could someone help me get rid of the supervisor password on this?? I've tried with autopatcher and some other things from forum but no luck, is e595 20NF thankyouuouou 💖
Thanks.
Done everything in the correct order. After the patch i flashed the original bios and i was able to access the setup without password. Then i shut the machine off. I connected an empty ssd and when immediately the bios password came back...
Any ideas? I will do it again one more time.Comment
Can someone patch this for me please?
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
okAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi, can you remove the password of my ThinkPad device? Since I was not sure what information was required, I also added the bios image. Thanks in advance.
Model: 6th Gen ThinkPad X1 Carbon 20KGS3W813
Serial: PF18BC5HAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello.
I did the patching, put it on the laptop, turned it on, went through the steps. so far everything is fine.
I restored the original bios. and now it doesn't do anything except for one led blink.
If I unsolder the bios chip, it still does the same thing.
Laptop is T470
Help please!
Hi.
I have a E490 Device. The DXE Driver shows me 458478389 as Hardware-ID.
Can anyone generate the Key for me?
ThanksComment
I could do it. A 33 ohm resistor came downHello.
Laptop is T470
Help please!Comment
hi i have one lenovo t480 intel 8th gen with computrace ,i tried autopatcher but is stuck in entering setup endesly,any hel will be appreciated
t480
type 20l5-0018us
sn pf-1s3ylg 1907
try .. giving me feedback makes me happy to help moreAttached Filesif you find these attachements useful please consider making a small donation to the site
If you use the AUTO-PATCHER offered here, you don't need a hardware ID.
This point is simply skipped with enter.
STEP 5: Press enter when it shows Hardware IDComment
Thank you for responce.
Before I found this forum, I bought a so-called "password unlock chip" and soldered it to the board.
Now the notebook tells me something about wrong UEFI variables, shows me the hardware ID and expects a key.
I also don't know what happens if I just press Enter. I don't want the whole thing to become worthless.
Hello, you've caught quite a bit of fraud, the chip is worthless. After patching, you have to reinstall the original BIOS of the notebook. (which you don't have) I would read the original BIOS chip three times and compare the contents to see if everything matches. Patch the original BIOS with the autopatcher and then restore the original BIOS. Forget about the chewed chip.Comment
When Supervisor Password is DISABLED and you just want to De-Activate Computrace, you must first set the Supervisor Password and then (read)-patch-program the patched BIOS file and perform the unlock procedure which will reset the known Supervisor Password and de-activate Absolute Computrace. To finish just program the Original BIOS.Comment
lenovo t470s
hi can someone help me. i need patch me please! Thanks!Attached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
