Microsoft Surface Pro 7 / 7+ NEED BIOS. HELP!
  • trepachka
    • Oct 2022
    • 524
    Hello, I have this Microsoft Surface 7 Pro that's stuck @ Windows logo. Could someone, please fix bios contents for it?
    Microsoft Surface 7 Pro 1866
    S/N 020671500753
    The original bios is attached. Thank you.
    • blcksmthprnt
      • Nov 2023
      • 14
      • Ukraine
      #242
      S/N 020671500753
      try first 1. if it doesn't work try 2. if it doesn't work try 3. if it turns on then write and we'll think about what to do next
      • ACHRAFJIRANI
        • Apr 2018
        • 66
        • MOROCCO
        #243
        can anyone clear the password for this Surface 7 pro 1866 please?
        SN:082637295253​
        • volinakis
          • Jan 2021
          • 3231
          • N/A
          #244
          SN:082637295253​
          try
          please support this forum
          • ACHRAFJIRANI
            • Apr 2018
            • 66
            • MOROCCO
            #245
            Originally posted by volinakis
            try
            thinks bro
            • Prott
              • May 2022
              • 154
              • Czechia
              #246
              can somebody please help me with my Surface Pro 7 BIOS? It's having ME problems (bios showing ME version 0.0.0.0) + it is unable to boot from SSD or flashdrive (and sometimes it doesn't boot at all). Thank you SO much!
              PS: It is interesting that the working Rev 1 board BIOS that I have from a previous post is not working on the Rev 2 board.
            • Prott
              • May 2022
              • 154
              • Czechia
              #247
              My apologies. Please help me fix this bios for Surface Pro 7 (ME error, can't boot from any drive / usb stick, sometimes doesn't boot at all). I can get into UEFI without problems, but it still does not want to boot past that no matter the settings.
              Model: 1866 (i5/8/128)
              SN: 049321294453
              Board revision: 2.0B
              Thank you.
              • Smeek
                • Sep 2021
                • 66
                • România
                #248
                Please can be clear the BIOS restriction of boot from USB and password for this Surface 7 pro 1866 ?
                SN: 066583701453​
                • Kabbutino
                  • Apr 2024
                  • Europa
                  #249
                  Hi, i've got a problem with my surface pro 7, After i install hackintosh on It, my PC shows the Windows logo and immediately It turn off. How can i resolve this problem? In this Moment Is on a repair shop and they changed the chip of the bios but nothing It won't boot.
                  • dutchgaucho
                    • 75
                    • The Netherlands
                    #250
                    Hello there, I'm having a Surface Pro 7 that turns on for 4 seconds an then shuts down. I've tried Peste's BIOS (posted in #8) and it works but touch is not working and DMI data obviously does not match. Could somebody fix mine?
                    Thanks!
                  • dutchgaucho
                    • 75
                    • The Netherlands
                    #251
                    Sorry for that. The serial number is 024073501453.
                    • minhdigital
                      • Nov 2022
                      • 778
                      • Vietnam
                      #252
                      Send to you
                      • dutchgaucho
                        • 75
                        • The Netherlands
                        #253
                        Originally posted by minhdigital
                        Send to you
                        Awesome! You're the best. Working flawlessly. Thanks!
                        • Kabbutino
                          • Apr 2024
                          • Europa
                          #254
                          Hi, Is possible do a CPU swap from a motherboard to another motherboard? Because my surface has the problem compare the logo for 3 seconds and shut down immediately and i change the bios chip but the bios won't boot. Any suggest? Plz Is very important to me this surface
                          • Prott
                            • May 2022
                            • 154
                            • Czechia
                            #255
                            Hi, there can be multiple reasons why Surface won't boot. It can be any hardware fault preventing the Surface from finishing the power on sequence. Desoldering a CPU is the absolutely last resort when everything else fails (and is usually not even economical due to the cost of the CPU itself as well as the time spent on the exchange).
                            I would suggest to:
                            1. Check the resistance of all the coils - is there any that's low?
                            2. Find the power on sequence in the schematics and measure all the signals in order to see where the sequence stops. Then you can narrow it down to a specific portion of the board that doesn't work.
                            Hope that helps.
                            • Kabbutino
                              • Apr 2024
                              • Europa
                              #256
                              The First problem i think was the bios because when i do hackintosh It Is fxked and i think if i find a new motherboard when all components works and the same for the bios i think tò do a swap but idk
                              • Prott
                                • May 2022
                                • 154
                                • Czechia
                                #257
                                Did you try the bios from minhdigital​? That one is working for me. Also:
                                - What programmer are you using?
                                - Are you desoldering the bios chip or programming in place?
                                - Did you first cleared the chip before programming and verified it afterwards?
                                • Kabbutino
                                  • Apr 2024
                                  • Europa
                                  #258
                                  1) idk because my surface Is at a repair shop
                                  2) yes, he changed the chip
                                  3) i think yes
                                  • Prott
                                    • May 2022
                                    • 154
                                    • Czechia
                                    #259
                                    I guess at this point is more about what the repair shop can do. Swapping a CPU won't be a cost effective option. Like you said, swapping the motherboard for a fully functional one might be the best bet.
                                    • Leinad78
                                      • Apr 2024
                                      Good Evening Guys,
                                      second post in this amazing resource-based forum.
                                      Unfortunately my Surface Pro 7 broke on me with the draided boot-lope problem. I already tried disconnecting the battery, but no chance. I desoldered the Bios successfully and read it with NeoProgrammer. I´d be super happy if anyone could take a look at that file to find out what could be causing the issue.
                                      The machine is a 1866 with 8Gb/128Gb config and serial number 026001512653.
                                      Thanks in advance
