me. Thanks
                Re: Hp 14-cf008ca Hedwig-6050a2992901-MB-A02(A2)
                try...
                  Thank you., re-programmed the BIOS chip., The DC--in jack LED lights up but still no display.. when turned on the fan spin very fast for about 30 sec & then the motherboard shuts down by itself & does not turn on again. Then I turn on again same status.. Any further clues will be helpful. Thanks
                    try..
                      Thank you very much... will try today & inform you...
                        Still the same.... I think there is a problem with the motherboard, anyway I have ordered a new board, got it cheap, Thank you so much "PESTE" for all the help..
                          Originally posted by peste View Post
                          try..
                          Thanks Peste & everyone to know that this BIOS Dump is 100% working fine. No Display Notebook just woke up with this dump.. Thanks
                            thank you....100% working...
                              hp 14-cf0018ca hedwig-6050a2992901-mb-a02(A2) bios ?
                              HP 14-cf0018ca that powers on however does not display and image and cycles on and off. External monitor used same result. unit has no signs of liquid damage. Removed memory and no change or codes. I have attached the extracted BIOS. Please help provided updated bios.
                              thanks in advance
                                Re: hp 14-cf0018ca hedwig-6050a2992901-mb-a02(A2) bios ?
                                thanks in advance
                                HP Notebook - 14-cf0018ca
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  Thank you for the help!
                                    laptop model - hp 14-cf0057tx
                                    motherboard part number-hedwig 6050a2992901-mb-a02(a2)
                                    plz provide me the working bios
                                      Do you have a backup
                                        here is the backup bios
