Hello
on T470S, i weld the unluck bios chip, do all the procedure, but when i sold original bios, still asking for password
do you have any help ?
thanks
Attached Filesif you find these attachements useful please consider making a small donation to the site
Good day,
I would like to share, after follow the instruction all working well.
but now, the laptop only take longer time after pressing F1 menu, only "Entering Bios Menu" and after few minutes "laptop hang"
Model laptop : T470s
Serial : PC0NTV4P
Board type : 20HG-S07D0K
Using UEFIReplace to inject 2 DXE drivers...
[1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
[2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
Looking for volumes to patch...
[1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
Found volume at offset 800000h (checksum 2609h)
Replacing volume.
Done.
PATCH FILE: lenovo2_PATCHED.bin
Good luck.
above detail information, I can share it, need advise and need help how to handle this case
thanks
Three
tryGood day,
Serial : PC0NTV4P
Replacing volume.
Done.
Good luck.
thanks
Three
No. The steps details, power on - lenovo logo appears - press enter - and only bitlocker passcode needed - and if 3x times failed laptop shutdown.
unfortunately, I don’t have the password.
Another laptop have bitlocker code, but didn’t work.
Good day,
Serial : PC0NTV4P
Replacing volume.
Done.
Good luck.
thanks
Three
Finally, I can fixed these issue. I will update in this forum today.
Thank you ✌️
Follow step by step - ( thread "LENOVO BIOS AUTO-PATCHER ")Good day,
Serial : PC0NTV4P
Replacing volume.
Done.
Good luck.
thanks
Three
and I did another step
- Delete / erase program BIOS
- Re-programming using original T470s working bios (attached for original working bios)
and working well
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Knucklegrumble
thanks for sharing this tool and the instruction,
it works great an a Lenovo L480 (25Q128JV) to reset the passwordComment
thank's for making the process alot simpler @Knucklegrumble,
the tool you made is working to remove supervisor password on
Lenovo ThinkPad L13 with machine type 20R3 but, with some issues
that later i came across with my own solution & i wanna share
my solution that worked for me, because i've searched the net and
no one come with the solution.
after flashing patched bios to the chip i ignored message that said:
2204: System configuration data is invaid
and continuing the process that described on page 1, after re-flashed
original bios back to the chip the error message still exist, i thought
because i haven't done the "restore default" menu in bios and not attached
anything to the motherboard except screen, charger and usb keyboard
after restoring default in bios the error message still there and i still
ignored that, put back all together, set the date & clock and leave everything
on default value, exit the bios and before it boot to window the error 2204
emerge and halt the boot process, ask me to press ESC to continue and i did,
booted to window normaly and everything okay in windows, restart and error
2204 is halting again, asking to press ESC to continue (this time it get
my attention though). everytime the laptop turned on (cold boot or warm boot) always
halted by error 2204.
checked all serial in bios information it's all there, not invalid or missing.
i did all the steps on adding or editing DMI info using tool in
https://www.badcaps.net/forum/troubl...=5#post1622424
everytime i try to add using the tool it's always said "Data of the same device type is already in EEPROM"
searched for reference on error 2204 and found nothing related to my problem,
after intense nerf fighting i decide to take a risk that would brick this Thinkpad L13,
this is what i've done:- build bootable fdd using "Lenovo Gold Key U1 Tool", i followed instructions till creation using u1.exe
- booted the fdd and choose top of the menu (forget to take picture)
- press any key after choosing the top menu
- i followed instruction coolshrimp here https://www.badcaps.net/forum/troubl...74#post1711774, i think the instruction from coolshrimp a bit different but, the main goal is the same, to empty stored data on eeprom & enter same data but with diferent "aproach" using the tool (i think), just remember to read the S/N first and take a picture of it, cause you'll need reenter those exactly the same as it was
- after initializing eeprom chosen, the process could take 40-60 seconds so be patient and don't interupt
- when done initializing it will ask to enter serial number, enter the "C0" section from the picture you take exactly the same
- after that it will generate UUID & brand name, just choose "yes"
- after done and pressing enter, it will go back to S/N utility. if not just try to explore one by one menu until you found it, in S/N utility choose "add S/N" and choose "B0" then enter serial from the picture you take exactly the same
- choose exit from sub menu until main menu choose exit (shutdown)
- done
sorry for the long story, hope it helpsComment
Im confused as to what steps i am suppose to take. Do i just take these files and run them or am i suppose to flash it to a chip or something. Their are no written instrucions and i dont know what i am doing. (moments written before disaster) LOLComment
It can. I can confirm now, boot password can also be removed.Comment
LENOVO BIOS AUTO-PATCHER only works up to ThinkPad X1 Carbon Gen 6 (20KH, 20KG), your X1 Carbon is Gen 7, that's why.Comment
Thanks for picking it up. An error was caused that identified the wrong chip before I thought it was W25Q125FW, WHICH IS 1.8V. I grabbed a vast magnifier glass, and it was W25Q125FV, which is 3.3 v. Lenovo Patcher is done its thing now.Comment
Hello
can anyone help me with SVP
Lenovo P72 20MB (S/N PF-1FMMCY), Autopatcher will not workAttached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
- Loading...
