  • Guest Is a noob
    • Oct 2024
    • Deutschland
    #3421
    I tried it on my svp locked l560 and the cmd File closed right as I opened it
    • Andreasbest
      • Aug 2014
      • 1195
      • Hellas ( Greece )
      #3422
      This means the dump is corrupted, happened to me too.
      • Andreasbest
        • Aug 2014
        • 1195
        • Hellas ( Greece )
        #3423
        I need help with a locked T440p
        I dumped the bios but for some reason autopatcher report it as corrupted, even if i dump it 3 times, i verify it 3 times and laptop posted and worked just fine with it, just bios locked.
        Since i was unable to patch it with autopatcher i had the brilliant idea to change the TPM using a patched bios from another 440p, worked fine BUT when i reflash the old bios (the supposedly corrupted OR the locked bios of the patched version) i get 5 beeps again and again.
        Tried RTC reset etc but no luck.
        I upload both bios.
        Any help appreciated.
        Thank you in advance!
        • Markus1741
          • Sep 2020
          • 897
          • N/A
          #3424
          Try this new build files ....
          • Andreasbest
            • Aug 2014
            • 1195
            • Hellas ( Greece )
            #3425
            Works like a charm. Can't thank you enough!!
            • Terabyter
              • Oct 2024
              • United States of America
              #3426
              ​not working for my T480 20L6
              after flashing the patched version it beeps.
              • Andreasbest
                • Aug 2014
                • 1195
                • Hellas ( Greece )
                #3427
                Works until T470.
                From T480 you must use this method https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
                • Crazyboy119
                  • Oct 2024
                  I have a X390 20Q1, with an i7-8665U. This is not the YOGA model! I need some guidance because I realized I was reading all about the YOGA version. I haven't pulled the dump yet but am getting to it tmr once I get the 3.3V mod done on my CH341A.
                  Any help is greatly appreciated!
                  • Andreasbest
                    • Aug 2014
                    • 1195
                    • Hellas ( Greece )
                    #3429
                    Not sure if autopatcher works on X390.
                    Not working on 480 and 480s so i assume the same for X390.
                    If not working then -> https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
                    • elle24
                      Elle24
                      • Sep 2024
                      • 10
                      Hi, please explain to us, does this auto patcher work on all lenovo laptop models ?
                      • Andreasbest
                        • Aug 2014
                        • 1195
                        • Hellas ( Greece )
                        #3431
                        No, only in a short range..
                        Until Intel 3rd gen we use the SCL and SDA short method (check google for it, depending on your model)
                        from 4th to 7th gen we use the autopatcher method
                        from 8th gen and up we use the LPC bus short method here
                        BUT somewhere in 10th gen we stop, no free solution from there, you can contact allservice.ro to ask if they have solution that requires laptop on their lab though.
                        • dtc911
                          Arvys
                          • Aug 2022
                          • 6
                          • Majami
                          #3432
                          I have a Lenovo ideapad gaming3 15IMH05 model name 81Y4..Need patchted bios ( forgott supervizor pasv).thenks
                          • ThinkpadMounty
                            • Sep 2023
                            • 14
                            Did anyone suggest what might be wrong? I get same issue
                            • jakobc
                              • Oct 2024
                              Having trouble with this on my T480s. Tried twice with the same result: I go through the process just fine in the patched BIOS and then restore the original image, but it still requires a password. The instructions say to reset the BIOS settings but it seems the settings are protected by the authentication system, so I'm stuck. Some people are reporting this works on T480s, so anybody know what's different in my case?
                              • kordex35
                                • Apr 2015
                                • 49
                                • Polska
                                #3435
                                You can make these models this way
                                ThinkPad T480 (20L5, 20L6)
                                • kordex35
                                  • Apr 2015
                                  • 49
                                  • Polska
                                  #3436
                                  valid dump
                                  • danito
                                    • Jun 2016
                                    • 1054
                                    #3437
                                    Originally posted by kordex35
                                    valid dump
                                    Provide the full machine model number, serial number
                                    • dtc911
                                      Arvys
                                      • Aug 2022
                                      • 6
                                      • Majami
                                      #3438
                                      SN:PF280VG6 MTM81Y400J5PB
                                      F.id JVHFC1
                                      MO PCF9XB0522118
                                      • shiyab
                                        • Sep 2023
                                        • 1581
                                        • india
                                        #3439
                                        F.id JVHFC1
                                        MO PCF9XB0522118
                                        hi try unlock
                                        • dtc911
                                          Arvys
                                          • Aug 2022
                                          • 6
                                          • Majami
                                          #3440
                                          hi .thenks i want to ask what method to use for unlocking?
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
