Thinkpad Yoga LA-A341P BIOS
  • lharvie
    • Oct 2018
    I bricked my thinkpad yoga i5 convertible 12.5in while updating the BIOS
    The only way to recover is to flash the BIOS
    I need a BIOS image file - can anyone help
  • lharvie
    • Oct 2018
    Re: Lenovo Thinkpad Yoga 14 - BIOS Dump - TPM Security
    Does anyone have a BIOS image for a ThinkPad Yoga
    Motherboard LA-A341P
    • lharvie
      • Oct 2018
      I found this for anyone else out there you might need it
      • slyevo
        • Jun 2011
        • 5
        Hi
        Could you possibly advise which chip is the bios chip on this board?
        Mark
        • mr.Data
          • Sep 2018
          • 74
          • Netherlands
          Programmed it on to the eeprom but the system keeps the password. Also the serial does not change.
          Do I need to flash another chip to remove the password?
          • okbalord
            • Jun 2017
            • 204
            • Algeria
            ty work"s for me
            OKBALORD
            • estabilito
              • Aug 2020
              • 54
              • poland
              Re: Thinkpad Yoga LA-A341P BIOS
              Any idea how to remove supervisor password from this motherboard?
              I flashed the bios and kbc but password is still here. Password is gone only if i remove the eeprom chip so i Think that the password is there but this is write protected chip and i cant do anything.
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1226
                • France
                LA-A341P : 2x bios and 24rf08 + EC
                LA-A342P : 2x bios and EC
                the 24rf08 or p24s08a reads very well, this eprom is not locked
                or bypass password with shunt on 24rf08 between scl and sda when backlight come and F1 to enter setup.
                • estabilito
                  • Aug 2020
                  • 54
                  • poland
                  It work's, thank you!
                  • Ariu
                    • Dec 2020
                    • 133
                    please clean me region, this bios dump is working but late Display....
                    • Ariu
                      • Dec 2020
                      • 133
                      already done it for the others that need it!_!
                      • axell02
                        • Aug 2016
                        • ROMANIA
                        i need dump to kb9012-A4 motherboard LA-A341P REV 1.0, can anyone help me please?
                        • jacospama
                          • Aug 2019
                          • 240
                          • Ghana
                          zips1 la-a341p rev 1a bios password reset
                          how can i clear password from zips1 la-a341p rev 1a
                            • 20961
                            Re: zips1 la-a341p rev 1a bios password reset
                            see post #8
                            • jacospama
                              • Aug 2019
                              • 240
                              • Ghana
                              Originally posted by SMDFlea
                              see post #8
                              thANK YOU
                              • corona100
                                • Mar 2020
                                • 145
                                • U.S.A
                                Lenovo LA-A341P REV 1.0 bios request
                                hello guys looking for lenovo LA-A341P REV 1.0
                                REV 1.0 Not the A1
                                • peste
                                  • 12835
                                  • ROMANIA
                                  Re: Lenovo LA-A341P REV 1.0 bios request
                                  REV 1.0 Not the A1
                                  post the full name and model of the laptop
                                  • m3troid
                                    • Aug 2022
                                    • georgia
                                    Could you highlight the scl and sda in an image, also what is the optimal way to shunt it to unlock password, as the chip is rather difficult to access if the full frame is assembled
                                    thanks -M3troid
                                    • m3troid
                                      • Aug 2022
                                      • georgia
                                      my apologies, images loaded after a reload of the page, images clarify very well.
                                      did you initially use the bioshunger bios to achieve unlocked password, i take it this one is not ME neutered, i can achieve this myself once i arrive home
                                      • m3troid
                                        • Aug 2022
                                        • georgia
                                        i tried shunting after i had succesfully used the bioshunger files to troubleshoot that indeed the bios chip was being problematic, i then neutered IME from the original bios files and got it to boot, however i could never get past the bios password so i tried shunting it, with what i assume is very bad success as my laptop no longer boots, the fan speeds up fast shutsdown the laptop and repeats this process 3 times blinking the power LED, my assumption is from the attached images that this process somehow fried my onboard ram as the chip itself looks to be visually fine but ram chips have weird wear in them
                                        any remedies to recommend for this process or is my laptop just toast at this point i am indeed waiting to get a multimeter at this point to zero in on possible issues
                                          Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 04:10 AM
                                        • Loki_Fido
                                          Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
                                          by Loki_Fido
                                          Hi everyone, hope everyone's having a great day.
                                          I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
                                          I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
                                          So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
                                          Does this mean the BIOS is fine? making it a hardware issue?
                                          I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
                                          03-14-2025, 07:42 PM
                                        • Maxpower3
                                          Brand name and Model Type for Lenovo error 2202 product name is invalid
                                          by Maxpower3
                                          Info for error 2202 LenovoThinkPad models and type
                                          Extract from ThinkPad Maintenance Utilities Configuration File
                                          plnsrv.ini Version 1.01
                                          Some information that may be useful
                                          There must also be missing models, add them to the list if you know of any.
                                          Code:
                                          brand name
                                          20B1=ThinkPad Edge E445
                                          20B2=ThinkPad Edge E545
                                          20BC=ThinkPad Edge E145
                                          20BM=ThinkPad X140e
                                          20BL=ThinkPad X140e
                                          20A3=ThinkPad X230s
                                          20AH=ThinkPad X230s
                                          20AK=ThinkPad X240s
                                          20AJ=ThinkPad X240s
                                          02-21-2024, 10:27 AM
                                          Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X13 Yoga Gen 2 (Intel) boardview and ThinkPad X13 Yoga Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 05:00 AM
