Microsoft Surface Pro 7 NEED BIOS. HELP!
  • pauloliver
    • Nov 2017
    • 3
    • derby
    #281
    can help me to clean my bios password?
    Thanks and Advance...
    Model Microsoft Surface Pro 7
    Model Number 1866
    Serial Number 038664103253
    Board ID JALAMA_ICL_MB DV :20B
    Badcaps Electronics Repair Forum & Schematic Search
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    #282
    Model Number 1866
    use "Upload Attachements" tab to upload your bios backup, not external site. Use winzip or winrar to compress it.
    • pauloliver
      • Nov 2017
      • 3
      • derby
      #283
      Model Number 1866
      • volinakis
        • Jan 2021
        • 2875
        • N/A
        #284
        Model Number 1866
        try
        • DNAGSM
          • Jun 2023
          • 20
          • Algeria
          #285
          Model Microsoft Surface Pro 7 Plus
          Model Number 1960
          Serial Number 041778104953
          Board ID MP5 W MB REV: J
          Originally posted by hoaca388
          Unlocked
          no working , after pressing the power button, a logo appears and then turns off
          After changing bios ic
          How to fixe this problem
          Click image for larger version Name:	IMG20240622230454.jpg Views:	0 Size:	5.15 MB ID:	3295375
          Is there a solution or other modification to Bios?​
          • dolku
            • Aug 2020
            • Switzerland
            #286
            HI Friends,
            Does anybody has surface pro 7 Clean Bios version 13.0 Please
          • Prott
            • May 2022
            • 154
            • Czechia
            #287
            Hello Badcappers,
            could you please help me with fixing this bios for my surface pro 7? It starts up, but can't see the internal SSD drive and - after booting from an external one - has problems with ME (version 0.0.0.0 and shows as not working correctly in the device manager).
            Model: 1866/i5/8 GB (JALAMA_ICL, REV: 2.0B)
            SN: 049321294453
            Thank you!
            • volinakis
              • Jan 2021
              • 2875
              • N/A
              #288
              try
              • ACHRAFJIRANI
                • Apr 2018
                • 65
                • MOROCCO
                #289
                pls bios password
                surface pro 7
                SN: 061706104153
                model: 1866 i5/8/256
                • volinakis
                  • Jan 2021
                  • 2875
                  • N/A
                  #290
                  Originally posted by ACHRAFJIRANI
                  pls bios password
                  surface pro 7
                  SN: 061706104153
                  here. You also had enrollment and Auto-Pilot enabled.
                  • Prott
                    • May 2022
                    • 154
                    • Czechia
                    #291
                    Originally posted by Prott
                    Hello Badcappers,
                    SN: 049321294453
                    Thank you!
                    Can somebody please point me to any direction as to how fix the non working drive internal drive? I am pretty sure it's a BIOS issue, as I soldered the drive correcty (checked all the connections with multimeter afterwards and made sure there's a connection), yet the machine doesn't see any drive at all. I will be ethernaly grateful for any tips, cause this is the only thing that's keeping this machine from fully working. :/
                    Is there a setting that I can change in FIT to try and fix this issue or is it just a corrupted firmware file? Or can an "invisible drive" be caused by the ME region not working?
                    • hatemkobicy
                      • Dec 2023
                      • Netherlands
                      #292
                      Model Number 1960
                      Serial Number 000865922253
                      please unlock this
                      • volinakis
                        • Jan 2021
                        • 2875
                        • N/A
                        #293
                        Model Number 1960
                        please unlock this
                        you also have enterprise enrollment and auto-pilot activated. only unlocking won't help.
                        • fixed4ucy
                          • Nov 2017
                          • 17
                          • cyprus
                          #294
                          hi
                          I have locked bios can you help me?
                          • piszpunta
                            • Jan 2019
                            • 260
                            • poland
                            #295
                            Write this file and enter Password : 12345678
                            • fixed4ucy
                              • Nov 2017
                              • 17
                              • cyprus
                              #296
                              ​hi i tried the unlocked bios but it powers for 3 sec and then shuts down
                              any suggestions
                              • franklinogot
                                Super Member
                                • Oct 2023
                                • 26
                                • Philippines
                                #297
                                any suggestions
                                Here. Try this
                                • fixed4ucy
                                  • Nov 2017
                                  • 17
                                  • cyprus
                                  #298
                                  Hi guys
                                  powering for 5 seconds and shutting down
                                  please can anyone help me?
                                  • bvu
                                    • Jul 2023
                                    • 22
                                    Please help fix my bios. Unit turns on, has logo for a few seconds then turns off and repeats in a loop. Thanks!
                                    Model: 1866 Surface Pro 7
                                    SN: 001533204253
                                    • volinakis
                                      • Jan 2021
                                      • 2875
                                      • N/A
                                      #300
                                      hi
                                      try
