  • rumpumpel1
    • Jul 2019
    • 165
    • germany
    #1781
    Originally posted by Anorwgmla
    Before I do it, is anyone who can check my bios file which I uploaded and confirm that have the same problem with autopatcher?
    hereby confirmed
    • rumpumpel1
      • Jul 2019
      • 165
      • germany
      #1782
      Originally posted by esprugodoys
      Hi Flea! been reading this thread and the other one specifically for Lenovo T495 (FA495 NM-C131)..
      i performed your instructions on the 1st post, but did not seem to work. Black screen and some tones (somewhat like musical) is all I got along with fan spin. Got a bit anxious as I read a post from someone that even his backup dump was not able to restore the laptop's original state. Luckily though my backup dumps managed to restore it so I'm back to square one of having power-on bios password..
      any chance you could assist me on getting a good patch for this laptop?
      here's the backup dump that i used
      Starting with T490 the autopatcher will NOT work anymore.
      • AAAC
        • Jan 2020
        • 459
        • Mexico
        #1783
        There are a few exceptions, I have this T495 on my list of compatible models:
        ThinkPad T495 (TYPES: 20NJ and 20NK)
        @esprugodoys
        Have you tried to flash back Original BIOS in order to check that you have a “good” backup?
        • rumpumpel1
          • Jul 2019
          • 165
          • germany
          #1784
          Is there anyone who can give a detailed description on how to clear supervisor password on AMD based T14?
          • alaminp
            • Jan 2022
            • 21
            • saudi arabia
            #1785
            lenovo t480
            • esprugodoys
              • May 2018
              • 6
              • Philippines
              #1786
              @esprugodoys
              @AAAC
              yes. my backup dump is good, the one i attached on my previous post that is the backup that i used. laptop is back to its original state now which has a Power-On/bios password using that dump.
              this particular model is Type 20NK as indicated on the sticker at bottom cover.
              • skazide
                • Jul 2015
                • 144
                • morocco
                #1787
                success to patch x1 yoga 3rd gen with auto patcher thanks
                • AAAC
                  • Jan 2020
                  • 459
                  • Mexico
                  #1788
                  @esprugodoys
                  Can you go into Setup/BIOS? Power-on the laptop, press F1 key to go into Setup, when asked for password just press ENTER key, if it lets you get in (in read-only mode) go to Security and check Supervisor Password status.
                  • esprugodoys
                    • May 2018
                    • 6
                    • Philippines
                    #1789
                    @esprugodoys
                    I am not able to get in SETUP/BIOS (read-only mode).. as soon as I power it On, the "Bottom cover tamper detected" comes up after the Lenovo logo shows up.. which then prompts for a Fingerprint scan or the Power-On password.
                    Laptop just shuts down after 3 incorrect attempts on the password prompt.
                    since the Power-On password is enabled, it would be safe to assume that Supervisor Password is Active or Enabled?
                    • AAAC
                      • Jan 2020
                      • 459
                      • Mexico
                      #1790
                      @esprugodoys
                      Most probably it's the Supervisor Password Active, unless you haven't reset CMOS by disconnecting all source of energy and also disconnecting CMOS battery.
                      So if you Original BIOS is good and safely stored, have you tried to look for a T495 patched BIOS to try? This patched bios is only used for the unlock, after that you will use the Original BIOS.
                      • esprugodoys
                        • May 2018
                        • 6
                        • Philippines
                        #1791
                        @esprugodoys
                        update:
                        got it to work now.. just finished installing a new OS on it.
                        details i sent to your inbox.. Tnx a lot!
                        • Anorwgmla
                          • Aug 2022
                          • Poland
                          #1792
                          Originally posted by rumpumpel1
                          hereby confirmed
                          Hello again,
                          first of all thanks for checking my bios file.
                          Why Am I not able to patch it myself?
                          Still the same problem, autopacher works, there is information about new bios file created, but the file doesn't egsist in shown source.
                          Even I tried to patch someone's bios file updated on this forum - the same problem.
                          Software here: Wind10, Python 3.10.
                          • rumpumpel1
                            • Jul 2019
                            • 165
                            • germany
                            #1793
                            The X260 has a W25Q128FV as SPI Flash which is packaged as WSON8. Although the pins are visible as small bullets, there is no way to produce a dump by using a clamp. If you would have used a TL866II instead of a CH341A the programmer would have told you that there is a contact problem. I was not able to produce a dump even by using pogo pins. With WSON8 there is only one way: desoldering.
                            Lenovo stopped this stupidity and starting with the X270 they used again SO8 packaging.
                            For the patched BIOS you can use the binary of an arbitrary X260. But after removing the password you need your original BIOS, so you need a verfied dump. By verified I mean: produce as many dumps until two consecutive dumps are identical (fc /b dump-A.bin dunp-B.bin).
                            Good luck.
                            • novator_km
                              • Aug 2019
                              • 6
                              • Ukraine
                              #1794
                              hello need help
                              lenovo p52s patched bios supervizor password
                              • novator_km
                                • Aug 2019
                                • 6
                                • Ukraine
                                #1795
                                bios_old
                                • miansh621
                                  Banned
                                  • May 2022
                                  • 133
                                  • pakistan
                                  #1796
                                  Originally posted by novator_km
                                  bios_old
                                  STEP 1: Flash and replace current BIOS with the generated patch file
                                  STEP 2: Boot the machine
                                  STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                  STEP 4: Enter any character when asked for Supervisor Password
                                  STEP 5: Press enter when it shows Hardware ID
                                  STEP 6: Press space bar 2x when asked
                                  STEP 7: Turn off machine
                                  STEP 8: Restore original BIOS
                                  STEP 9: Reset BIOS settings to factory defaulT
                                  • novator_km
                                    • Aug 2019
                                    • 6
                                    • Ukraine
                                    #1797
                                    Thank you so much. )
                                    • corona100
                                      • Mar 2020
                                      • 155
                                      • U.S.A
                                      #1798
                                      i have X390 8th it's possible to unlock with AutoPatcher ???
                                      • corona100
                                        • Mar 2020
                                        • 155
                                        • U.S.A
                                        #1799
                                        this is my dump the autopatcher not working can any one deal with this dump please
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12441
                                          #1800
                                          Here.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
