  • loveUKnuckleGrumble
    • Feb 2026
    • France
    #4301
    Hello, i had the same problem as awena n the exact same device (e585 20kv r5 2500U)
    Originally posted by AWENA
    Hello, I have a problem with my Lenovo ThinkPad E585 laptop (AMD Ryzen 5 2500U). I have a problem at this point in the manual:
    STEP 4: Enter any character when asked for Supervisor Password
    When I press F1, a screen is shown asking me to enter the password (on a black background, like a command line) but the keyboard stops working, no buttons on the keyboard work. I also tried to connect a USB keyboard - unfortunately the same thing happened. I tried to turn off and try to repeat all the steps again and again several times - but unfortunately nothing has changed, the laptop seems to freeze. When I restore the backup bios, everything works fine in Windows 10, the keyboard works, the laptop works without any problems (but the password in the bios unfortunately remains and I can't reinstall Windows). I also tried the already patched dump from the forum (post hoaca388):
    https://www.badcaps.net/forum/troubl...s-dump-request
    But the result is the same, you can't enter the password on the patched bios. Maybe someone knows a solution, what am I doing wrong?
    ​ but by patching the bios attached by "big-boss1" from https://www.badcaps.net/forum/troubl...b531-bios-dump I managed to delete the password.
    Attached is the patched version.
    • olivettinho
      • Feb 2026
      • 9
      Lenovo X380 Yoga
      I really need help! I dumped the bios, all good. Patched it, all good. Flashed the patched one, all good. Did all the steps, all good. But when flashing the original bios again, suddenly the chip isn't recognized by the CH341A anymore, it always says IC not responding. Now when I turn on the laptop, the fan shortly spins and the keyboard backlight comes ip for a second, then nothing happens. What could I do? I do not have the equipment or ability to solder the bios chip.
      Kind regards,
      olivettinho
      • infino
        • Jun 2021
        • 15
        • Polska
        #4303
        Originally posted by olivettinho
        Lenovo X380 Yoga
        Kind regards,
        olivettinho
        Unfortunately, there are not many options in this situation.
        First of all, if possible, try to reflash the last BIOS dump that was known to be working. If the programmer still cannot detect the chip and reflashing is not possible, then there are two main possibilities:
        1. The BIOS chip itself may be damaged. In this case, the only real solution is to replace the chip with a new one that is preprogrammed with a correct BIOS dump.
        2. Carefully inspect the motherboard around the BIOS chip area. It is quite possible that during previous work (or clip attachment) a nearby component was damaged or shifted out of place. Check especially for small resistors or capacitors next to the BIOS chip
        • Gabesz103
          • Aug 2025
          • 12
          • Magyarország
          • Electronic devices
          #4304
          Originally posted by Maxpower3
          read MEC17 ,no others solution
          Ok, I ned to buy pickit4 for chip rading. I have a schematc, could you please check the connection pinout on the schematic? Do you have boardview to this thinkpad x1 yoga gen8? (same with carbon gen11)
          • MattyD44
            • Feb 2026
            • 7
            #4305
            Hello all,
            I've got a ThinkPad X1 Yoga 3rd Gen and the patcher completes successfully but after re-flashing I get the black screen and 0285 tune. I've attached the patched .bin, can anyone help please?
            Serial: R90VQAQ5
            Model: X1 Yoga 3rd - Type 20LE
            MB model: Can't find that on the board
            BIOS chip: W25Q128JV
            Thanks,
            Matt
              • 24137
              Please post that schematic in this thread topic -> https://www.badcaps.net/forum/troubl...m-e911-rev-2-0
                • 24137
                Originally posted by MattyD44
                Hello all,
                Thanks,
                Matt
                Please read https://www.badcaps.net/forum/troubl...before-posting and post the serial number , moel number (including model type) and motherboard model number.
                • MattyD44
                  • Feb 2026
                  • 7
                  #4308
                  Edited the post, sorry.
                  • Gabesz103
                    • Aug 2025
                    • 12
                    • Magyarország
                    #4309
                    Maxpower3,
                    Could you please help me? Thanks your support!
                      • 24137
                      Maxpower3,
                      Please attach files directly to your post in a zip or rar
                      • SevenOp
                        • Apr 2021
                        Lenovo X380 Yoga
                        Kind regards,
                        olivettinho
                        Had a similar issue on my T480s. Ended up having to desolder the chip and use a programmer to flash it off-board.
                        • olivettinho
                          • Feb 2026
                          • 9
                          Did that now, too; wiht original bios, fan spins 2 short times, powerled on the button stays on, but nothing else happens. I also used a spare bios chip, nothing changes.
                          • Stefan Steff
                            • Mar 2024
                            • 664
                            #4313
                            I will try to help you but first:
                            Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                            • olivettinho
                              • Feb 2026
                              • 9
                              Lenovo Thinkpad X380 Yoga - 20LJS18S00 (DTZS2)
                              Board: LA-F421P (Intel ME 11.8.55.3510 Corporate LP C0) Rev.: 1.0
                              S/N: MP1GUFWW
                              If you need any furhter Information, just let me know.
                              • Stefan Steff
                                • Mar 2024
                                • 664
                                #4315
                                S/N: MP1GUFWW
                                Thanks for the info,
                                Try first this dump.
                                It should work if you successfully patched and run your original dump making all steps.
                                If it's not working post your original dump.
                                _EDIT_
                                Added a second version and a third with brand new BIOS region and a clear ME region as you mentioned.
                                • olivettinho
                                  • Feb 2026
                                  • 9
                                  _EDIT_
                                  Thanks, I tried the V3 as it is the Corporate LP, but still the same issue; fan spins 2 times for about 1 sec, Screen black, LED on the power button constantly on; CAPSLOCK no reaction
                                  See my original dump attached
                                  • Stefan Steff
                                    • Mar 2024
                                    • 664
                                    #4317
                                    Please try to let it on for at least 10 minutes...
                                    • olivettinho
                                      • Feb 2026
                                      • 9
                                      OK I'll try, after about 3-4 minutes, the fan starts spinning continously and the CPU seems to get warm.
                                      • olivettinho
                                        • Feb 2026
                                        • 9
                                        Did that now, runs for about 15 mins, no other reaction; do i need to replug the power cord after the 15 minutes? Or should it show something on the screen?
                                        • Stefan Steff
                                          • Mar 2024
                                          • 664
                                          #4320
                                          It should give some picture within 10 minutes...
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Deniz
                                            IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                                            by Deniz
                                            Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                                            I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                                            I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                                            Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                                            After that, I tried to update the...
                                            01-27-2026, 06:56 AM
