guys i still have problems with FIT tool. i want to clean me in T460s bios but FIT wont open bios still the same error with all bioses
Maybe that helps I have a Lenovo T460s BIOS file with Me Clean.
EDIT: Do NOT flash this bios !! . Firmware cleaned with Intel ME/TXE injector does not keep the OEM`s original ME/TXE configuration. Open this bios with Flash Image Tool (attached) and the bios at post #87 with FIT 11 (copy FIT to 2 seperate folders with each bios) and compare the differences.
Its no good cleaning the ME that way,it has not kept the OEM`s original configuration. There is no boot guard ,no OEM public key hash,no Firmware update OEM ID .
I can tell by looking at your picture that you`re trying to open a G50-70 bios with the wrong FIT version. See the attached picture the G50-70 bios opened with MEAnalyzer,the ME firmware is version 9.5 ,so you need to use FIT from the "Intel ME System Tools v9.5" .The T460s does have ME 11 ,so open it with FIT from the Intel CSME System Tools v11
Hello, thank you for the tip, you never stop learning.
I created this file again on your white.
Now I don't know if it's correct.
Please delete my wrong file so no one gets hurt.
Many greetings
Many greetings
Ive left the bios at post #84 and added a note not to use it. This new bios cleaned with FIT looks ok to me,it has kept the original configuration.
Thanks for clearing it up. i dont know that FIT is from that tools with many versions.
so i need to first check me version and by that use correct FIT version?
Yes thats right. Hre`s the link at win-raid https://winraid.level1techs.com/t/in...ols-2-15/30719
Scroll down the page to: C2. (CS)ME System Tools .Click on one of those tools links and it`ll take you to mega. Check back there every few months to see if there`s a newer version of the tools.
You can run into a few issues sometimes trying to open a bios with an older version of FIT than what it was built with,ME 11 and under seems to be ok,its 12 and above that can be problematic.MEAnalyzer will tell you which version of the tool it was built with,that exact version might not even be available. Ive got 3 different versions of the "Intel CSME System Tools v12" ,r10 r14 and r21 ,each one has a "Tools Version Info.txt" file with a build number for each tool. The r10 FIT version is 12.0.6.1120 ,r14 FIT version is 12.0.22.1310 and r21 FIT version is 12.0.49.1536 .
If i have a bios doesn`t open with one version i try the others,if it doesn`t open with any then its probably because the bios or ME firmware is corrupt.
Reason: edited winraid link
Hello SMDFlea,
is it possible that the bios file is defective?
With this Lenovo X1 Carbon 5th, the touchpad does not work under Windows 10 at any time.
Maybe it has something to do with the bios file.
Thank you very much
Hello SMDFlea,
Thank you very much
under windows many things not work. did u try ubuntu or other?
Hello, that's the amazing thing under Ubuntu 20.04 or Debian 10 the touchpad works without any problems.
Now I don't understand why not under Windows 10, the driver has already been reinstalled, nothing.
Many greetings
Hello SMDFlea,
Thank you very much
It looks like the bios didn`t build because you didn`t open the untitled.xml file before clicking on the build button.The bootguard warning should be yes.
Install lenovo thinkvantage and let it do the driver updates,you`re probably missing something like the serial io driver,have a look in device manager and see if theres any yellow triangles.Don`t trust windows to install all the drivers
Hello SMDFlea,
Thank you very much
Hello SMDFlea,
sorry for my mistake, I guess I loaded the wrong FIT from the internet.
I used the version from the Win-Raid Forum CSME System Tools v11 r44 and it works without any problems.
Many greetings
Hello SMDFlea
I have a question in the picture if I had this error in the ME Analyzer again when checking the BIOS file.
What does it mean now?
Error: MFS Data Page 402 > Chuck 1020 CRL-16 is INVALID !
Maybe you can explain that to me.
Thanks in advance.
Hello SMDFlea
Thanks in advance.
It means part of the ME FW is corrupt.If the bios opens and builds ok with FIT its fixed but sometimes it can be too corrupt and it won`t open.
Many greetings
Linux defaults to PS2 emulation if the HID/I2C/Smbus protocols are not found. So what you are seeing is basic PS2 emulation of the touchpad under Linux. That means the necessary HID device structures have not been integrated into the firmware when you modified the firmware.
