Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Microsoft Surface Pro 7 / 7+ NEED BIOS. HELP!
  • payam
    replied
    Hello, after extracting this BIOS file, when we put it back on the device, the touch no longer works, even though it worked before and we didn't make any changes.
    surface pro 7 (1866)
    sn:002623112153
    Premium supporters get full download access and other benefits.
  • MrGamecase
    replied
    Need a gut check before I go barking up the wrong tree, I recently reformatted my Surface Pro7 (upgraded from 10 to 11).
    I had driver issues... no touchscreen, Windows hello facial, Tpm .etc.etc so I went to ms website and downloaded the SurfacePro7_Win11_22621_25.090.3489.0.msi package and installed. everything went fine it recognised everything but the firmware section of device manager gave me a load of orange triangles & error (14) reboot to finish setup.
    I rebooted and got the windows logo with the writing
    system updates are underway please keep your device plugged in. This was on screen for all of a second before the whole screen turned off and the system fans began ramping up and down.....
    left it like this for 48hours.... Was I the end forced to reboot the device, Windows came back up OK but with the same errors... and black lines flickering all over the screen, I reformatted the device again with Ms official recovery image or the pro7 thinkg it would restore the device but I still have the same errors with the firmware section.....if I go into the bios I see the version numbers just fine
    SAM - 14.104.139
    IME - 10.8.1560.0
    TF - 3.1.59.139
    PDC - 3.6.1
    dTPM - 7.2.1.0
    SUEFI - 8.123.140
    secureboot disabled & no management installex
    is this a FW issue / would flashing the uefi.bin from SurfacePro7_Win11_22621_25.090.3489.0.msi fix the issues??.....
    I don't want to pull the surface apart unless I have to
  • JasiqiLabeat
    replied
    ^hi guys, i need your help with a surface 7 pro bios here, i have this device and the error is shows logo for 2-3sec and shuts down, charges normaly.
    if somebody here is kind eenough to repair this bios would helped me a lot , here are the specs
    1866
    256gb
    042225604353
    thank you
  • virusok
    replied
    Originally posted by virusok
    I tried this one too, no luck, same behaviour. I tried like you editing variables, no luck, it seems like need to edit something like crc, or some hash after edit, it seems like it verifi the integrity before start, another member gave me a version virh no nvram, it starts but no sn, dmi and ssd.
    Hi fellows, can anyone help me find a soletion on my problem? Please help.
  • virusok
    replied
    Originally posted by Sparo
    Try this one next, you're in the wrong thread btw
    This thread is for Surface Pro 5, NOT Surface Pro 7+ so your post will be moved there
  • Sparo
    replied
    Tried, it does not start, at all, only logo for 2-3 sec
  • virusok
    replied
    Hi try this modification first
  • Sparo
    replied
    Hi everyone, can anyone help disable dfci from surface pro 7+ 1960 bios dump,
    Surface pro 7+ 1960 SN-029576614453
  • virusok
    replied
  • shiyab
    replied
    Dfci enabled, autopilot, semm or how it is called
    post issu pic
  • virusok
    replied
    Originally posted by shiyab
    issu? bios password ?
  • shiyab
    replied
  • virusok
    replied
  • adamgouadma
    replied
    hi try
    Thank you very much
  • shiyab
    replied
    Originally posted by adamgouadma
    microsoft surface pro 7 with efi password model is:1866 with128gb storage ....serial num is:033731405153 ...help me remove password
    hi try
  • adamgouadma
    replied
  • virusok
    replied
    Thanks for trying to help me, but no luck, no ssd and me 0.0.0.0
    Hi fellows, is there any chance ti fix it?
  • virusok
    replied
    Originally posted by SMDFlea
    try
    replied
    Hi everyone, can someone help cleaning or remove Microsoft intune management from bios , surface pro 7+ 1960, I flashed the bios that shiyab gave but there's no DMI , no ssd support
    The dump i uploaded earlier
    try
  • virusok
    replied
